Discrepancy between Simple IRFs and Monte Carlo IRFs
jfwarren
Unread post by jfwarren »
I'm fairly new to RATS and hope you can help.
I'm running a two variable VAR for US Real GDP and the US savings rate and imposing a long run restriction (Blanchard-Quah restriction) that states that shocks to the savings rate have no long run effect on the growth rate of GDP.
I'm using the 2nd difference of the Log of Real GDP and the 1st difference of the savings rate and so expect to see that the accumulated impulse response of output to the savings shock converges to zero.
I get this result when I run the simple Impulse Responses but I also want to get the confidence bands for these too. Following the MonteCarlo procedure, I get very different impulse responses. Can you help? I'm not sure what is wrong with my code or whether there is a calibration discrepancy between the two.
OPEN DATA "C:\Users\jfw43\Dissertation\Eviews and Data Files\Savings Rate and Log GDP in Differences.RAT"
DATA(FORMAT=RATS) 1959:01 2014:03 D2LRGDP DSRATE
system(model=svar)
var d2lrgdp dsrate
lags 1
estimate(noprint,resids=resids)
compute factor=%bqfactor(%sigma,%varlagsums)
declare rectangular[series]  impulses(2,2)
com implabels = ||'Output','Savings Rate'||
impulse(decomp=factor,result=impulses,model=svar) * 40 *
@varirf(model=svar,decomp=factor,steps=40,page=byshocks,$
	variables=||"Real GDP","Savings Rate"||,shocks=||"Output", "Savings"||,accum=||1,2||)
And this for MC simulations:
****MONTE CARLO ESTIMATION******
compute [vect[strings]] shocklabels=||"Output","Savings"||
compute [vect[strings]] varlabels=||"Real GDP","Savings Rate"||
system(model=svar)
var d2lrgdp dsrate
lags 1
@BQDoDraws(model=varmodel)
@MCGraphIRF(model=varmodel,shocklabels=shocklabels,varlabels=varlabels)
Many thanks
Re: Discrepancy between Simple IRFs and Monte Carlo IRFs
You left the ACCUM=||1,2|| option off the @BQDODRAWS.
jfwarren
Thank you for a speedy reply.
I added in the accumulate option and I still get a very different looking impulse response function (i.e. the main thing is that the Monte Carlo ones are very smooth and do not give me a convergence to zero on the GDP response to a savings shock). Why might this be?
Are doing the Monte Carlo draws the best method to getting the standard errors? I'd prefer to plot my graphs manually in Excel, can I extract the standard errors in another format.
Many thanks,
jfwarren wrote:Thank you for a speedy reply.
They will be smoother because they're the average (or median) across a set of draws. Convergence to zero will likely be slower, sometimes much slower. See what happens if you increase the number of steps (perhaps to 100).
jfwarren wrote: Are doing the Monte Carlo draws the best method to getting the standard errors?
Yes.
jfwarren wrote: I'd prefer to plot my graphs manually in Excel, can I extract the standard errors in another format.
Use @MCPROCESSIRF. You could then copy the information out to an Excel file using COPY.
jfwarren
Thank you so much for your help. I increased the number of steps and it now converges to zero and looks very like the impulse responses I obtained from my original code.
I am trying to implement the @MCProcessIRF code to graph my own impulse response functions in Excel.
This is my code:
compute nvar = 2
compute nlags = 1
compute nsteps = 50
compute ndraws = 5000
system(model=svar)
var d2lrgdp dsrate
lags 1 to nlags
det
estimate(noprint)
declare vect[rect] %%responses
dim %%responses(ndraws)
infobox(action=define, progress, lower=1, upper=ndraws) "Monte Carlo Integration"
do draw=1, ndraws
impulse(noprint,model=svar,factor=factor,results=impulses,steps=nsteps)
do i=1, %rows(accum)
      do j=1,nvar
         acc impulses(accum(i),j) 1 steps
dim %%responses(ndraws)(nvar*nvar,nsteps)
ewise %%responses(ndraws)(i,j)=ix=%vec(%xt(impulses,j)),ix(i)
infobox (current=draw)
end do draw
infobox(action=remove)
@MCProcessIRF(model=svar,lower=lower,upper=upper,irf=irf)
For "@MCProcessIRF(model=svar,lower=lower,upper=upper,irf=irf)" I used the program file in https://estima.com/forum/viewtopic.php?f=8&t=1118 "b_l_jme2009.rpf" as a template.
A)What does lower=lower, upper=upper, irf=irf refer to?
B) When I run this output I get an error on the accumulate do loop. Why might this be? I want to accumulate both impulses.
Many thanks,
J
For (B) just use your original program and replace the @MCGRAPHIRF with @MCPROCESSIRF.
For (A) lower=lower, upper=upper, irf=irf, that's described in the help for the procedure:
* These are the outputs. They all need to be used. Each generates a
* RECT[SERIES], where x(i,j) is the series of responses of variable i to
* shock j.
* IRF=RECT[SERIES] with the central measure of the impulse responses
* LOWER=RECT[SERIES] with the lower bounds
* UPPER=RECT[SERIES] with the upper bounds
If you want to copy the information to Excel, you would do the @MCPROCESSIRF, then do something like
copy(format=xls,org=columns) / irf lower upper
For each combination of variable i and shock j, you have an IRF, a LOWER and an UPPER series.
jfwarren
Thank you Tom! That worked a treat.
My query is that the impulse responses although qualitatively the same as the simple accumulated IRs (I put them into excel and took the cumulative sum myself) I got from my original estimation the numbers are a bit different... why might this be? Is there an error somewhere in the calibration of my results from the MC simulation.
If you're talking about the IRF's, the output from @MCPROCESSIRF is (by default) the mean of the cloud of responses. That won't be the same as the response at the least squares estimates.
jfwarren
Thank you, that makes sense.
I am trying to estimate a five variable VAR to analyse the effects of a savings shock on GDP growth as well as the nominal interest rate, consumption and inflation. This is similar to that in Gali "Technology, Employment and the Business Cycle" (1999). It doesn't matter what the additional restrictions are as these are just to identify the the system and as long as they don't restrict the effect of a savings shock I believe it won't affect the impulse responses to this shock? Is this right?
The ordering of my variables is {second difference Log Real GDP, first difference savings rate, CPI inflation, first difference nominal interest rate, first difference log consumption}
dec rect lr(5,5) sr(5,5)
input lr
. 0 . . .
input sr
. . 0 0 0
. . 0 0 0
. . . 0 0
. . . . 0
This puts no contemporaneous restrictions on the effects of output and savings rate to their own and each other's shocks and then implements the same LR restriction as in my bivariate model.
My IRF results for a savings shock are attached - I'm surprised that there is no response after one period for all of the variables??
IRF Five Variable VAR.docx
(18.37 KiB) Downloaded 789 times
jfwarren wrote:Thank you, that makes sense.
Not necessarily. "B" models generally depend upon the full set of restrictions.
jfwarren wrote: The ordering of my variables is {second difference Log Real GDP, first difference savings rate, CPI inflation, first difference nominal interest rate, first difference log consumption}
input lr
. 0 . . .
input sr
. . 0 0 0
. . 0 0 0
. . . 0 0
. . . . 0
That sounds like you have lags=0 in the VAR.
jfwarren
Thank you - the zero lags was my problem. It looks much better now.
I'm trying to run the Monte Carlo simulations for this program as well following b_l_jme_2009.prg from Bjornland and Leitemo's paper (2009).
It runs fine until this point:
	dim %%responses(draw)(nvar*nvar,nsteps)
end do draw
where I get the error
## SX22. Expected Type STRING, Got INTEGER Instead
>>>>box (current=draw)<<<<
I didn't seem to have this problem before in my previous MC program. What does the error mean and how do I fix it? I'll attach the program file.
5var Monte Carlo.RPF
(3.35 KiB) Downloaded 1065 times
You have a space between infobox and the ( for the option field.
jfwarren
Thanks! I think I must be getting quite tired missing these things..!!
I've got a working MC code now but despite increasing the number of steps and draws, can't seem to get the response of output to a savings shock to converge to zero as it should do by my long run restriction.
Is there something wrong with my code or is this perhaps a side effect of imposing short run restrictions as well as the LR restriction.
compute nvar = 5
compute nlags = 1
compute nsteps = 200
compute ndraws = 1000
compute [vect[strings]] shocklabels=||"Output","Savings","Inflation","Interest Rate","Consumption"||
compute [vect[strings]] varlabels=||"Real GDP","Savings Rate","Inflation","Nominal Interest Rate","Consumption"||
system(model=fivevar)
var d2lrgdp ds dinf dr dlcons
lags 1 to nlags
det
compute vsigma=%sigma
input lr
. 0 . . .
input sr
. . 0 0 0
. . 0 0 0
. . . 0 0
. . . . 0
dec vect[strings] shocklabels varlabels
compute shocklabels=||"Output","Savings","Inflation","Interest rate","Consumption"||
compute varlabels=||"Real GDP","Savings Rate","CPI Inflation","Nominal Interest rate","Consumption"||
@ShortAndLong(lr=lr,sr=sr,masum=inv(%varlagsums)) %sigma f
compute fd=%xdiag(f)
ewise f(i,j)=f(i,j)/fd(j)
@varirf(noprint,model=fivevar,steps=nsteps,factor=f,page=byshock,accum=||1,2,4,5||,$
  shocks=shocklabels,varlabels=varlabels)
procedure SRLRDoDraws
option model     model
option integer   ndraws   1000
option integer   nsteps   200
option vect[int] accum   ||1,2,4,5||
option rect      lr
option rect      sr
local integer nvar
local rect    fxx fwish fsigmad factor
local integer wishdof
local rect    betaols betau betadraw
local vect    ix
local symm    sigmad
local integer i j draw
if .not.%defined(fivevar) {
   disp "###SRLRDoDraws(MODEL=fivevar,other options)"
   return
compute nvar=%modelsize(fivevar)
compute fxx    =%decomp(%xx)
compute fwish  =%decomp(inv(%nobs*%sigma))
compute wishdof=%nobs-%nreg
compute betaols=%modelgetcoeffs(fivevar)
local rect[series] impulses(nvar,nvar)
declare vect[rect]   %%responses(ndraws)
do draw=1, ndraws
	if %clock(draw,2)==1 {
      compute sigmad  =%ranwisharti(fwish,wishdof)
      compute fsigmad =%decomp(sigmad)
      compute betau   =%ranmvkron(fsigmad,fxx)
   else
   compute %modelsetcoeffs(model,betadraw)
@ShortAndLong(lr=lr,sr=sr,masum=inv(%modellagsums(fivevar))) sigmad factor
impulse(noprint,model=fivevar,results=impulses,steps=nsteps)
    	do j=1,nvar
        acc impulses(accum(i),j) 1 nsteps
	infobox(current=draw)
end do draw
compte %modelsetcoeffs(model,betaols)
end SRLRDoDraws
@SRLRDoDraws(accum=||1,2,3,4,5||,model=fivevar,lr=lr,sr=sr)
*@MCProcessIRF(model=fivevar,lower=lower,upper=upper,irf=irf)
@MCGraphIRF(model=fivevar,shocklabels=shocklabels,varlabels=varlabels,page=byshock)
Thank you
Don't change anything with the SRLRDODRAWS procedure---take it exactly as it is in the Bjornland-Leitemo replication. Instead of using the options to input your information (which is the whole point of procedures), you tried to edit the procedure to fit your model and ended up using an incorrect combination of OLS and sampled coefficients.
jfwarren
Thank you - got that sorted. I am totally new to this sort of software, have only ever used pre-set function windows in Eviews.
I am using the
@MCGraphIRF(model=threevar,shocklabels=shocklabels,varlabels=varlabels,page=byshock)
@MCProcessIRF(model=threevar,percentiles=||.16,.84||,center=median,lower=lower,upper=upper,irf=irf)
after the @MCProcessIRF function.
However, when I ran it the first time I got an option to save the output.... but I've used the same command today and it doesn't let me have that option and just finishes the MC integration a short progress box flashes up for a second and then there is neither any output or an option to save the output in my file?
