Log-likelihood function of SVAR models
condor
Unread post by condor »
I ran the cvmodel.prg and would like to compute the likelihood value myself. In the output, the results for "amodel" indicate that the log likelihood value is estimated as -281.0251
I tried the following formula (from the users guide), but it gives me a quite different answer. Am I missing something or doing something wrong? I would be glad, if anyone could help me...
dec rect bmat
compute bmat  = ||$
1,0,0,0,0,0|$
0,1,0,0,0,0|$
0,0,1,0,0,0|$
0,0,0,1,0,0|$
0,0,0,0,1,0|$
0,0,0,0,0,1||
compute llog = -%nobs/2*(2*(%log(%det(afrml(t)))-%log(%det(bmat)))-(%trace(%log(inv(bmat)*afrml(t)*%sigma*tr(afrml(t))*inv(tr(bmat))))))
Re: Log-likelihood function of SVAR models
%nobs/2 (written that way) won't be the correct value if %nobs is odd because it's an integer divide. Use .5*%nobs instead. You don't have the integrating constants in your formula. It looks as if we were missing the adjustment for the concentrating term ourselves. This was left out of both log likelihoods so it doesn't affect any of the tests, and doesn't affect the estimates, since it's a constant. The following will give you the value shown in the CVMODEL output if AFACTOR is the factor matrix created by the instruction:
disp %logdensitycv(afactor*tr(afactor),%sigma,%nobs)+.5*6*%nobs
and the correct log likelihood is either
or
disp %logl-.5*6*%nobs
