Failure at stacking two matrices....
Martin
Unread post by Martin »
Trying to stack two matrices into one, but no success for days. Can anyone help me to see which part goes wrong? Thanks.
Here is my program and output:
[1] DISP TR(ALPHAORT)
0.97456 0.22411 9.39326e-04 0.00000
0.01159 -0.05039 0.00239 0.99866
[2] DISP TR(%ALPHA1)*INV(OMEGA)
6662.33384 -27012.07346 -69.40077 -7486.57001
-6401.24550 8461.91272 192.20440 -19015.56708
[3] COMP IDLEFT = || TR(ALPHAORT) | TR(%ALPHA1)*INV(OMEGA) ||
[4] COMP IDRIGHT = || TR(%ALPHA1)*GAMMA*GY | %ZEROS(%R,1) ||
[5] DISP IDLEFT
0.97456
9.39326e-04 0.00000
6662.33384
==> I thought IDLEFT will be a 4x4 matrix. The outcome is not right.
[6] DISP IDRIGHT
-368.27392
-692.51845
0.00000
0.00000
[7] COMP SOL = INV(IDLEFT)*IDRIGHT
Can't Find Match for INV(RECTANGULAR(REAL)). Closest Match is INV(MATRIX(REAL))
>>>>P SOL = INV(IDLEFT)<<<<
Furthermore, if there is a variable, whenever I try to re-declare it shows
## SX1. Identifier A is Already in use as a(n) RECTANGULAR(REAL)
How do I release it and change it to a new type?
I tried RELEASE, but had no success.
Site Admin
Unread post by moderator »
With Version 7, you can use the new matrix concatenation operators to stack arrays. With older versions, you need to use the %BLOCKGLUE function to do this (you can also use an EWISE command with a %IF function or COMPUTE commands inside a DO loop, but the concatenation operator or %BLOCKGLUE function are easier).
With respect to re-declaring a variable as a different type, you can't change the type of a variable within a given program or session. You would need to clear the memory (using File-Clear Program or the "Clear Program" toolbar) and start fresh.
You can re-dimension an array without clearing the memory. For example, if you have a (5,5) rectangular array, you could re-dimension it as (10,10) or (2,8), etc. You just can't change the type.
Martin
Thank you so much. :D
