Creating indices
terrya
Creating indices
Post by terrya »
How can one create indices of the type Ind = 100*y(t)/y(t=n), where n is the particular observation on which the index is based?
terrya
Re: Creating indices
Post by terrya »
I should have said that I was looking for something cleverer than just using the actual value, something like the @elem instruction in EViews
Post by TomDoan »
set Ind = 100*y(t)/y(n)
or
set IND = 100*y/y(n)
RATS uses series{l} for lags and leads, and series(n) for references to specific entries.
marcushemma
Post by marcushemma »
How would that look if you want to create indices, with reference to a specific entry, e.g. 2000:1, for a number of series?
I tried a number of variations based on a do loop with the series as i = 1,n but that didn't work.
Any suggestions?
Post by TomDoan »
marcushemma wrote:How would that look if you want to create indices, with reference to a specific entry, e.g. 2000:1, for a number of series?
Any suggestions?
Something like:
dofor i = dpfood dpvice dpdura
   set(scratch) i = i{0}/([series] i)(1950:1)
You need to "cast" the index to a series in order to do the reference to a specific entry.
marcushemma
It works fine until the date for the base of the index but not afterwards. Here's an example that uses some data from the Enders' files.
cal 1959 1 4
all 2001:1
OPEN DATA "\Enders\Money_dem.xls"
DATA(FORMAT=XLS,ORG=COLUMNS) 1959:01 2001:01 DATE GDP RGDP M2 M3 TB3mo TB1yr
open data a:\money_dem.xls
data(org=obs,format=xls)
dofor i = gdp rgdp m2 m3
    set i =  i{0}/([series] i)(1960:1)
GRAPH(STYLE=LINE,KEY=BELOW) 4
# GDP
# RGDP
# M2
# m3
pri / gdp rgdp m2 m3
Post by TomDoan »
Sorry about that. If you overwrite the series, you need a SCRATCH option on the SET instruction. I've corrected the code in the previous post.
