dear Tom Doan
i have two variables lx ly, i will estimate a dcc-garch model, i set the variance as:
H1(t)=c1+a1*H1(t-1)+b1*e1(t-1)e1(t-1)'+a12*H2(t-1)
H2(t)=c2+a2*H2(t-1)+b2*e2(t-1)e2(t-1)'+a21*H1(t-1)
how can i modify the code mgarchdcc2? in the first step ,the code estimate the univariate GARCH models ,but could not include the the term a12*H2(t-1) and a21*H1(t-1)
meanwhile i try the garch VARIANCE option , and it can not exlude the MA term
thank you very much
* Multivariate GARCH with two-step DCC estimator
all 6237
open data g10xrate.xls
data(format=xls,org=columns) / usxjpn usxfra usxsui usxnld usxuk usxbel usxger usxcan
compute n=8
dec vect[series] x(n)
compute i=0
dofor [string] s = 'jpn' 'fra' 'sui' 'nld' 'uk' 'bel' 'ger' 'can'
compute xrate='usx'+s,i=i+1
set x(i) = 100.0*log(%s(xrate)/%s(xrate){1})
end dofor
dec vect[series] eps(n)
dec vect fullbeta(4*n+2)
* Do univariate GARCH models. Save the standardized residuals
* into eps(i). Copy the coefficients into the proper slots in
* the full beta matrix.
do i=1,n
garch(p=1,q=1,resids=r,hseries=h) / x(i)
set eps(i) = r/sqrt(h)
do j=1,4
compute fullbeta(n*(j-1)+i)=%beta(j)
* Compute the covariance matrix of the standardized residuals
vcv(matrix=rr)
# eps
* Create the series[symm] uu (outer product of residuals). Make
* it the unconditional value prior to the sample.
dec series[symm] uu q
gset uu %regstart() %regend() = %outerxx(%xt(eps,t))
gset uu 1 %regstart()-1 = rr
gset q = rr
* Log likelihood for the DCC phase, taking the residuals as given
nonlin a b
dec frml[symm] qf
frml qf = (qx=(1-a-b)*rr+a*uu{1}+b*q{1})
frml logl = q=qf,%logdensity(%cvtocorr(q),%xt(eps,t))
compute b=.80,a=.10
maximize logl 2 *
dcc grach
Re: dcc grach
You might want to look at the "VARMA" GARCH model which is built in to RATS (MV=DCC,VARIANCES=VARMA). You're one term short of that (it includes the lagged e^2 terms of both residuals in each equation), and it probably makes sense to include those if you including the lagged cross variance.
luxu1983
Re: dcc grach
thank you TomDoan, i have coded the garch model i mentioned aboveTomDoan wrote:You might want to look at the "VARMA" GARCH model which is built in to RATS (MV=DCC,VARIANCES=VARMA). You're one term short of that (it includes both residuals in each equation), and it probably makes sense to include those if you including the lagged cross variance.
but now question is the initial value setting for cross terms
