Latitude, longitude and distance
Roddy Dog
Unread post by Roddy Dog »
I have latitude and longitude coordinates for a range of cities. Can RATS compute the bilateral distances between them? If so, advice would be appreciated. Many thanks.
Re: Latitude, longitude and distance
The (great circle) distance is relatively straightforward once the latitude and longitude are converted to radians. In what format do you have them now?
Roddy Dog
Hi Tom, I have the latitude and longitude data in decimal degrees.
See https://www.movable-type.co.uk/scripts/latlong.html. If you have latitude as running from -90 (South) to +90 (North), then you convert to radians by multiplying those by %PI/180. If you have longitude from -180 to +180, similarly convert to radians by multiplying by %PI/180. The ATAN2(y,x) function in the Javascript code is the RATS function %ATAN(y/x). (ATAN2 is designed to handle x=0).
