GARCH-BEKK with initial values vector
myrthevandieijen
Unread post by myrthevandieijen »
I would like to estimate a GARCH BEKK without exogenous regressors and use those coefficient estimates as input for another GARCH BEKK estimation with exogenous regressors. I saw that there's an option 'initial', but I am struggling with the way to input previously estimated coefficients. I used %BETA, but the size of that vector is concerning me. It includes the estimates of the VAR(1) model coefficients I've estimated as mean model and the BEKK coefficients, but I would like to use the values in another model via 'initial' where I include dummies in the VAR(1) and external regressors in the GARCH BEKK. I think I would need to adjust the %BETA vector to include extra zeros in order to compute a vector of the same size of the new model I intend to estimate. How would I be able to do that?
I was thinking as well that I could estimate the VAR(1) with dummies separately (just as I did for the VAR(1) without dummies), and include those estimates in the vector and then add the %BETA coefficients of just the GARCH BEKK C, A and B matrices. How would I be able to do that?
I'm doing this because the GARCH model won't converge (even when adjusting the simplex iterations and BFGS iterations), so I want to change the initial values to help it converge.
It concerns this code (the code for the VAR(1) is standard):
* Estimate GARCH-BEKK without dummies
* with VAR(1) without dummies
garch(p=1,q=1,model=var1model,mv=bekk,rvector=rr,hmatrices=hh,pmethod=simplex,piters=20,iters=1000,robusterrors)
* need variables with coefficients to use later for initial_values in next GARCH-BEKK
compute coefficients = %BETA
display coefficients
* Estimate GARCH-BEKK with external event regressors
* use initial values from previous GARCH-BEKK without dummies ---> how??
garch(p=1,q=1,model=var1model,mv=bekk,rvector=rr_ev,hmatrices=hh_ev,initial = coefficients, iters=1000,robusterrors,xreg)
# prod_announce strat_moves fin_client neg_events
* Estimate GARCH-BEKK with company related events dummies
* with VAR(1) with seasonality dummies
garch(p=1,q=1,model=var1model_seas,mv=bekk,rvector=rr_ev,hmatrices=hh_ev,initial = coefficients, iters=1000,robusterrors,xreg)
Many thanks in advance for your help!
Myrthe
Re: GARCH-BEKK with initial values vector
Those are big, rather messy, parameter sets and rearranging the information isn't simple. Is there a reason you want to do that?
myrthevandieijen
My co-authors and I want to investigate volatility spillovers on different type of data than stock returns. I know it's not the standard way multivariate GARCH models are used, but that's one of the novelties of our paper so I'm certain I want to do this, I really hope you can help. As changing the initial values is one of the standard recommendations you receive once the model doesn't converge, I had expected there to be more examples online, but I couldn't find any unfortunately. I hope you might be able to help with creating a vector of coefficients.
I know how to create a vector in various languages, but I seem to get stuck in RATS (still a newbie)..
Many thanks in advance!
Myrthe
myrthevandieijen
Sorry to bother you again, but did you get a chance to look at the issue? I really need some help setting up this vector of initial values, would be great if you could give an example of how to code it.
Myrthe
