Create matrix to display results of various GARCH models
buddas
Unread post by buddas »
The code below is used to compute 30 different GARCH models for each one of a sample of 55 companies. Is there any way I can create a matrix to display all coeffs (both mean and variance ones) and the respective stderrs, t-stats, p-values and %converged?
Open Data C:\Users\buddas\Documents\Data2.xls
Data(Format=xls,org=col)
Stats(noprint) rt;com nobs = %nobs; com step = 501
do j=1,nobs,step
Display 'Garch results'
SMPL j j+500
garch(p=1,q=1,pmethod=simplex,piters=20,method=bhhh,reg,iters=500) / RT
# RMT DUMMY_2DAYS CONSTANT
# RMT DUMMY_0_10 CONSTANT
garch(p=1,q=1,pmethod=simplex,piters=20,method=bhhh,reg,xreg,iters=500) / RT
# DUMMY_AFTER
# DUMMY_AFTER
# RMT DUMMY_0_2 CONSTANT
# DUMMY_AFTER
# RMT DUMMY_0_5 CONSTANT
# DUMMY_AFTER
# RMT DUMMY_10_0 CONSTANT
# DUMMY_AFTER
# RMT DUMMY_10_10 CONSTANT
# DUMMY_AFTER
# RMT DUMMY_1_0 CONSTANT
# DUMMY_AFTER
# RMT DUMMY_1_1 CONSTANT
# DUMMY_AFTER
# RMT DUMMY_2_0 CONSTANT
# DUMMY_AFTER
# RMT DUMMY_2_2 CONSTANT
# DUMMY_AFTER
# RMT DUMMY_5_0 CONSTANT
# DUMMY_AFTER
# RMT DUMMY_5_5 CONSTANT
# DUMMY_AFTER
# RMT DUMMY_ANNMT CONSTANT
# DUMMY_AFTER
# RMT DUMMY_PREVIOUS DUMMY_ANNMT CONSTANT
# DUMMY_AFTER
# RMT DUMMY_PREVIOUS DUMMY_2DAYS CONSTANT
# DUMMY_AFTER
Thanks in advance :)
Re: Create matrix to display results of various GARCH models
Have you looked at REPORT with the REGRESS option? That's designed to organize output from various regressions (or other estimation instructions). Once the report is done you can either export it from the view on the screen, or export it directly using the UNIT option on REPORT(ACTION=SHOW,...)
