How to code up BVAR Impulse Response???
dnfloro1
Unread post by dnfloro1 »
My question is a bit basic, as I dont know how to code up the IMPULSE from the BVAR code in the Bayesian Econometrics Workbook. The code below does forecasting.
Im a newbie in Bayesian VAR, so thanks for your patience and help!
FROM THE BAYESIAN COURSE WORKBOOK:
compute lags=4			;*Number of lags
compute nstep=16		;*Number of response steps
compute nburn=500   	;*Number of burn-in draws
compute ndraws=2500	;*Number of keeper draws
open data haversample.rat
cal(q) 1959
data(format=rats) 1959:1 2006:4 ftb3 gdph ih cbhm
set loggdp = log(gdph)
set loginv = log(ih)
set logc   = log(cbhm)
* These are the controlling parameters for the symmetric "Minnesota"
* prior - the own lag tightness and the relative tightness on the other
* lags.
compute tight=.1
compute other=.5
* First, estimate the system with a prior via mixed estimation, to see if
* we come up with something similar via Gibbs sampling.
system(model=varmodel)
variables loggdp loginv logc ftb3
lags 1 to lags
specify(type=symmetric,tight=tight) other
* Estimate with a prior
estimate
compute nvar=%nvar
@BVARBuildPriorMN(model=varmodel,tight=.1,other=.5) hbpriors hpriors
@BVARFinishPrior hbpriors hpriors bprior hprior
compute sigmad=%sigma
dec vect[series] forecast(nvar)
dec vect[series] forestderr(nvar)
* Range to forecast
compute fstart=%regend()+1
compute fend  =fstart+nstep-1
do i=1,nvar
   set forecast(i)   fstart fend = 0.0
   set forestderr(i) fstart fend = 0.0
infobox(action=define,progress,lower=-nburn,upper=ndraws) "Gibbs Sampler"
do draw=-nburn,ndraws
   infobox(current=draw)
   * Draw b given sigma
   compute bdraw =%ranmvkroncmom(%cmom,inv(sigmad),hprior,bprior)
   compute rssmat=%sigmacmom(%cmom,bdraw)
   * Draw sigma given b
   compute sigmad=%ranwisharti(%decomp(inv(rssmat)),%nobs)
   if draw<=0
      next
   compute %modelsetcoeffs(varmodel,bdraw)
   simulate(model=varmodel,cv=sigmad,results=simresults,steps=nstep)
   do i=1,nvar
      set forecast(i)   fstart fend = forecast(i)+simresults(i)
      set forestderr(i) fstart fend = forestderr(i)+simresults(i)**2
end do draw
infobox(action=remove)
do i=1,nvar
   set forecast(i) fstart fend   = forecast(i)/ndraws
   set forestderr(i) fstart fend = sqrt(forestderr(i)/ndraws-forecast(i)**2)
do i=1,nvar
   set lower fstart fend = forecast(i)-2.0*forestderr(i)
   set upper fstart fend = forecast(i)+2.0*forestderr(i)
   graph(header="Forecasts of "+%l(%modeldepvars(varmodel)(i))) 4
   # forecast(i) fstart fend
   # lower fstart fend 2
   # upper fstart fend 2
   # %modeldepvars(varmodel)(i) fstart-12 fstart-1
Re: How to code up BVAR Impulse Response???
There are literally dozens of examples that do the impulse responses of various forms of VAR's. We did the forecasts in that example because we didn't have many examples of how to handle forecasts.
Look at the MONTEVAR.RPF example. Everything after the %MODELSETCOEFFS instruction in MONTEVAR is for handling impulse responses, and everything after that in the program you posted is for handling forecasts.
mightydell37
Unread post by mightydell37 »
TomDoan wrote:There are literally dozens of examples that do the impulse responses of various forms of VAR's. We did the forecasts in that example because we didn't have many examples of how to handle forecasts.
Can I use @MONTEVAR procedure after estimating the BVAR?
