Different size of graphs in spgraph envirmoment
paretto
Unread post by paretto »
is there a way to control the exact size of each graph in an spgraph enviroment. Let's say I have one graph in levels, the graph below should be just half the size of the upper graph.
Can I controll the size directly?
Thanks a lot!
Re: Different size of graphs in spgraph envirmoment
If you're talking about 2/3 to one and 1/3 to the other, no. You can nest SPGRAPH's inside SPGRAPH's, which will give you graphs of different sizes, but each SPGRAPH always divides its regions up equally.
