How to do a summation
huanpipt
Unread post by huanpipt »
Hello, I want to do a summation but I don't know how to do it
Following is my initial code.
I don't know how to write a loop to do the summation.
Could anyone help me?
dec real L k o sigx
dec series intergral(i)
nonlin L k o sigx varx
compute M=100
frml integral = (1/M)*exp(2*o*sin(2*%pi*(i*L/M)))*exp(-2*k*(t-(i*t/M)))
do i=0,M
compute integral = integral + integral
end do
Re: How to do a summation
Use SSTATS, though you need to be careful about your integer divides. As you've written it, 1/M is zero---you want 1.0/M, and you'll have similar problems with i*t/M. For SSTATS, the loop index has to be T, so it looks like you'll need to switch the T and I subscripts in your formula. Something like:
SSTATS 0 M (1/M)*exp(2*o*sin(2*%pi*(t*L/M)))*exp(-2*k*(i*(1.0-t)/M)))>>integral
huanpipt
Thanks for response.
In fact, I'd like to estimate the four parameters in the equation, as following
L k o sigx are four parameters
equation :
ec = exp(-r*TT)*(S*%cdf(d1)-S*%cdf(d1-(varf^(0.5))))
d1 = (log(S/S)+0.5*varf)/(varf^(0.5))
varf = varx*exp(-2*k*(TT))*integral
integral = summation from t=0 to t=M of (1.0/M)*exp(2*o*sin(2*%pi*(t*L/M)))*exp(-2*k*(ii*(1.0-t)/M))
I run the following code, however there is an error message
Could anyone help me with this?
Thanks very much.
open data TD3monthc2.xls
CALENDAR(irregular)
data(format=xls,org=columns) / ii TT r S A
dec real L k o sigx varx
nonlin L k o sigx
compute M = 100
SSTATS 0 M (1.0/M)*exp(2*o*sin(2*%pi*(t*L/M)))*exp(-2*k*(ii*(1.0-t)/M))>>integral
compute varx = sigx**2
frml varf = varx*exp(-2*k*(TT))*integral
frml d1 = (log(S/S)+0.5*varf)/(varf^(0.5))
frml ec = exp(-r*TT)*(S*%cdf(d1)-S*%cdf(d1-(varf^(0.5))))
frml RR = A - ec
nlls(frml=RR,piters=10,iters=100) * 1 99 UU
You will need to create a FUNCTION which evaluates the integral at a given value of T. See, for instance, the BONDS.RPF example, which does NLLS using a functional form which, like your integral, isn't closed form. As you have it written, INTEGRAL is computed only once, not once per entry in each function evaluation.
huanpipt
I follow the BOND.rpf to revise my code while there an error message that I cant solve.
1 part to set an loop of summation
dec real L k o sigx varx M
nonlin L k o sigx
compute M = 100
function opvalue p
type real opvalue
type integer p
*integral=opvalue
compute pp = 0
while pp<100 {
compute opvalue = (1/M)*exp(2*o*sin(2*%pi*(pp*L/M)))*exp(-2*k*(ii*(1-pp)/M))
compute opvalue = opvalue + opvalue
compute pp=pp+1
}end while
2nd part to sum all things to opvalue and then to estimate parameters
the error message appeared in this part
## SX22. Expected Type REAL, Got MATRIX(REAL) Instead
>>>>f(d1)-S*%cdf(d2)))<<<<
compute varf = varx*exp(-2*k*(TT(p)))*opvalue
compute d1 = (log(S(p)/S(p))+0.5*varf)/(varf^(0.5))
compute d2 = d1-(varf^(0.5))
compute opvalue = exp(-r(p)*TT(p))*(S*(%cdf(d1)-S*%cdf(d2)))
frml optionprice A = opvalue(t)
nlls(frml=optionprice,piters=10,iters=100) A 1 99 UU
I'm confused that I didn't set any matrix, why error message inform that.
Thanks for your help
huanpipt wrote:nonlin L k o sigx
compute M = 100
function opvalue p
type real opvalue
type integer p
*integral=opvalue
compute pp = 0
while pp<100 {
compute pp=pp+1
}end while
This has all kinds of problems. First, you need to read the message earlier about integer divides. 1/M and 1.0/M aren't the same thing and neither are (1-pp)/M and (1.0-pp)/M. Also, what do you think opvalue = opvalue + opvalue is going to do? What it will do is give you double the pp=99 value of the (1/M)... calculation. You need one variable for the pp-specific calculation, and a different one for the summation across pp.
Is there anything in this which depends upon data, or is this just a function of the non-linear parameters? And what is the argument "P" used for?
huanpipt wrote: 2nd part to sum all things to opvalue and then to estimate parameters
What's S. Isn't it a series? If you use it in a COMPUTE, it will be treated as a VECTOR. You're also using OPVALUE for two different purposes, and that entire second calculation is set up for executing just once, not once per function evaluation. That second one needs a different name, and it needs to be a function of the entry number or a FRML since it depends upon the data S.
huanpipt
compute M = 100
function opvalue p
type real opvalue
type integer p
*integral=opvalue
compute pp = 0
while pp<100 {
compute pp=pp+1
}end while
I thought I could use opvalue= opvalue(pp)+opvalue(pp+1) because there is another opvalue above.
I'll revised it again.
S is a series. Here I want to simulate the process in BOND.RPF - Add separate values into opvalue- so I add the summation part in the 1st part then add other part in 2nd part.
I thought I might misunderstand the FUNCTION, I'll try to revise it again.
Thanks for your help.
huanpipt
I revise the code
I use the function to do the summation integral
p I want to set it as different time, just as the code "compute mdate=maturity(bond)" in BONDS.rpf
Because there is only one variable ii in my equation so I only wrote "compute iii=ii(p)"
dec real L k o sigx M
nonlin L k o sigx
compute M = 100
function integral p
type real integral
type integer p
local real pp
compute integral = 0
compute iii = ii(p)
compute pp = 0
while pp<M {
compute partintegral = (1.0/M)*exp(2*o*sin(2*%pi*(pp*L/M)))*exp(-2*k*(iii*(1.0-pp)/M))
compute integral = integral + partintegral
compute pp = pp + 1
}end while
Then, I use SET to set each part of calculation
frml varf = sigx*exp(-2*k*(TT))*integral(t)
set d1 = (log(S/S)+0.5*varf)/(varf^(0.5))
set d2 = d1-(varf^(0.5))
set opvalue = exp(-r*TT)*(S*(%cdf(d1)-S*%cdf(d2)))
However, there is a error message.
If I shouldn't end the FUNCTION in the 1st part ?
huanpipt
I revised the code today. The 2nd part is put into FUNCTION in this code, but the error message still exists.
Would you please help me find which part is wrong?
Thank you very much.
dec real L k o sigx
nonlin L k o sigx
function opvalue p
type real opvalue
type integer p
local real pp iii M SS rp TTT integral varf d1 d2
compute iii = ii(p)
compute M = 100
compute pp = 0
while pp<M {
compute integral = integral + $
compute pp = pp + 1
}end while
compute TTT=TT(p)
compute varf = sigx*exp(-2*k*(TTT))*integral
compute SS=S(p)
compute d1 = (log(SS/SS)+0.5*varf)/(sqrt(varf))
compute d2 = d1-(sqrt(varf))
compute rp=r(p)
compute opvalue = exp(-rp*TTT)*(SS*(%cdf(d1)-SS*%cdf(d2)))
If you tried to run something similar to what you've posted, you should have also gotten warning messages that your non-linear parameters aren't initialized, and that it's trying 0. Zero is a bad number for at least the sigx if not for the others. Start with proper guess values and it should work. If it doesn't, then you probably need to try smaller (closer to zero) guesses for any of the parameters that are in exp(...) functions. With guess values of the wrong size, those could over- or underflow on the initial function evaluation.
huanpipt
It works.
I'm very Thankful for your help.
huanpipt
I'm really thankful for your previous help.
Now, I develop the model into a more complicated one and encounter a problem.
I attached the model in the word and following is my code.
CALENDAR(irregular)
data(format=xls,org=columns) / TT r S A X
dec real L k o sigx miu N
nonlin L K o sigx miu
function opvalue p
type real opvalue
type integer p
local real ii M SS rp TTT integral F ppp TTTT pppp F
compute TTT=TT(p)
compute ppp = TTT*360
compute XX=X(p)
**using if function to separate pre- or in-period**
**pppp is the calculation for summation F(t,Ti)  **
if TTT <= 1.0 / 12
 compute pppp = ppp
else
 compute pppp = 30
**set F initial**
compute F =0
**set loop for F**
while pppp > 0 {
compute TTTT = ppp / 360
**set loop for integral**
	compute M = 100
	compute ii = 0
	while ii<M {
	(1.0/M)*exp(2.0*o*sin(2.0*%pi*(ii*TTTT/M+L)))*exp(-2.0*k*(TTTT*(1.0-ii/M)))
	compute ii = ii + 1
**end loop for integral**
compute F = F + $
exp(XX*exp(-k*TTTT)+miu*(1-exp(-k*TTTT))+(0.5)*sigx*sigx*integral)*exp(-k*TTTT)
compute ppp = ppp - 1
compute pppp = pppp - 1
**end loop for F**
**obtain sigmaF, d1, d2,and finally opvalue**
compute SS=S(p)
compute sigf = (sigx*exp(o*sin(2*%pi*(L)))/N/SS)*F
compute d1 = (log(SS/SS)+0.5*sigf^(2))/(sigf)
compute d2 = d1-(sigf)
compute rp=r(p)
**set frml**
**set the initial value for each parameter**
compute N=30,L=-0.1,k=0.1,o=0.1,sigx=0.1,miu=0.1
**using least square to estimate**
nlls(frml=optionprice,piters=10,iters=500,trace) A
Indeed, there is no error message but it only shows the result like the following.
Non-Linear Optimization, Iteration 1. Function Calls 281.
Cosine of Angle between Direction and Gradient 0.0000000. Alpha used was 0.000000
Adjusted squared norm of gradient 0
Diagnostic measure (0=perfect) 0.3000
Subiterations 0. Distance scale 0.000000000
Old Function = 633700.642178 New Function = 633700.642178
New Coefficients:
-0.090000 0.100000 0.100000 0.100000 0.100000
Nonlinear Least Squares - Estimation by Gauss-Newton
Convergence in 1 Iterations. Final criterion was 0.0000000 <= 0.0000100
Dependent Variable A
Usable Observations 197 Degrees of Freedom 192
Total Observations 198 Skipped/Missing 1
Centered R**2 -704.178541 R Bar **2 -718.869761
Uncentered R**2 -149.076410 T x R**2 -29368.053
Mean of Dependent Variable 4.107614213
Std Error of Dependent Variable 2.141235790
Standard Error of Estimate 57.450188668
Sum of Squared Residuals 633700.64218
Log Likelihood -1075.02952
Durbin-Watson Statistic 0.012088
1. L -0.090000000 0.000000000 0.00000 0.00000000
2. K 0.100000000 0.000000000 0.00000 0.00000000
3. O 0.100000000 0.000000000 0.00000 0.00000000
4. SIGX 0.100000000 0.000000000 0.00000 0.00000000
5. MIU 0.100000000 0.000000000 0.00000 0.00000000
I think it's unusual, because I've set the pre-iteration and one data is missed from the sample.
Could you help me with this ?
I hope this may not be too annoying for you.
model.docx
(14.07 KiB) Downloaded 1165 times
This doesn't look right:
Why would you have SS/SS?
Your function, at least at the guess values, is obviously way off. You need to first walk through you formulas and make sure that you have them translated into calculations correctly. do
set test = opvalue(t)
print / test a
to see whether this is a general problem or if there are a few data points that are responsible for most of the very high sum of squared errors. If it's the latter, you can focus in on those calculations. If it's more general, than you will have to throw some DISPLAY instructions inside the function to determine where the calculation is going off track.
huanpipt
I set SS/SS because it's ATM options. In that case, S equals K.
I found one data point has the TT=0, as a result, F=0, sigf=0, opvalue= NA.
However, after I exclude this data, I found it still runs "strangely" ( only one iteration and no pre-iteration).
I'll use a simple data to check if the code for calculation is wrong.
I'm really appreciate your reply and help.
