how to specify bndecomp.src arma(p,q)
hardmann
Unread post by hardmann »
Before I decompose lgdp series by @bndecomp.src, I should rightly test ARIMA form of lgdp. However, I get ar=3 ma=1, which is refused by @bndecomp. It responese that ar should be between 0 - 2.
Best regards.
hardmann
Re: how to specifu bndecomp.src arma(p,q)
Not with any version of BNDECOMP that we've had in at least ten years.
hardmann
Re: how to specify bndecomp.src arma(p,q)
bndecomp.src had been revised in 2005,2006,2007.
I want to learn BN decom.
Best Regard.
Hardmann
The error message presumably was that the sample range was wrong, not that the AR parameters were wrong. If you use AR=3, you need the start parameter to be at least 4.
The one example we have that uses this is endersp252.rpf from the Enders textbook examples. That both does the BN decomposition by working out the calculations, and also by using BNDECOMP.
