why get MAT15 in bivariate DCC-GARCH
wendyyuan
Unread post by wendyyuan »
I make some modification based on ''garchmvdcc2''.
The main change is colored with red. The MAT15 problem (Subscripts Too Large or Non-Positive
) appears in the Log likelihood for the DCC phase
dec vect[series] eps(n)
dec vect fullbeta(2*n+2)
* Do univariate GARCH models. Save the standardized residuals
* into eps(i). Copy the coefficients into the proper slots in
* the full beta matrix.
do i=1,n
   garch(p=1,q=1,resids=r,hseries=h) / x(i)
   set eps(i) = r/sqrt(h)
   do j=1,2
      compute fullbeta(n*(j-1)+i)=%beta(j)
* Compute the covariance matrix of the standardized residuals
vcv(matrix=rr)
# eps
* Create the series[symm] uu (outer product of residuals). Make
* it the unconditional value prior to the sample.
dec series[symm] uu q
gset uu %regstart() %regend() = %outerxx(%xt(eps,t))
gset uu 1 %regstart()-1 = rr
gset q  = rr
* Log likelihood for the DCC phase, taking the residuals as given
nonlin a b
dec frml[symm] qf
frml qf   = (1-a-b)*rr+a*uu{1}+b*q{1}
frml logl =q=qf, %logdensity(%cvtocorr(q),%xt(eps,t))
compute b=.10,a=.010
maximize logl 1
* Compute the estimates into the final two slots in fullbeta
compute fullbeta(2*n+1)=%beta(1),fullbeta(2*n+2)=%beta(2)
Could you help me to find out how to correct it?
Appreciate any help!
Re: why get MAT15 in bivariate DCC-GARCH
maximize logl 1
is clearly wrong. You can't start at entry 1 since you need lags of the variance and the outer product of the residuals. The start period should be one higher than the range used in estimating the univariate GARCH models.
wendyyuan
TomDoan wrote:maximize logl 1
Sorry, I miss a 'star' here
it should be
Maximize logl 1 *
here the '1' is the end value for parameter.
I think there should be something wrong elsewhere. Please have a look.
Thanks a lot
The 1 for the start is what is wrong. You can't compute the likelihood starting at entry 1.
