cats 2.0 does not function with winrats 8.0
tavera
Unread post by tavera »
Dear all
our university has winrats 8.0 pro and CATS 2.0. Whe,n I try to use cats from the menu (time series then cats cointegration), winrats tries to find a file called CmyCATS.rsc which is not in CATS. If I select the myCATS.src file, winrats then tries to find the file called CCATStable.src which is not in CATS.
It seems that winrats 8.0 searches for files with a letter C added at the beginning of the names of the files included in CATS 2.0.
How to solve this problem ?
Do I have to rename all the files ?
Thanks in adavnce
Site Admin
Re: cats 2.0 deos not function with winrats 8.0
Unread post by moderator »
You need updates two at least a couple of the CATS files for compatibility with RATS 8. Depending on how your CATS 2.0 installation is, you may also need updates to other files.
Please email me at
support@estima.com
with your full name and CATS (or RATS) serial number and I will send the necessary files.
Tom Maycock
Esitma
Site Admin
We have now posted a zip file with the updates necessary for compatibility with RATS 8.0 here on the forum. See:
http://www.estima.com/forum/viewtopic.php?f=10&t=1129
Tom Maycock
