Asymmetric Exchange Rate Pass-Through
mightydell37
Unread post by mightydell37 »
I'm looking for the codes of the paper entitled "Asymmetric Exchange Rate Pass-Throuh in the Euro Area: New Evidence from Smooth Transition Models" by Nidhaleddine Ben Cheikh and available at http://dx.doi.org/10.5018/economics-ejournal.ja.2012-39
Re: Asymmetric Exchange Rate Pass-Through
Just follow the links in the site you posted to:
http://thedata.harvard.edu/dvn/dv/econo ... 02.1/18603
The .rar file is an archive with the RATS code and data.
mightydell37
I run the code below but I got this error:
## SX11. Identifier SEASONS is NOT recognizable. Incorrrect Option Field Parameter Order?
>>>>>>>ib{0 to 4} seasons {<<<<<<<<
How do I fix this error? Thanks.
DISPLAY '*******************************************************'
DISPLAY "Asymmetric ERPT in EA"
CALENDAR 1975 1 4
ALLOCATE 2010:4
OPEN DATA
DATA(FORMAT=XLS,ORG=COLS)
PRINT /
SET lipc_1 = log(ipc_1)
SET ltc_1 = log(tc_1)
SET lwpx = log(wpx)
SET lpib = log(pib)
*log transformation
set dlipc_1 = log(ipc_1) - log(ipc_1 {1})
set dltc_1 = log(tc_1) - log(tc_1 {1})
set dlwpx = log(wpx) - log(wpx {1})
set dlpib = log(pib) - log(pib {1})
*First difference
*Unit root tests:
@URADF(maxlag=8,sclags=18,det=constant,signif=.05) dlipc_1
@Zivot(maxlag=8,signif=.05,CRIT=AIC,BREAK=intercept) dlipc_1
@LPUnit(maxlag=8,signif=.05,Method=AIC,break=trend) dlipc_1
@URADF(maxlag=8,sclags=18,det=constant,signif=.05) dltc_1
@Zivot(maxlag=8,signif=.05,CRIT=AIC,BREAK=intercept) dltc_1
@LPUnit(maxlag=8,signif=.05,Method=AIC,break=intercept) dltc_1
@URADF(maxlag=8,sclags=18,det=constant,signif=.05) dlwpx
@Zivot(maxlag=8,signif=.05,CRIT=AIC,BREAK=intercept) dlwpx
@LPUnit(maxlag=8,signif=.05,Method=AIC,break=intercept) dlwpx
@URADF(maxlag=8,sclags=18,det=constant,signif=.05) dlpib
@Zivot(maxlag=8,signif=.05,CRIT=AIC,BREAK=intercept) dlpib
@LPUnit(maxlag=8,signif=.05,Method=AIC,break=intercept) dlpib
*Cointeration test:
LINREG lipc_1 / res
# constant ltc_1 lwpx lpib
*OLS estimation
@LAGSELECT(MAXLAG=8,SCLAGS=18,DET=constant,SIGNIF=.05) res
*procedure lagselect on residuals
@egtestresids(lags=2) res
*Engle-Granger test
*Gregory-hansen test (level shift):
@GregoryHansen(model=CONSTANT,LAGMETHOD=AIC,MAXLAGS=12,nograph) lipc_1
*Gregory-hansen test (level and slope shift):
@GregoryHansen(model=REGIMETREND,LAGMETHOD=AIC,MAXLAGS=12,nograph) lipc_1
*ARDL Model:
LINREG dlipc_1
# constant dlipc_1{1 to 4} dltc_1{0 to 4} dlwpx{0 to 4} dlpib{0 to 4} seasons{-2 to 0}
*OLS estimation
*standard equation is trimmed :
LINREG(lwindow=neweywest) dlipc_1
# constant dlipc_1{1 4} dltc_1{0 4} dlwpx{0 2 4} dlpib{1 3 4} seasons{-2 to 0}
summarize (%beta(5)+%beta(6)+%beta(7))/(1-(%beta(2)+%beta(3)+%beta(4)))
*Tests:
stat %resids
@RegCorrs(number=4,QSTATS,nograph,report)  %resids
display "AIC" %aic
@mcleodli(number=4) %resids
@ARCHTest(lags=4) %resids
*RESET Tests:
set resids = %resids
@regreset(h=4) resids
*STR Model
set vtc = log(tc_1) - log(tc_1 {1})
stat dltc_1
display *.####### %variance
display *.####### 1.0/sqrt(%variance)
*LSTR model:
nlpar(exactlinesearch)
compute scalef=1.0/sqrt(%variance)
nonlin(parmset=starparms) gamma c
frml glstar = logistic = %logistic(20.46*gamma*(dltc_1{4}-c),1.0)
compute c=%mean,gamma=2.0
equation standard dlipc_1
equation transit dlipc_1
frml(equation=standard,vector=phi1) phi1f
frml(equation=transit ,vector=phi2) phi2f
frml star dlipc_1 = g=glstar,phi1f+g*phi2f
nonlin(parmset=regparms) phi1 phi2
nlls(parmset=regparms,frml=star) dlipc_1
* Based upon the initial results, the standard equation is trimmed. This is now estimated with
* all the parameters.
# constant dlipc_1{4} dltc_1{0 2 3} dlwpx{0 1 2} dlpib{0} seasons{-2 to 0}
* We have to re-estimate this since we changed the specification.
nlls(parmset=regparms+starparms,frml=star,trace) dlipc_1
*Tests:
stat %resids
*Test d'absence d'autocorrelation residuelles :
display "AIC" %aic
*Tests d'absence d'effets ARCH :
*Fonction de transition :
set cc = %beta(26)
set Seuil = cc(t)
set F_Transition = glstar(t)
set V_Transition = dltc_1{4}
scatter
# V_Transition F_Transition / 10
nonlin coef1 coef2 coef3 coef4 coef5  coef6 coef7
compute coef1 = %beta(2)
compute coef2 = %beta(3)
compute coef3 = %beta(4)
compute coef4 = %beta(5)
compute coef5 = %beta(15)
compute coef6 = %beta(16)
compute coef7 = %beta(17)
*ERPT when G=0 :
compte SR = coef2
compte LR = (coef2+coef3+coef4)/(1-(coef1))
Display SR LR
summarize (%beta(3)+%beta(4)+%beta(5))/(1-(%beta(2)))
*ERPT when G=1 :
compte SR_g = (coef2+coef5)
compte LRg = (coef5+coef6+coef7)/(1-(coef1))
compte LR_g = (coef2+coef3+coef4+coef5+coef6+coef7)/(1-(coef1))
display SR_g LRg LR_g
summarize (%beta(3)+%beta(4)+%beta(5)+%beta(15)+%beta(16)+%beta(17))/(1-(%beta(2)))
summarize %beta(3)+%beta(15)
frml pt_sr = coef2+F_Transition*coef5
set ERPT_SR = pt_sr
frml pt_lr = LR+F_Transition*LRg
set ERPT_LR = pt_lr
*print / F_Transition ERPT
SCATTER(STYLE=DOTS,OVERLAY=DOTS,OVCOUNT=2,pattern,key=below,nokbox) 2
# V_TRANSITION F_TRANSITION
# V_TRANSITION ERPT_SR
# V_TRANSITION ERPT_LR
GRAPH(STYLE=LINE,OVERLAY=LINE,scale=both,OVCOUNT=1,$
klabel=||"Past Depreciation (Left scale)","Threshold","Short-run ERPT (Right scale)"||,key=below,nokbox,pattern) 3
# V_TRANSITION / 8
# Seuil / 3
# ERPT_SR / 1
klabel=||"Past Depreciation (Left scale)","Threshold","Long-run ERPT (Right scale)"||,key=below,nokbox,pattern) 3
# V_TRANSITION / 8
# Seuil / 3
# ERPT_LR / 1
*ESTR model :
frml glstar = exponential = 1-exp(-20.46^2*gamma*(dltc_1{4}-c)^2)
*Tests:
stat %resids
display "AIC" %aic
set cc = %beta(26)
set Seuil = cc(t)
scatter
*ERPT when G=0 :
compte SR = coef2
Display SR LR
*ERPT when G=1 :
set ERPT_SR = pt_sr
set ERPT_LR = pt_lr
# V_TRANSITION / 8
# Seuil / 3
# ERPT_SR / 1
# V_TRANSITION / 8
# Seuil / 3
# ERPT_LR / 1
It looks like it needs
SEASONAL SEASONS
at some point before the LINREG's start.
mightydell37
TomDoan wrote:It looks like it needs
SEASONAL SEASONS
Thanks a lot for your help. After adding SEASONAL SEASONS in the codes, the program now runs smoothly up to the part with McLeodiLi and ARCH tests. However, I get errors when I get to the estimation of the transition funcitions. Although I am able to plot the transition function, I got an error in the summary of function of coefficients and the latter charts are no longer produced since I got NAs in the summary of function of coefficients.
Grateful, if you can look at the codes. Thanks.
Comment out the @ARCHTEST procedure calls. They're overwriting the regression information.
mightydell37
TomDoan wrote:Comment out the @ARCHTEST procedure calls. They're overwriting the regression information.
Thanks a million, Tom. Perfect!
mightydell37
May I know how linearity tests against STR model was implemented? Table A1, p.23 of paper on Asymmetric Exchange Rate Pass-Through by Ben Cheikh presents these linearity tests but the codes were not included in the attached RATS code. The examples in the RATS Workbook using @STARTEST use only a univariate nonlinear models. The attached RATS codes also do not include the LM test of parameter constancy and the LM test of no remaining nonlinearity which appear in Table 1, p.15 of the paper.
Grateful if you can look into this query.
mightydell37 wrote:Dear Tom,
I'm pretty sure that Table A1 is just a list of results from univariate @STARTEST's. The entire paper is about univariate STAR models.
mightydell37 wrote: The attached RATS codes also do not include the LM test of parameter constancy and the LM test of no remaining nonlinearity which appear in Table 1, p.15 of the paper.
You would have to ask the author. You can see his questions and answers (his handle is nbcheikh) about this at:
https://estima.com/forum/viewtopic.php?f=30&t=747
If the parameter constancy test was actually done with @FLUX, it would not be an LM test---it's a Nyblom fluctuations test instead.
nbcheikh
Unread post by nbcheikh »
Nonlinearity test is done for the multivariate case and specification tests (parameter constancy and no remaining nonlinearity) are LM-type tests, all were done using Jmulti software which is freely downloadable on: http://www.jmulti.de/
mightydell37
Thanks a lot. I did this for Belgium and true enough, the chosen specification is LSTR for lag 1 of exchange rate depreciation and Linear for lags 2, 3 and 4. However, the LSTR model (even the ESTR model) estimated in RATS uses lag 4 of exchange rate depreciation.
wert12
Unread post by wert12 »
Dear Tom;
I downloaded the code from https://dataverse.harvard.edu/file.xhtm ... ersion=2.0. However, I get the signal "## SX11. Identifier AIC is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>TANT,LAGMETHOD=AIC,<<<<
Is it possible you meant
I
Common errors are
* a missing $ at the end of a long line which continues to the next"
How can I solve it?
Regards;
The syntax of @GregoryHansen changed quite a bit in 2012 around when this was written. The first use should now read:
@GregoryHansen(model=CONSTANT,method=AIC,MAXLAGS=12,nograph)
# lipc_1 ltc_1 lwpx lpib
with a similar change to the second one.
Note that this program doesn't really match the paper with which it's attached---it seems to be a similar, but still different analysis with the same data set. (The published paper uses a STAR effect only on the exchange rate, while this applies the threshold to the entire regression).
wert12
Dear Tom;
I chnaged the parts of the to RATS_codes to
"@GregoryHansen(model=CONSTANT,method=AIC,MAXLAGS=12,nograph)
Howver, I get the warning "Gregory-Hansen Cointegration Test
Null is no cointegration (residual has unit root)
Regression Run From 1975:03 to 2009:03
Observations 137
Break in Intercept. No Trend.
With 0 lags chosen from 12 by AIC
Variables
LIPC_1
LTC_1
LWPX
LPIB
Minimum T-Statistic -4.407
Achieved At 1980:03
1% Critical Value -5.770
5% Critical Value -5.280
10% Critical Value -5.020
## SX11. Identifier SEASONS is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>ib{0 to 4} seasons{<<<<
Common errors are
How can I solve it?
Regards;
wert12
Dear Tom;
When I delete the seasons from the main file, I got the warning as "
Value 0.45026526 t-Statistic 3.24838
Standard Error 0.13861222 Signif Level 0.0014908
NA NA NA
Summary of Function of Coefficients
Value NA t-Statistic 0.00000
Standard Error NA Signif Level 1.0000000
Value NA t-Statistic NA
Standard Error 0.07867283 Signif Level NA
## SR14. Empty Range on Series ERPT_SR."
Could you please help me? Regards.
