problem with egarch 2,2
karl5914
I am trying to implement my EGARCH 2,2 model with two components.
and I entered the follwoing commands:
nonlin A11 A22 A33 A44 A2 A3 A4
SET Q / = %seesq**0.5
SET H / = EXP(RANGE - 0.43)
SET U / = 0.0
compute A11=1, A22=0.9,A33=0.05,A44=-0.1, A2=0.12,A3=0.01,A4=-0.1
frml res = (RANGE - 0.43 - LOG(q))/0.29
frml qf = exp(A11+A22*log(q{1}) + A33*u{1} + A44*E{1}/q{1})
frml HF = exp(qf{1}+A2*log(h{1})+A3*u{1} + A4*E{1}/h{1})
frml logl = h(t)=hf(t),(Q(t)=QF(t)),(u(t)=res(t)),-0.5*(log(0.29**2) + u(t)**2/.29**2)
maximize(method=GENETIC,iters=100) LOGL 3 500
maximize(method=bfgs, iters=100) LOGL 3 500
but my result does not have the t-test for the last three variables like:
MAXIMIZE - Estimation by BFGS
Convergence in 8 Iterations. Final criterion was 0.0000000 <= 0.0000100
Daily(5) Data From 1987:01:05 To 1988:11:30
Usable Observations 498
Function Value 616.40462187
1. A11 -0.428450517 0.000069382 -6175.24257 0.00000000
2. A22 0.000215242 0.008749363 0.02460 0.98037336
3. A33 0.104713782 0.209460362 0.49992 0.61713021
4. A44 0.001762898 0.032202527 0.05474 0.95634234
5. A2 0.328352033 0.000000000 0.00000 0.00000000
6. A3 0.118726418 0.000000000 0.00000 0.00000000
7. A4 -1.335753740 0.000000000 0.00000 0.00000000
Would anyone know what has went wrong?
SET U / = 0.0
Re: problem with egarch 2,2
Where does H enter your likelihood? It looks as if you're hard coding a variance of .29 rather than using H.karl5914 wrote:I am trying to implement my EGARCH 2,2 model with two components.
and I entered the follwoing commands:but my result does not have the t-test for the last three variables like:Code: Select all
nonlin A11 A22 A33 A44 A2 A3 A4 SET Q / = %seesq**0.5 SET H / = EXP(RANGE - 0.43) SET U / = 0.0 compute A11=1, A22=0.9,A33=0.05,A44=-0.1, A2=0.12,A3=0.01,A4=-0.1 frml res = (RANGE - 0.43 - LOG(q))/0.29 frml qf = exp(A11+A22*log(q{1}) + A33*u{1} + A44*E{1}/q{1}) frml HF = exp(qf{1}+A2*log(h{1})+A3*u{1} + A4*E{1}/h{1}) frml logl = h(t)=hf(t),(Q(t)=QF(t)),(u(t)=res(t)),-0.5*(log(0.29**2) + u(t)**2/.29**2) maximize(method=GENETIC,iters=100) LOGL 3 500 maximize(method=bfgs, iters=100) LOGL 3 500
karl5914
the dependent variable is distrbuted as n( 0.43+lnh, 0.29**2)
karl5914 wrote:the dependent variable is distrbuted as n( 0.43+lnh, 0.29**2)
