I am trying to run BEKK (std) , BEKK (diag. ) models for log-return o & H index.
So I run this code in RATS 8.0 for BEKK (std):
open data Y1_O_A.xls
data(format=xls,org=columns) / O A
compute gstart=2,gend=2276
garch(p=1,q=1,mv=bekk,pmethod=simplex,piters=5,hmatrices=bekkhh, rvectors=bekkrv) gstart gend O A
Log Likelihood 12215.6569
1. Mean(1) 0.000283340 0.000400013 0.70833 0.47874139
2. Mean(2) 0.000664793 0.000280385 2.37100 0.01774018
3. C(1,1) 0.002027994 0.000343817 5.89846 0.00000000
4. C(2,1) -0.000395421 0.000278227 -1.42122 0.15525376
5. C(2,2) -0.000296307 0.000793017 -0.37365 0.70866801
6. A(1,1) 0.207104417 0.016768757 12.35061 0.00000000
7. A(1,2) -0.045891094 0.010128710 -4.53079 0.00000588
8. A(2,1) 0.032267832 0.023867324 1.35197 0.17638590
9. A(2,2) 0.210708054 0.015582838 13.52180 0.00000000
10. B(1,1) 0.973169654 0.004569885 212.95277 0.00000000
11. B(1,2) 0.011234222 0.003081176 3.64608 0.00026627
12. B(2,1) -0.004411685 0.005757129 -0.76630 0.44349814
13. B(2,2) 0.975466541 0.003366010 289.79906 0.00000000
1. How can I get AIC criteria?
2. how can I get conditional correlations? (to plot the graph, and export it as jpg/png ) (I know that I should use hmatrices and rvectors , so I assigned a variable to them in the models but dont know how to do next steps!)
3. in the original paper, the are using triangular BEKK , is there any trick to convert std. to triangular?
I tried to use this code( which is introduced by Mr.TOM here http://www.estima.com/forum/viewtopic.php?f=11&t=495) Then I failed!
compute n=2
dec packed vat(n,n) vbt(n,n)
dec packed vct(n,n)
dec rect var(n,n) vbr(n,n)
compute vat=sqrt(.05)*%identity(n),vbt=sqrt(.45)*%identity(n)
compute vct=%decomp(rr)
nonlin(parmset=tbekkparms) vct vat vbt
FUNCTION %%TBEKKInit
local integer i j
compute vcs=%ltouterxx(vct)
ewise vbr(i,j)=%if(j>=i,vbt(i,j),0.0)
ewise var(i,j)=%if(j>=i,vat(i,j),0.0)
END
frml hf = vcs+%mqform(h{1},vbr)+%mqform(uu{1},var)
maximize(title="Triangular BEKK",start=%%TBEKKInit(),parmset=meanparms+tbekkparms,$
method=bfgs,iters=400,pmethod=simplex,piters=5) logl gstart gend
because : rr is not introduced! ( actually in that code it is for initial setup parameters for MAXIMIZE code)
4.Then what is C in the table 6 first colmn.?
5.is Mean (1) the same as AR ?
6.is mean (2) the same as MA?
thanks in advance.
