MS dynamic probit model via Gibbs, Dueker 1999/2000
randerson
I wish to estimate Dueker's MS-Dynamic probit model, as in Dueker, JBES, 1999: Conditional Heteroscedasticity in Qualitative Response Models of Time Series, and Dueker, FRBStL Review, 2000, Are Prime Rate Changes Asymmetric?
I have the Rats proc for Gibbs on the dynamic probit model
https://ideas.repec.org/c/boc/bocode/rtz00182.html
and Tom Doan's program for Dueker's 2005 article Qual VAR paper https://ideas.repec.org/c/boc/bocode/rtz00049.html
I also have Dueker's 2000 Gauss code, as posted on the St Louis Fed web site
<http://research.stlouisfed.org/publicat ... ticle/3452>
but I have gotten a bit lost combining the Rats code and the Gauss code into a program for Dueker's 1999/2000 MS Dynamic Probit.
Perhaps this is not as difficult as I am making it. Has anyone attempted this before?
Thank you very much for any guidance.
Richard Anderson
Richard Anderson
Re: MS dynamic probit model via Gibbs, Dueker 1999/2000
The one piece of that that isn't "off the shelf" is the draws for the cutoffs for the ordered probit. Given the y*'s, that's a draw from a uniform from the range bounded by the highest y* below to the lowest y* above.
randerson
I see. Dueker's Gauss code has those arrays as hcat and lcat, where "cat" are his 7 categories segregated by size of change in y (measured in basis points). I see the draws from the uniform. I will keep working on it. Thank you.
This is an example of sampling for an ordered probit model using the same basic procedure as is followed for the ordered probit part of the Dueker paper. I'm not sure it's a particularly good sampling scheme. The problem is that the y*'s and the cuts are highly correlated (y*'s are squeezed between the cuts and the cuts are squeezed between the y*'s) but are drawn separately. You might want to see if you can find a paper which does a better-designed sampler for the ordered probit. Offhand, I'm thinking that putting a constant in the regressor set and pegging the middle cut point to zero would work better by turning the cut parameters into differentials, rather than making them also have to take care of the level. The two parameterizations are equivalent for ML, but aren't for Gibbs sampling.
* Example of Gibbs sampling for an ordered probit model.
* Based upon Wooldridge, "Econometrics of Cross Section and Panel Data",
* 2nd ed. Example 16.2 from pp 657-658
open data pension.raw
data(format=free,org=columns) 1 226 id pyears prftshr choice female $
married age educ finc25 finc35 finc50 finc75 finc100 finc101 $
wealth89 black stckin89 irain89 pctstck
* Linear model.
linreg pctstck
# choice age educ female black married finc25 finc35 finc50 finc75 $
finc100 finc101 wealth89 prftshr constant
* Ordered probit estimated by ML.
ddv(type=ordered,dist=probit,cuts=cuts) pctstck
* Flat prior on coefficients
dec symm hprior
dec vect bprior
compute hprior=%zeros(%nreg,%nreg)
compute bprior=%zeros(%nreg,1)
* YSTAR will be the latent variable which determines the choice. It's
* treated as a set of parameters in the sampler.
dec series ystar
* Create an equation with the regressors from the ML estimate of the
* ordered probit. Save the estimates into BDRAW, which will be used for
* the draws for the coefficients.
equation(lastreg) eqn ystar
compute bdraw=%beta
* Get the set of values of the dependent variable.
@uniquevalues(values=yvalues) pctstck
compute ngroup=%size(yvalues)
* For convenience, create a SERIES[INTEGER] which maps an entry to the
* position in the YVALUES vector based upon the dependent variable.
dec series[int] which
gset which = 0
do time=gstart,gend
do i=1,ngroup
if pctstck(time)==yvalues(i) {
compute which(time)=i
break
end do time
* This will be used inside the draw loop
dec vect lcat(ngroup) hcat(ngroup)
* These will be the parameters that we save on each draw: the regression
* parameters for the index function and the cut points.
nonlin(parmset=oprobit) bdraw cuts
compute ndraws=10000
compute nburn=10000
dec series[vect] bgibbs
gset bgibbs 1 ndraws = %parmspeek(oprobit)
infobox(action=define,progress,lower=-nburn,upper=ndraws) $
"Ordered Probit Model-Gibbs Sampling"
do draw=-nburn,ndraws
* Draw y*'s given regression coefficients and cuts. This is a
* truncated Normal with mean equal to X beta at the current set of
* coefficients with lower and upper bounds determined by the cut
* points.
set cmean gstart gend = %eqnvalue(eqn,t,bdraw)
set lower gstart gend = %if(which==1,%na,cuts(which-1))
set upper gstart gend = %if(which==ngroup,%na,cuts(which))
set ystar gstart gend = %rantruncate(cmean,1.0,lower,upper)
* Draw beta's given y*'s. Given the y*'s, this is just a
* straightforward draw for a regression (with residual variance 1).
cmom(equation=eqn)
compute bdraw=%ranmvpostcmom(%cmom,1.0,hprior,bprior)
* Draw cut points. These are drawn uniformly from the values in the
* gaps between the y*'s for the different values of "which".
do i=1,ngroup
ext(smpl=(which==i),noprint) ystar gstart gend
compute lcat(i)=%minimum,hcat(i)=%maximum
do i=1,ngroup-1
compute cuts(i)=%uniform(hcat(i),lcat(i+1))
infobox(current=draw)
* If we're out of the burn-in, save the parameters
if draw>0
compute bgibbs(draw)=%parmspeek(oprobit)
end do draw
infobox(action=remove)
@mcmcpostproc(ndraws=ndraws,mean=bmean,stderrs=bstderrs,cd=bcd) bgibbs
