sign restrictions: Rubio-Waggoner-Zha approach
tclark
In light of the broad interest in sign restrictions on VARs, before writing my own code I thought it might be worth asking if anybody has already written code for the sign restriction algorithm developed (see pp.45-46) in "Structural Vector Autoregressions: Theory of Identification and Algorithms for Inference," by J. Rubio-Ramirez, D. Waggoner, and T. Zha (http://home.earthlink.net/~tzha01/worki ... TIFICATION). The same algorithm is used in the paper "Markov-Switching Structural Vector Autoregressions: Theory and Application" by the same authors.
If anyone has code already and would be willing to share it, I would very much appreciate it.
Todd
Todd
Todd Clark
Economic Research Dept.
Re: sign restrictions: Rubio-Waggoner-Zha approach
There's a %QRDECOMP function in RATS, so you can do that with
The "Q" matrix is qr(1). %QRDECOMP doesn't control the signs on the diagonal of the R matrix, but that doesn't seem to be important. (Flipping signs on columns of Q doesn't affect its distribution).
Note, by the way, that that procedure is actually no different (in practice) from the sequential generation that's done in our Uhlig examples.
compute qr=%qrdecomp(%ranmat(n,n))Note, by the way, that that procedure is actually no different (in practice) from the sequential generation that's done in our Uhlig examples.
tclark
Thanks, Tom. The coding seems easy enough now.
tclark
The program in the box modifies Tom Doan's Uhlig-with historical decompositions program to use the sign restrictions algorithm of Rubio, Waggoner, and Zha. As Tom noted, the RWZ approach is the same in practice, except that the RWZ approach is faster with large models. This code handles the impulse responses and historical decompositions (which I need), but not the forecast error variance decomposition (which is simply commented out).
* This program applies the sign restriction algorithm of "Structural Vector Autoregressions: Theory of Identification
* and Algorithms for Inference" and "Markov-Switching Structural Vector Autoregressions: Theory and Application"
* by J. Rubio-Ramirez, D. Waggoner, and T. Zha to estimate impulse responses as in Uhlig (2005), "What are the
* effects of monetary policy on output? Results from an agnostic identification procedure." Journal of Monetary
* Economics, 52, pp 381-419.
* Todd Clark wrote the program by modifying Tom Doan's Uhlig code.
* This version omits the computation of the forecast error variance but does inclue an historical decomposition
* of the data showing the cumulative effects
* of the monetary policy shocks. Note that this is not part of the paper.
grparm(portrait) header 15 subheader 12 keylabeling 16 footer 10 vlabel 12 hlabel 12
env nowshowgraphs gsave="Myresults*.rgf" gformat=rgf
open data uhligdata.xls
calendar(m) 1965
data(format=xls,org=columns) 1965:01 2003:12 gdpc1 gdpdef cprindex totresns bognonbr fedfunds
set gdpc1 = log(gdpc1)*100.0
set gdpdef = log(gdpdef)*100.0
system(model=varmodel)
lags 1 to 12
estimate(noprint)
dec vect[strings] vl(6)
compute vl=||"real GDP","GDP price defl","Comm. Price Ind.","Fed Funds Rate","Nonborr. Reserv.","Total Reserves"||
* n1 is the number of draws from the posterior of the VAR
* n2 is the number of draws from the unit sphere for each draw for the VAR
* nvar is the number of variables
* nstep is the number of IRF steps to compute
* KMAX is the "K" value for the number of steps constrained
compute n1=10000
compute n2=10000
compute nkeep=20000
compute nvar=6
compute nstep=60
compute KMAX=5
* set up the number of shocks considered, along with signs
* Note that the computations portion of the program is set up to allow
* for multiple shocks, but the portion of the program that constructs the charts
* assumes only one shock of interest
comp nshock = 1
dec rec signs(nvar,nshock) ;* a matrix with the signs to be imposed, for # shocks = nshock
* use a 1 for >= 0, -1 for <= 0, and %NA for unrestricted
comp signs = ||%NA|-1|-1|1|-1|%NA||
compute hstart = 1998:1
compute hend = 2002:12
compute nhor = hend-hstart+1
dec vect[series] upaths(nvar) u(nvar) onesteps(nvar) base(nvar) baseplus(nvar)
clear upaths
compute sxx =%decomp(%xx)
compute svt =%decomp(inv(%nobs*%sigma))
compute ncoef =%rows(sxx)
compute wishdof=%nobs-ncoef
* Most draws are going to get rejected. We allow for up to nkeep good ones. The
* variable accept will count the number of accepted draws. GOODRESP will be a
* RECT(nvar,nshock) at each accepted draw.
declare rect[rect] goodresp(nkeep,nstep) ;* goodfevd(nkeep)
declare vector ik a ones(nvar)
dec rec ikmat
compute ones=%const(1.0)
declare vector hk(nvar)
declare rect[rect] goodhist(nkeep,nshock)
* set up a vector of selection matrices that correspond to e(i) e(i)' in Tom Doan's notes on hist. decomp.
dec vec[rec] selmat(nshock)
do i = 1,nshock
comp selmat(i) = %zeros(nvar,nvar)
comp selmat(i)(i,i) = 1.
compute accept=0
infobox(action=define,progress,lower=1,upper=n1) "Monte Carlo Integration"
do draws = 1,n1
* responses.
compute sigmad =%ranwisharti(svt,wishdof)
comp [symm] invsigmad = inv(sigmad)
compute swish =%decomp(sigmad)
compute betau =%ranmvkron(swish,sxx)
* Use static forecasts over the period for historical decomposition to get the
* residuals. Use dynamic forecasts over the same period to get the base forecast
* series for the historical decomposition.
forecast(model=varmodel,from=hstart,to=hend,results=onestep,errors=u,static)
forecast(model=varmodel,from=hstart,to=hend,results=base)
impulse(noprint,model=varmodel,decomp=swish,results=impulses,steps=nstep)
*gset irfsquared 1 1 = %xt(impulses,t).^2
*gset irfsquared 2 nstep = irfsquared{1}+%xt(impulses,t).^2
* orthogonal components.
do subdraws = 1,n2
* first compute the QR decomposition and normalize signs as in RWZ Matlab code
comp qr=%qrdecomp(%ranmat(nvar,nvar))
do i = 1,nvar
if qr(2)(i,i)<0.
comp %psubmat(qr(1),1,i,-1.*%xcol(qr(1),i))
comp pmat = qr(1)
* Check that the responses have the correct signs for steps 1 to KMAX+1
* (+1 because in the paper, the steps used 0-based subscripts, rather than
* the 1 based subscripts used by RATS).
do k=1,KMAX+1
comp ikmat = %xt(impulses,k)*pmat ;* matrix of responses of i (row) to shock to j (col)
do i = 1,nshock ;* loop across shocks to check signs
comp ik = %xcol(ikmat,i).*%xcol(signs,i) ;* if the sign is right, the product should be >= 0
if %minvalue(ik)<0
branch 105
end do k
* This is an accepted draw. Copy the information out. If we have enough
* good ones, drop out of the overall loop.
compute accept=accept+1
dim goodresp(accept,nstep)(nvar,nshock) ;*goodfevd(accept)(nstep,nvar)
do k = 1,nstep
comp ikmat = %xt(impulses,k)*pmat ;* matrix of responses of i (row) to shock to j (col), at horizon k
comp goodresp(accept,k) = %xsubmat(ikmat,1,nvar,1,nshock) ;* pull out just responses to shocks of interest (subset of cols)
*ewise goodresp(accept)(i,j)=ik=%xt(impulses,i)*a,ik(j)
*ewise goodfevd(accept)(i,j)=ik=(irfsquared(i)*(a.^2))./(irfsquared(i)*ones),ik(j)
* Compute the historical paths of shocks to the system corresponding to the
* <<a>> weights on the Choleski factor.
comp PAmat = swish*pmat
do k = 1,nshock
dim goodhist(accept,k)(nhor,nvar)
compute remap = %mqform(selmat(k),tr(PAmat))*invsigmad ;* this uses the middle term of equation 4 of Tom Doan's notes
* on historical decompositions, with F = PAmat
do t=hstart,hend
compute %pt(upaths,t,remap*%xt(u,t))
end do t
* Forecast over the decomposition period with those added shocks
forecast(model=varmodel,from=hstart,to=hend,results=baseplus,paths)
# upaths
* Save the difference between the forecasts with and without and added shocks
* (and shift them into the slots 1,...,nhor) of <<goodhist>>.
ewise goodhist(accept,k)(i,j)=baseplus(j)(i+hstart-1)-base(j)(i+hstart-1)
end do k
if accept>=nkeep
break
:105
end do subdraws
if accept>=nkeep
break
infobox(current=draws)
end do draws
infobox(action=remove)
clear upper lower resp
spgraph(vfields=3,hfields=2,hlabel="Figure 6. Impulse Responses with Pure-Sign Approach")
do i=1,nvar
compute minlower=maxupper=0.0
smpl 1 accept
do k=1,nstep
set work = goodresp(t,k)(i,1) ;* only 1 shock of interest, so we only pull out the first column
compute lower(k)=frac(1)
compute upper(k)=frac(2)
compute resp(k)=%avg(work)
end do k
smpl 1 nstep
graph(ticks,number=0,picture="##.##",header="Impulse Responses for "+vl(i)) 3
# resp
# upper / 2
# lower / 2
spgraph(vfields=3,hfields=2,hlabel="Figure 8. Fraction of Variance Explained with Pure-Sign Approach")
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodfevd(t)(k,i)
compute upper(k)=frac(3)
compute resp(k)=frac(2)
end do k
smpl 1 nstep
graph(ticks,number=0,min=0.0,picture="##.##",header="Fraction Explained for "+vl(i)) 3
# resp
# upper / 2
# lower / 2
declare series upperH lowerH respH
spgraph(vfields=3,hfields=2,hlabel="Figure X. Historical Decomposition with Pure-Sign Approach")
do i=1,nvar
smpl hstart hend
clear upperH lowerH respH
smpl 1 accept
do k=hstart,hend
set work 1 accept = goodhist(t,1)(k-hstart+1,i) ;* only 1 shock of interest, so we only pull out the first column
compute lowerH(k)=frac(1)
compute upperH(k)=frac(3)
compute respH(k)=frac(2)
end do k
smpl hstart hend
graph(ticks,dates,picture="##.##",header="Contribution of Monetary Policy shock to "+vl(i)) 3
# respH hstart hend
# upperH / 2
# lowerH / 2
spgraph(done)-
marko3499
i would like to do forward error variance decomposition with this code, but I’m not quite sure how to do this. As far as I can see, the goodfevd matrix would be included in a loop similar to goodresp in Todd Clark’s code (where ikmatv would be the holder for FEVD below):
dim goodresp(accept,nstep)(nvar,nshock) goodfevd(accept,nstep)(nvar,nshock)
do k = 1,nstep
comp ikmatv = ???
comp goodfevd(accept,k) = %xsubmat(ikmatv,1,nvar,1,nshock)
How could this be done so that goodfevd could then be used for graphs analogously to goodresp?
Thanks in advance!
do k = 1,nstep
comp ikmatv = ???
Thanks in advance!
istiak
Dear Todd
From your code posted on October 27, 2009; I can understand that the VAR model uses monthly data from 1965.01-2003.12. But the code also shows the following part:
My question is, what does 'hstart' and 'hend' stand for.
Thank you so much.
KI
Thank you so much.
KI
That's the range for the historical decomposition.istiak wrote:Dear Todd
Thank you so much.
KI
istiak
Dear Todd/Tom
I will really appreciate the following two helps from the code.
1. In the code we are getting impulse responses for 1 SD increase in fedrate. Can you please show how I can get impulse responses for 1% increase in fedrate?
2. Besides the IRFs from 1% increase in monetary shock, how can I get IRFs from 1% increase in total reserve (the fourth variable in the VAR model)?
Thank you so much.
KI
Thank you so much.
KI
KOBE24
I am using the above program by Todd Clark to achieve historical decomposition after identifying 4 shocks.
The strange thing, at least to me, is that the baseline looks to be different depending on the number of draws from the posterior and / or from the unit sphere (I mean, very different, if I take
whatever n1 or n2 belonging to the following intervals
n1 [10000, 50000]
n2 [5000, 10000]
Is it supposed to be like that? What am I missing?
My intuition is that only baseplus(j)(i+hstart-1) should be changing across draws, not base(j)(i+hstart-1).
Thank you in advance for taking the time of answer this (basic) question.
n1 [10000, 50000]
n2 [5000, 10000]
** Forecast over the decomposition period with those added shocks
# upaths
ewise goodhist(accept,k)(i,j) = baseplus(j)(i+hstart-1)-base(j)(i+hstart-1)
end do k
if accept>=nkeep
break
:105
end do subdraws
if accept>=nkeep
break
end do draws
base changes with each value of draw. Given that, it's fixed across each subdraw.
KOBE24
thanks a lot, Tom.
your help is invaluable!
lali62
Could you tell me if I understand this logic of branch 105 in the loop correctly:
lets say I have 3 shocks and KMAX=5
do subdraws = 1,n2
do k=1,KMAX+1
*disp %minvalue(%xcol(ikmat,2).*%xcol(signs3,2))
if %minvalue(ik)<0
branch 105
end do k
if %minvalue(ik)<0, I iterate through next value of nshock.
lets say the value of i=3 and %minvalue(ik)<0, then I would go to the next iteration of k.
Also lets say if I am at i=3 and k=6, and %minvalue(ik)<0, then I would go to next iteration of subdraw.
Is this understanding correct.
if %minvalue(ik)>=0, I break out of inner loops i and k,and treat this as an accepted draw
do subdraws = 1,n2
do k=1,KMAX+1
if %minvalue(ik)<0
branch 105
end do k
The point of this is to reject the subdraw completely whenever the calculation fails to produce the proper sign (>=0).
if %minvalue(ik)<0
branch 105
It's only if you fully complete the I and K loops that you get an accepted subdraw.
if %minvalue(ik)<0
branch 105
