How to convert a vect into a series?
Jennylai
Dear all,
My question is: How should I do if I want to convert a vector into a series?
For example, I have a 9by1 vector y, and I want to assign the values of each ofthe element in this vector y to a series yt starting from 2008:2 to 2008:10 ?
Thank you very much!
Re: How to convert a vect into a series?
You can do that with a SET instruction, but you need to use the T subscript (with a shift value) in referring to entries in the vector. It sounds as if you need:Jennylai wrote:Dear all,
Thank you very much
SET YT 2008:2 2008:10 = Y(T-2008:1)-
Jennylai
May I ask another question? If I have a series called ya in a program file prg1.r, and I want to use this ya together with other series yb which is in another program file prg2.r to graph some comparison figure, what should I do? How shall I proceed?
Use COPY to copy the data out of one of the program, then read it into the other.
Jennylai
Thank you very much for your generous help all the time! I've worked that out!
