Asymmetric ECM IRFs
TVolscho-286
Asymmetric ECM IRFs
I have tested for and found support for asymmetric cointegration between two variables using the Enders-Siklos procedure. The two variables are 1) a measure of income tax evasion and 2) a measure of IRS audit rates.
One thing that would be helpful is a plot that demonstrates the asymmetry in response to above and below threshold shocks.
I can put together the two regular ECM equations but what most readers like to see are IRFs.
Does anyone have sample code?
Re: Asymmetric ECM IRFs
http://www.estima.com/forum/viewtopic.php?f=8&t=2077 is an example of GIRF's in a similar type of model.
TVolscho-286
Thanks, I do have the handbook from the Switching course. So it looks like this example uses the Sweep command to find the threshold. I used the Enders/Siklos procedure to find the threshold and then I created to variables p1 (above threshold)) and p2 (below threshold).TomDoan wrote:http://www.estima.com/forum/viewtopic.php?f=8&t=2077 is an example of GIRF's in a similar type of model.
Where would I start? I am a bit daunted. And would more information help? Like if I gave you the asymmetric ECM equation results? None of the first differences were significant, just the below threshold ECT was highly significant indicating that tax evasion adjusts to negative shocks in the tax return audit rate.
Would I start here (since I already have the threshold for the ECT)?
dec frml[int] switch
frml switch = 1+fix((spread{1}>=lower)+(spread{1}>upper))
* Estimate the model at the best breaks to get the covariance matrix.
* SMS_5_2.RPF
* Switching Models and Structural Breaks
* Example 5.2
* Based upon Balke and Fomby(1997), "Threshold Cointegration,"
* International Economic Review, vol 38, no 3, 627-45.
* Data file is a reconstruction.
* This estimates the thresholds using the bivariate likelihood, computes
* an eventual forecast function and GIRF.
cal(m) 1955:1
open data irates.xls
data(format=xls,org=columns) 1955:01 1990:12 fedfunds mdiscrt
set spread = fedfunds-mdiscrt
set thresh = spread{1}
linreg spread
# constant spread{1 2}
@UniqueValues(values=tvalues) thresh %regstart() %regend()
compute n=%rows(tvalues)
compute pi=.15
compute spacing=fix(pi*n)
* These are the bottom and top of the permitted index values for the
* lower index, and the top of the permitted values for the upper index.
compute lstart=spacing,lend=n+1-2*spacing
compute uend =n+1-spacing
set dff = fedfunds-fedfunds{1}
set ddr = mdiscrt -mdiscrt{1}
sweep
# dff ddr
# constant dff{1} ddr{1} spread{1}
compute loglbest=%logl
do lindex=lstart,lend
do uindex=lindex+spacing,uend
sweep(group=(thresh>=tvalues(lindex))+(thresh>tvalues(uindex)))
# dff ddr
if %logl>loglbest
compute lindexbest=lindex,uindexbest=uindex,loglbest=%logl
end do uindex
end do lindex
disp "Best Break Values" tvalues(lindexbest) "and" tvalues(uindexbest)
compute lower=tvalues(lindexbest),upper=tvalues(uindexbest)
sweep(group=switch(t))
# dff ddr
compute tvecmsigma=%sigma
system(model=basevecm)
variables dff ddr
lags 1
det constant spread{1}
dec rect[frml] tvecfrml(2,3)
do i=1,3
estimate(smpl=(switch(t)==i))
frml(equation=%modeleqn(basevecm,1)) tvecfrml(1,i)
frml(equation=%modeleqn(basevecm,2)) tvecfrml(2,i)
frml(identity) ffid fedfunds = fedfunds{1}+dff
frml(identity) drid mdiscrt = mdiscrt{1}+ddr
frml(identity) spid spread = fedfunds-mdiscrt
frml dffeq dff = tvecfrml(1,switch(t))
frml ddreq ddr = tvecfrml(2,switch(t))
group tvecm dffeq ddreq ffid drid spid
* Eventual forecast function, starting with 1981:1 data (largest value
* of spread).
forecast(model=tvecm,from=1981:1,steps=40,results=eff)
graph(footer=$
"Eventual Forecast Function for SPREAD, starting at 1981:1")
# eff(5)
graph(footer=$
"Eventual Forecast Function for Change in DR, starting at 1981:1")
# eff(2)
* GIRF starting in 1969:3 for a one s.d. shock to DR correlated with FF
* using the estimated covariance matrix. (1969:3 has values for both
* rates which are close to the average for the full period).
compute ndraws=5000
compute baseentry=1969:3
compute nsteps =40
dec vect[series] fshocks(2) girf(5)
dec series[vect] bishocks
dec vect ishocks
smpl baseentry baseentry+(nsteps-1)
do i=1,5
set girf(i) = 0.0
compute fsigma=%psdfactor(tvecmsigma,||2,1||)
do draw=1,ndraws
gset bishocks = %ranmvnormal(fsigma)
set fshocks(1) = bishocks(t)(1)
set fshocks(2) = bishocks(t)(2)
forecast(paths,model=tvecm,results=basesims)
# fshocks
compute ishock=fsigma(2,2)
compute ishocks=inv(fsigma)*bishocks(baseentry)
compute ishocks(2)=ishock/fsigma(2,2)
compute bishocks(baseentry)=fsigma*ishocks
compute fshocks(1)(baseentry)=bishocks(baseentry)(1)
compute fshocks(2)(baseentry)=bishocks(baseentry)(2)
forecast(paths,model=tvecm,results=sims)
# fshocks
do i=1,5
set girf(i) = girf(i)+(sims(i)-basesims(i))
end do draw
do i=1,5
set girf(i) = girf(i)/ndraws
graph(footer=$
"GIRF for Discount Rate to One S.D. Shock in Discount Rate")
# girf(4)
graph(footer=$
"GIRF for FedFunds Rate to One S.D. Shock in Discount Rate")
# girf(3)
graph(footer=$
"GIRF for Spread to One S.D. Shock in Discount Rate")
# girf(5)Re: Asymmetric ECM IRFs
How does your model differ from this? Our example hasTVolscho-286 wrote:Thanks, I do have the handbook from the Switching course. So it looks like this example uses the Sweep command to find the threshold. I used the Enders/Siklos procedure to find the threshold and then I created to variables p1 (above threshold)) and p2 (below threshold).TomDoan wrote:http://www.estima.com/forum/viewtopic.php?f=8&t=2077 is an example of GIRF's in a similar type of model.
- known cointegrating vector (the spread)
- three-regime threshold model with arbitrary (and still to be estimated) upper and lower breakpoints
TVolscho-286
I have:
a) the residuals
b) the threshold value
Is this all I need?
I have:
a) the residuals
Is this all I need?
Not if you want IRF's. You need to be able to generate simulations of the data, since it's the levels of the data that determine the deviation from the threshold.TVolscho-286 wrote:Hi Tom,
I have:
a) the residuals
Is this all I need?
TVolscho-286
So I have:
a) the two original series
b) the residuals from cointegrating regression
c) the threshold value from Enders/Siklos
d) two variables I created p1 (above threshold residuals, 0) and p2 (below threshold residuals, 0)
I want to plot the IRF due to a one-unit shock that disturbs the long-run equilibrium.
So I have:
TVolscho-286
Here are the asymmetric ECMs
P1 = residuals if above or equal to threshold chosen by TAR, else = 0
P2 = residuals if below threshold chosen by TAR, else = 0
DTax Evasion = -.108 -.067*P1(T=.84) -.580*P2(t=3.77) + .310*D_Tax Evasion(t-1)(T=2.23) - .110*DAudit((t-1)T=0.63)
DCorpAudit = -.271 -.087*P1(t=1.12) -.090*P2(t=0.70) + .160*DTax Evasion(t=1.38) + .196*DAudit(t=1.35)
Thus, I want to model the response to P2 in the first equation. Assuming a steady-state equilibrium and applying standard deviation shock.
That being said, where would I need to start modifying the above code?
Thanks again for your help!
Would it be possible to modify the above code (or the Balke-Fomby code more generally) so as to estimate separate GIRFs for each regime?
That depends upon what you mean. It doesn't make sense to look at the response confined to just one regime as that's not how the model works. However, a GIRF depends upon initial conditions and there is no "generic" condition for being in one regime. In one of his other papers, Balke averaged the GIRF's across all the observations which fell into one regime. That's one way to define that, but far from the only one.Coribe wrote:Would it be possible to modify the above code (or the Balke-Fomby code more generally) so as to estimate separate GIRFs for each regime?
How is the threshold defined in terms of Tax Evasion and Audit? You need a model written entirely in terms of the two dependent variables.TVolscho-286 wrote:Here are the asymmetric ECMs
