Panel Data Operation
yngvi
Unread post by yngvi »
I have a panel of 11 individuals and 16 time periods, 1997-2012.
Problem 1:
Applying a division by a common time series variable for all individuals e.g. CPI.
The SET instruction doesn't seem to work as the common variable is interpreted as
belonging to individual 1.
I have come up with the following
compute nobs=176
declare vector[real] YD_r(nobs)
do i=0,nobs-16,16
  do j=1,16
    compute k=i+j
    compute YD_r(k) = YD(k)/CPI(j)*CPI(16)
* converting vector to panel data
set yd_rt 1//1997:1 11//2012:1 = yd_r(t-1//1997:1+1)
Question: Is there an easier/cleaner way to do this?
Problem 2: What is the most natural way of making up a panel of time differences?
It can be done within a double do loop structure similar as above, e.g.
declare vector[real] dYD_r(nobs-11)
do i=0,nobs-26,15
  do j=1,15
    compute k=i+j
    compute dYD_r(k) = log(YD_r(k+1)/YD_r(k))
However I have a problem converting the dYd_r vector back to time series relating as
set dYD_rt 1//1998:1 11//2012:1 = dYD_r(t-1//1998:1+i)
doesn't work. It seems to assume the time series element of the differenced panel
begins in 1997. I'm pretty sure that I'm overlooking something really simple.
Thanks, Yngvi
Re: Panel Data Operation
yngvi wrote:I have a panel of 11 individuals and 16 time periods, 1997-2012.
Problem 1:
compute nobs=176
do i=0,nobs-16,16
  do j=1,16
    compute k=i+j
Sounds like you want
set(nopanel) yd_r = yd/cpi(%period(t))*cpi(2012:1)
yngvi wrote: Problem 2: What is the most natural way of making up a panel of time differences?
do i=0,nobs-26,15
  do j=1,15
    compute k=i+j
If you're trying to do a forward difference,
set dyd_r = log(yd_r{-1}/yd_r)
That will be defined except for the final period for each individual.
yngvi
The solution to problem 1:
needed to be ammended as:
set(nopanel) yd_r 1//1997:1 11//2012:1 = yd/cpi(%period(t))*cpi(2012:1)
i.e. I needed to specify the sample range explicitly. The %period(t) was what I was looking for. I had already tried something similar.
As regards problem 2 then I wasn't looking for a forward difference I just wanted to populate the vector with no empty elements.
As in the case of problem 1 I needed to specify the sample range explicitly but within a do loop. I don't understand why I can't use a similar sample reference as I did for problem 1.
In any case the following works:
do i=1,11
set dYD_r i//1998:1 i//2012:1 = log(yd_r/yd_r{1})
I would like to understand why I need to reference the sample range in a different manner in problem 2 than in problem 1 if you can provide a comment on that.
yngvi wrote: As regards problem 2 then I wasn't looking for a forward difference I just wanted to populate the vector with no empty elements.
do i=1,11
How do you difference the data without losing data points?
If you're doing the standard backwards difference, you just need
set dYD_r = log(yd_r/yd_r{1})
The first element of each individual will be NA. With panel data, by default, an expression which spans two individuals (as this would at the first entry in an individual's record) will be NA. The NOPANEL option in the other case disables that, allowing the calculation to use data from the common series (CPI) which is in the first individual's record only.
yngvi
do i=1,11
1) I was not addressing the fact that you loose datapoints. I was addressing the issue that in my example the SET instruction doesn't run correctly without setting the sample explicitly on the instruction.
2) In comparing problems 1 and 2 I was referring to that I seem to need a do loop in the second problem while I can use the SET instruction for the full sample, including the individual references. I.e. 1//1998:1 11/2012:1 vs. i//1998:1 i//2012:1 within a do loop. I am puzzled by the need to set the sample in different manners for the two problems. I am not puzzled at all by loosing a datapoint - that goes without saying. :)
What's your ALLOCATE instruction or first DATA range? That sets the default length on a SET instruction. If you make the ALLOCATE instruction cover the full range of the panel data, then you won't have to do an explicit range later on.
yngvi
This is how I set it up. I never did a separate ALLOCATE for the panel.
cal(a) 1997:1
all 2012:1
open data Indices.xlsx
data(org=obs,format=xlsx) 1997:01 2012:01 CPI W
close data
cal(a,panelobs=16) 1997:1
open data Panel.rat
data(format=rats) 1//1997:1 11//2012:1 C YD TFER A
close data
Then I set the ranges on the individual SET instructions.
Thanks for the help.
yngvi
FYI then I added an ALLOCATE 11/2012:1 instruction.
I still seem to require to put a do loop around the differencing set instructions as per my earlier post.
It's a puzzle but I've got a working program.
BTW do you have any documentation on the MOVE instruction.
Many thanks again.
If you do the ALLOCATE for the panel range, you shouldn't have to loop over the individuals.
The syntax for MOVE is
move series start end newseries newstart
It doesn't look at panel boundaries, so just shifts data around between series and newseries.
