Identifying VARs with sign restrictions
Re: Identifying VARs with sign restrictions
What is it that you're trying to do? You've already created two shocks which must be satisfying sign restrictions. If you're trying to create a third shock which is orthogonal to the first two and satisfies your four equality constraints, it won't work. That's six constraints plus the length constraint. Even if you didn't have that problem, you need to do the equality constrained shock first since the calculation is based upon the shock being freely chosen from the original impulse vectors.
lhlee0506
Hi~
I tried to identify 3 shocks_Business cycle shock, monetary shock and government spending shock.
Government spending shock is taken as one year delayed shock.
I think I messed it up.
when I ran pure 3 shocks code modified from the previous post, I found one question that almost all error band of impulse response except those with sign restrictions include zero which imply "insignificant".
If I cut the sample periods, I have more variales which do not include zero, but I have the sawtooth shape of impulse responses.
Is there any tricks in dealing with data or sign restriction setting which I should notice?
Thanks for your great helps.
open data data0508.xls
calendar 1970 1 4
data(format=xls,org=columns) 1970:01 2008:03 lrgspen1 lrgspen lrntax lrtax lrgexp lrgrev lrgcon lrginv1 lrginv $
lrgdp lrhgdp1 lrhgdp pgdpch cpich rint int lrpcon lrpinv1 lrpinv lrim lres lpgdp lm2 lpgdpch lrint lint vlpgdpch vlrint $
lrwmf lahmf lepmf depo ffr lrbc lrbcl lrtexp lrtexpca lrtexpcu lrtexpsp lrtrev lrtrevca lrtrevcu lrtrevsp
system(model=varmodel)
variables lrgdp lrpcon lrgspen lrntax lrpinv1 lint lm2 lpgdp
lags 1 to 4
estimate(noprint)
dec vect[strings] vl(8)
compute vl=||'Real GDP','Private Consumption','Government Spending','Net Tax','Private Investment','Interest Rate','M2','GDP deflator'||
* n1 is the number of draws from the posterior of the VAR
* n2 is the number of draws from the unit sphere for each draw for the VAR
* nvar is the number of variables
* nstep is the number of IRF steps to compute
* KMAX is the "K" value for the number of steps constrained
compute n1=200
compute n2=200
compute nkeep=1000
compute nvar=8
compute nstep=40
compute KMAX=5
dec symm s(8,8)
dec vect v1(8) ;* For the unit vector on the 1st draw
dec vect v2(7) ;* For the unit vector on the 2nd draw
dec vect v3(6) ;* For the unit vector on the 3nd draw
dec vect v(8) ;* Working impulse vector
compute sxx =%decomp(%xx)
compute svt =%decomp(inv(%nobs*%sigma))
compute ncoef =%rows(sxx)
compute wishdof=%nobs-ncoef
dec rect ranc(ncoef,nvar)
* Most draws are going to get rejected. We allow for up to 1000
* good ones. The variable accept will count the number of accepted
* draws. GOODRESP will be a RECT(nsteps,nvar) at each accepted
* draw.
declare vect[rect] goodresp(nkeep) goodfevd(nkeep)
declare vect[rect] goodrespa(nkeep) goodfevda(nkeep)
declare vect[rect] goodrespb(nkeep) goodfevdb(nkeep)
compute ones=%const(1.0)
source forcedfactor.src
compute accept=0
infobox(action=define,progress,lower=1,upper=n1) 'Monte Carlo Integration'
do draws=1,n1
* responses.
compute sigmad =%ranwisharti(svt,wishdof)
compute p =%decomp(sigmad)
compute ranc =%ran(1.0)
compute betau =sxx*ranc*tr(p)
* This is changed to unit shocks rather than orthogonalized shocks.
impulse(noprint,model=varmodel,decomp=%identity(8),results=impulses,steps=nstep)
gset irfsquared 1 1 = %xt(impulses,t).^2
* orthogonal components.
do subdraws=1,n2
* First Set of Restrictions - Unique Impulse Vector
compute v1=%ran(1.0),v1=v1/sqrt(%normsqr(v1))
compute v=i1=p*v1
do k=1,KMAX+1
compute ik=%xt(impulses,k)*v
if ik(1)<0 .or. ik(2)<0 .or. ik(5)<0 .or. ik(4)<0
branch 105
end do k
* Meets the first restriction
* Draw from the orthogonal complement of i1 (last five columns of the
* factor "f").
compute v2=%ranmat(8,1) ;* Draw a random 8-vector
compute v2(1)=0.0 ;* Zero the 1st component
compute v2=v2/sqrt(%normsqr(v2)) ;* Normalize to unit length
compute v=i2=f*v2 ;* Transform to impulse vector
* Second Set of Restrictions - monetary Shock
do k=1,KMAX+1
if ik(6)<0 .or. ik(8)>0 .or.ik(7)>0
branch 105
end do k
* Meets the second restriction
* Draw from the orthogonal complement of i2 (last four columns of the
* factor "g").
@forcedfactor(force=column) sigmad i1~i2 f
compute v3=%ranmat(8,1) ;* Draw a random 8-vector
compute v3(1)=0.0 ;* Zero the 1st component
compute v3(2)=0.0 ;* Zero the 2nd component
compute v3=v3/sqrt(%normsqr(v3)) ;* Normalize to unit length
compute v=i3=f*v3 ;* Transform to impulse vector
* Third Set of Restrictions - Govt Spending Shock
do k=1,KMAX+1
if ik(3)<0
branch 105
end do k
* Meets Three restrictions
compute accept=accept+1
dim goodrespb(accept)(nstep,nvar) goodfevdb(accept)(nstep,nvar)
dim goodrespa(accept)(nstep,nvar) goodfevda(accept)(nstep,nvar)
dim goodresp(accept)(nstep,nvar) goodfevd(accept)(nstep,nvar)
ewise goodresp(accept)(i,j)=(ik=%xt(impulses,i)*i1),ik(j)
ewise goodfevd(accept)(i,j)=ik=(irfsquared(i)*(i1.^2))./(irfsquared(i)*ones),ik(j)
ewise goodrespa(accept)(i,j)=(ik=%xt(impulses,i)*i2),ik(j)
ewise goodfevda(accept)(i,j)=ik=(irfsquared(i)*(i2.^2))./(irfsquared(i)*ones),ik(j)
ewise goodrespb(accept)(i,j)=(ik=%xt(impulses,i)*i3),ik(j)
ewise goodfevdb(accept)(i,j)=ik=(irfsquared(i)*(i3.^2))./(irfsquared(i)*ones),ik(j)
if accept>=nkeep
break
:105
end do subdraws
if accept>=nkeep
break
infobox(current=draws)
end do draws
infobox(action=remove)
clear upper lower resp
spgraph(vfields=4,hfields=2,hlabel='Impulse Responses with Pure-Sign Approach',subhea='Business Cycle Shock')
do i=1,nvar
compute minlower=maxupper=0.0
smpl 1 accept
do k=1,nstep
set work = goodresp(t)(k,i)
compute lower(k)=frac(1)*100
compute upper(k)=frac(2)*100
compute resp(k)=%avg(work)*100
end do k
smpl 1 nstep
graph(pattern,ticks,number=0,picture='##.##',header='Impulse Responses for '+vl(i)) 3
# resp
# upper / 2
# lower / 2
spgraph(vfields=4,hfields=2,hlabel='Impulse Responses with Pure-Sign Approach',subhea='Monetary Shock')
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodrespa(t)(k,i)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
spgraph(vfields=4,hfields=2,hlabel='Impulse Responses with Pure-Sign Approach',subhea='Government Spending Shock')
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodrespb(t)(k,i)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
spgraph(vfields=4,hfields=2,hlabel='Fraction of Variance Explained with Pure-Sign Approach',subhea='Business cycle shock')
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodfevd(t)(k,i)
compute lower(k)=frac(1)*10000
compute upper(k)=frac(3)*10000
compute resp(k)=frac(2)*10000
end do k
smpl 1 nstep
graph(ticks,number=0,min=0.0,picture="##.##",header="Fraction Explained for "+vl(i)) 3
# resp
# upper / 2
# lower / 2
spgraph(vfields=4,hfields=2,hlabel='Fraction of Variance Explained with Pure-Sign Approach',subhea='Monetary shock')
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodfevda(t)(k,i)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
spgraph(vfields=4,hfields=2,hlabel='Fraction of Variance Explained with Pure-Sign Approach',subhea='Government Spending shock')
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodfevdb(t)(k,i)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
I'm not sure what you mean by "I found one question that almost all error band of impulse response except those with sign restrictions include zero". Are you saying that once you're past the end of the sign restrictions the responses no longer have the signs that you imposed on the shorter lags? That seems odd for a model with so many very persistent variables. You're not doing very many draws - you should probably see what happens when you increase that. Also, have you checked how easily the sub-draw procedure is getting a set of sign-restricted responses, that is, how many subdraws are typically needed in order to get a set which passes. If that's a high number, it may be an indication that the set of constraints is too rigid.lhlee0506 wrote:Hi~
lhlee0506
Hi~
I am sorry for my imprecise expression.
I mean after meeting three shocks and producing all impulse responses of every shock,
their error band (16% and 84% percentils) will include zero, especially those variables without sign restriction.
for example, the impulse response graph of real GDP, private consumption, private investment...etc of government spending shock , thier error band will include zero.
According to Sims and Zha, error band includes zero seems to imply "stastiscally insignificant".
I worry my estimation finally produce almost insigificant results.
Perhaps I miss some points at dealing with data or setting sign restriction or something else.
By the way, how do I check if I have enough sub-draws to pass?
Thank you for your kindness.
I am really appreciated.
Best
Best
You have to remember that your government spending shock is constructed to be orthogonal to your other two shocks, one of which was chosen to be positive on most of the real variables. It's certainly possible that isolated government spending shocks have no predictable effect on the other real variables. The lack of a "result" is a result.lhlee0506 wrote:Hi~
Best
Regarding the sub-draws, check your value of "draws" at the end of the loop. If that's fairly large (close to "n1"), you're not getting many good sub-draws.
lhlee0506
But why even though I identified only one government spending shock, the impulse responses of almost all variables also include zero?
Do the following to verify that you're getting the programming correct.lhlee0506 wrote:But why even though I identified only one government spending shock, the impulse responses of almost all variables also include zero?
1. Make sure you're getting enough acceptances. Do a DISP ACCEPT after the infobox(action=remove). If that isn't equal to your value of NKEEP, you need to increase the n1 and maybe n2 values.
2. If you're getting the right number of acceptances, do the following (again, after the infobox(action=remove))
@forcedfactor(force=column) sigmad i1~i2~i3 f
impulse(factor=f,steps=20,model=varmodel,print)If 1 is OK and 2 is OK, then your calculations are correct. If the responses of other variables to your government spending shock are insignificant, then, well, you have a topic for a paper.
dennis0125hk
Here's the code that I modified from this post. I also downloaded Forcefactor.src and installed it in WINRAT in order to run the program file.
However, when I attempt to run it by WINRATS 7.1, below error message keeps appearing
## CP17. PROCEDURE/FUNCTION Must be Initial Statement in a Compiled Section
>>>>procedure <<<<
## SX11. Identifier F is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>%xsubmat(f,1,6,2,6)<<<<
How could I solved the problem?
* Replication File for Uhlig (2005), "What are the effects of monetary policy on output?
* Results from an agnostic identification procedure." Journal of Monetary Economics, 52, pp
* 381-419. Pure sign restriction approach
open data uhligdata.xls
calendar 1965 1 12
data(format=xls,org=columns) 1965:01 2003:12 gdpc1 gdpdef cprindex totresns bognonbr fedfunds
set gdpc1 = log(gdpc1)*100.0
set gdpdef = log(gdpdef)*100.0
lags 1 to 12
estimate(noprint)
dec vect[strings] vl(6)
compute vl=||'real GDP','GDP price defl','Comm. Price Ind.','Fed Funds Rate','Nonborr. Reserv.','Total Reserves'||
compute n1=200
compute n2=200
compute nvar=6
compute nstep=60
compute KMAX=5
* draw.
declare vect[rect] goodresp(1000)
compute accept=0
do draws=1,n1
* responses.
compute swish =%decomp(sigmad)
compute betau =sxx*ranc*tr(swish)
impulse(noprint,model=varmodel,decomp=swish,results=impulses,steps=nstep)
do subdraws=1,n2
compute v=i1=swish*v1
do k=1,KMAX+1
if ik(4)<0.or.ik(6)<0.or.ik(2)>0.or.ik(5)>0
branch 105
end do k
* factor "f").
@forcedFactor(force=column) sigmad i1 f
compute v2=%ran(1.0),v2=v2/sqrt(%normsqr(v2))
compute v=i2=%xsubmat(f,1,6,2,6)*v2
* Second Set of Restrictions - Demand Shock
do k=1,KMAX+1
if ik(1)<0.or.ik(2)<0
branch 105
end do k
* Meets both restrictions
if accept>=1000
break
:105
end do subdraws
if accept>=1000
break
end do draws
spgraph(vfields=3,hfields=2,hlabel='Figure 6. Impulse Responses with Pure-Sign Approach')
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
smpl 1 nstep
graph(ticks,number=0,picture='##.##',header='Impulse Responses for '+vl(i)) 3
# resp
# upper / 2
# lower / 2
end(reset)
>>>>procedure <<<<
* ForcedFactor computes a factorization of an input NxN covariance matrix SIGMA
* which controls either
* (a) a column or block of columns in the factorization itself
* (b) a row or block of rows in the inverse of the factorization
* In the case (a), you provide an RxN matrix A. An RxR matrix PI is computed so
* that PI is upper triangular and A x PI makes up the first R columns in a matrix
* F that factors SIGMA (that is FF'=SIGMA). In particular, if R=1, then the first
* column of F is a scale multiple of A. Because of the structure of PI, if R>1,
* the first column of F is a scale multiple of the first column in A, the second
* column in F will be a linear combination of the first two columns of A, etc.
* In the case (b), you provide an NxR matrix A. An RxR matrix PI is computed so
* that PI is lower triangular and PI x A makes up the first R rows of the inverse
* of a matrix F that factors SIGMA. In particular, if R=1, the first row in F**-1
* is a scale multiple of A.
* This allows you to either force an orthogonalized component to hit the variables
* in a specific pattern (done by setting a column of the factorization), or to
* force that an orthogonalized component be formed from a particular linear
* combination of innovations (forces a row in the inverse). You set the one
* component, and ForcedFactor builds a factorization around it. With multiple
* input components, you can force the factorization to include linear
* combinations of your inputs.
* Syntax:
* @ForcedFactor( options ) sigma a f
* Parameters:
* sigma SYMMETRIC covariance matrix (input)
* a RECTANGULAR (or VECTOR) - one dimension should be the same as sigma (input)
* f RECTANGULAR - output factor of sigma
* Options:
* force=[row]/column indicates whether a scale of "a" is to be a row in the
* inverse or a column in the factorization itself.
* Examples:
* In a four variable system where the first two variables are two interest rates,
* @ForcedFactor sigma ||1.0,-1.0,0.0,0.0|| f1
* @ForcedFactor(force=column) sigma ||1.0,1.0,0.0,0.0|| f2
* f1 will be a factorization where the first orthogonal component is the
* (non-orthogonal) innovation in the difference between the rates. f2 will be a
* factorization where the first orthogonal component loads equally onto the two
* interest rates, and hits none of the other variables contemporaneously.
* Revision Schedule
* 09/02 Written by Estima
* 11/05 Revised to allow multiple rows or columns
* %SVDZeros picks out the "r" smallest elements in the vector v, returning a
* VECT[INT] with the subscripts. This is used to locate the zero singular values
* in a singular value decomposition.
function %SVDZeros v r
type vect[int] %SVDZeros
type vector v
type integer r
local vector ranks
local integer i j
compute ranks=%ranks(v)
dim %SVDZeros(r)
compute j=0
do i=1,%rows(v)
if ranks(i)<=r {
compute j=j+1
compute %SVDZeros(j)=i
procedure forcedFactor sigma a f
type symm sigma
type rect a
type rect *f
option choice force 1 row column
local integer n r
local rect vv w pi p ff fill
local symm pp
local vect[rect] ss
local vect[int] zeros
compute n=%rows(sigma)
compute r=%imin(%rows(a),%cols(a))
if %imax(%rows(a),%cols(a))<>n {
disp "@ForcedFactor sigma a f"
disp "A is dimension" %rows(a) "x" %cols(a)
disp "SIGMA " n "x" n
disp "One dimension of A must match SIGMA"
return
if force==2 {
compute p=inv(%decomp(sigma))
if %rows(a)==n
compute vv=p*a
else
compute vv=p*tr(a)
compute w=%blockglue(||vv,%zeros(n,n-r)||)
compute ss=%svdecomp(w)
compute zeros=%SVDZeros(ss(2),n-r)
compute pp=inv(tr(vv)*vv)
compute pi=%psdfactor(pp,%seq(r,1))
dim fill(n,n-r)
ewise fill(i,j)=ss(1)(i,zeros(j))
compute f=inv(p)*%blockglue(||vv*pi,fill||)
else {
compute p=%decomp(sigma)
if %cols(a)==n
compute vv=a*p
else
compute vv=tr(a)*p
compute w=%blockglue(||vv|%zeros(n-r,n)||)
compute pi=inv(%decomp(%outerxx(vv)))
dim fill(n-r,n)
ewise fill(i,j)=ss(3)(j,zeros(i))
compute ff=%blockglue(||pi*vv|fill||)
compute f=p*inv(ff)
MC128
Dear all,
I am thinking of including some exogenous variables (e.g. constant, dummies and more importantly, some stochastic variables) into Uhlig's sign restriction framwork. The problem that I have is how would the posterior distribution of Beta (the regression coefficients) and Sigma (the variance-covariance matrix) changed as a result. I know that Kadiyala and Karlsson (1997, p104) shows the general case of posterior distribution of normal-wishart priors in a model with exogenous variables but I am more concerned with the specific case of a weak (or flat) prior as in Uhlig (2005). So in my case, what should I input for the posterior distribution of Beta and Sigma?
Thanks for any comment!
MC128
MC128
You missed a few things in copying the earlier code. First, you need to do a source forcedfactor.src instruction outside the loop. That's what's causing your immediate problem. You're also missing the declarations for v1 and v2. You need (again outside the loop), dec vect v1(6) v2(5). After correcting those, you'll find that you get a very low yield on acceptances, so you'll probably have to greatly increase n1 and n2.dennis0125hk wrote:Here's the code that I modified from this post. I also downloaded Forcefactor.src and installed it in WINRAT in order to run the program file.
<<snipped>>
>>>>procedure <<<<
TL
I have been using the following code (two shocks) you kindly helped me.
In addition to impulse responses and variance decomposition, would it be possible to directly acquire the followings from this code?
1. The baseline series (in order to see the prediction errors (the deviation between the baseline and the actual series))
2. The contribution of each shock in explaining the deviation between the baseline and the actual series. That is, series of the baseline with the first shock and series of the baseline with the second shock.
Tim
Tim
OPEN DATA uhligdata.xls
CALENDAR 1965 1 12
compute missc=1.0e+32
data(format=xlS,org=columns) 1965:1 2003:12 gdpc1 gdpdef cprindex totresns bognonbr fedfunds
lags 1 to 6
deterministic constant
compute vl=||'Consumer Prices','Real GDP','Interest Rates',$
'Market Index Real Stock Prices','Financial Sector Index Real Stock Prices','Real Exchange Rates'||
compute n1=1000
compute n2=1000
compute nvar=6
compute nstep=60
compute KMAX=5
dec symm s(6,6)
dec vect v1(6) ;* For the unit vector on the 1st draw
dec vect v2(5) ;* For the unit vector on the 2nd draw
dec vect v(6) ;* Working impulse vector
* draw.
declare vect[rect] goodresp(1000) goodfevd(1000)
declare vect[rect] goodrespa(1000) goodfevda(1000)
compute accept=0
do draws=1,n1
* responses.
impulse(noprint,model=varmodel,decomp=p,results=impulses,steps=nstep)
do subdraws=1,n2
compute v1=%ransphere(6)
compute i1=p*v1
do k=1,KMAX+1
compute ik=%xt(impulses,k)*v1
if ik(1)>0.or.ik(2)>0.or.ik(3)<0.or.ik(6)>0
branch 105
end do k
* factor "f").
compute v2=%ransphere(5)
compute i2=%xsubmat(f,1,6,2,6)*v2
compute v2=inv(p)*i2
do k=1,KMAX+1
compute ik=%xt(impulses,k)*v2
if ik(1)<0.or.ik(2)<0.or.ik(3)<0.or.ik(6)<0
branch 105
end do k
ewise goodresp(accept)(i,j)=(ik=%xt(impulses,i)*v1),ik(j)
ewise goodfevd(accept)(i,j)=(ik=(irfsquared(i)*(v1.^2))./(irfsquared(i)*ones)),ik(j)
ewise goodrespa(accept)(i,j)=(ik=%xt(impulses,i)*v2),ik(j)
ewise goodfevda(accept)(i,j)=(ik=(irfsquared(i)*(v2.^2))./(irfsquared(i)*ones)),ik(j)
if accept>=1000
break
:105
end do subdraws
if accept>=1000
break
end do draws
spgraph(vfields=6,hfields=2,subhea='Monetary Policy Shocks and Exchange Rate Shocks, Thailand')
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
smpl 1 nstep
graph(pattern,ticks,number=0,picture='##.##',header=+vl(i)) 3
# resp
# upper / 2
# lower / 2
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smpl
spgraph(vfields=3,hfields=2,hlabel='Fraction of Variance Explained with Pure-Sign Approach',subhea='Subhea')
do i=1,nvar
smpl 1 accept
do k=1,nstep
display resp(k)
end do k
smpl 1 nstep
graph(pattern,ticks,number=0,min=0.0,picture="##.##",header="Fraction Explained for "+vl(i)) 3
# resp
# upper / 2
# lower / 2
smpl
spgraph(vfields=3,hfields=2,hlabel='SECOND Fraction of Variance Explained with Pure-Sign Approach',subhea='Subhea')
do i=1,nvar
smpl 1 accept
do k=1,nstep
display resp(k)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smpl-
This does the historical decomposition for the one shock model. It isn't that hard to modify it for two.
Code below corrected June 25, 2009
* Based upon Uhlig (2005), "What are the effects of monetary policy on output?
* Economics, 52, pp 381-419. Pure sign restriction approach.
* This does an historical decomposition of the data showing the cumulative effects
* of the monetary policy shocks. Note that this is not part of the paper.
calendar(m) 1965
lags 1 to 12
estimate(noprint)
compute vl=||"real GDP","GDP price defl","Comm. Price Ind.","Fed Funds Rate","Nonborr. Reserv.","Total Reserves"||
compute n1=200
compute n2=200
compute nkeep=1000
compute nvar=6
compute nstep=60
compute KMAX=5
compute hstart = 1998:1
compute hend = 2002:12
compute nhor = hend-hstart+1
dec vect[series] upaths(nvar) u(nvar) onesteps(nvar) base(nvar) baseplus(nvar)
clear upaths
* Most draws are going to get rejected. We allow for up to nkeep good ones. The
* variable accept will count the number of accepted draws. GOODRESP will be a
* RECT(nsteps,nvar) at each accepted draw.
declare vector ik a ones(nvar)
declare vector hk(nvar)
declare vect[rect] goodhist(nkeep)
compute accept=0
infobox(action=define,progress,lower=1,upper=n1) "Monte Carlo Integration"
do draws=1,n1
* responses.
compute betau =%ranmvkron(swish,sxx)
* Use static forecasts over the period for historical decomposition to get the
* residuals. Use dynamic forecasts over the same period to get the base forecast
* series for the historical decomposition.
forecast(model=varmodel,from=hstart,to=hend,errors=u,static)
forecast(model=varmodel,from=hstart,to=hend,results=base)
do subdraws=1,n2
compute a=%ransphere(nvar)
* Check that the responses have the correct signs for steps 1 to KMAX+1
* (+1 because in the paper, the steps used 0-based subscripts, rather than
* the 1 based subscripts used by RATS).
do k=1,KMAX+1
compute ik=%xt(impulses,k)*a
if ik(4)<0.or.ik(3)>0.or.ik(2)>0.or.ik(5)>0
branch 105
end do k
* This is an accepted draw. Copy the information out. If we have enough
* good ones, drop out of the overall loop.
ewise goodresp(accept)(i,j)=ik=%xt(impulses,i)*a,ik(j)
ewise goodfevd(accept)(i,j)=ik=(irfsquared(i)*(a.^2))./(irfsquared(i)*ones),ik(j)
* Compute the historical paths of shocks to the system corresponding to the
* <<a>> weights on the Choleski factor.
dim goodhist(accept)(nhor,nvar)
compute remap=swish*a*tr(a)*inv(swish)
do t=hstart,hend
compute %pt(upaths,t,remap*%xt(u,t))
end do t
* Forecast over the decomposition period with those added shocks
forecast(model=varmodel,from=hstart,to=hend,results=baseplus,paths)
# upaths
* Save the difference between the forecasts with and without and added shocks
* (and shift them into the slots 1,...,nhor) of <<goodhist>>.
ewise goodhist(accept)(i,j)=baseplus(j)(i+hstart-1)-base(j)(i+hstart-1)
if accept>=nkeep
break
:105
end do subdraws
if accept>=nkeep
break
end do draws
spgraph(vfields=3,hfields=2,hlabel="Figure 6. Impulse Responses with Pure-Sign Approach")
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
smpl 1 nstep
graph(ticks,number=0,picture="##.##",header="Impulse Responses for "+vl(i)) 3
# resp
# upper / 2
# lower / 2
spgraph(vfields=3,hfields=2,hlabel="Figure 8. Fraction of Variance Explained with Pure-Sign Approach")
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
declare series upperH lowerH respH
spgraph(vfields=3,hfields=2,hlabel="Figure X. Historical Decomposition with Pure-Sign Approach")
do i=1,nvar
smpl 1 accept
clear upperH lowerH respH
do k=hstart,hend
set work 1 accept = goodhist(t)(k-hstart+1,i)
compute lowerH(k)=frac(1)
compute upperH(k)=frac(3)
compute respH(k)=frac(2)
end do k
* compute maxupper=%max(maxupper,%maxvalue(upper)) ,min=minlower,max=maxupper
* compute minlower=%min(minlower,%minvalue(lower))
display 'contributions to variable' +vl(i)
do h=1,nhor
display respH(h)
end do h
smpl hstart hend
graph(ticks,dates,picture="##.##",header="Contribution of Monetary Policy shock to "+vl(i)) 3
# respH hstart hend
# upperH / 2
# lowerH / 2
spgraph(done)-
TL
I have modified the code for two shocks. Nevertheless, results do not appear. I might do something wrong. Could you please give me some suggestions?
Tim
Tim
CALENDAR 1965 1 12
lags 1 to 6
compute n1=1000
compute n2=1000
compute nvar=6
compute nstep=60
compute KMAX=5
compute hstart = 1995:1
compute hend = 2003:12
clear upaths
dec symm s(6,6)
* draw.
declare vect[rect] goodhist(1000) goodhista(1000)
compute accept=0
do draws=1,n1
* responses.
forecast(model=varmodel,from=hstart,to=hend,results=onesteps,errors=u,static)
do subdraws=1,n2
compute i1=p*v1
do k=1,KMAX+1
branch 105
end do k
* factor "f").
do k=1,KMAX+1
branch 105
end do k
dim goodhist(accept)(nhor,nvar) goodhista(accept)(nhor,nvar)
do t=hstart,hend
compute %pt(upaths,t,p*(a.*(inv(p)*%xt(u,t))))
end do t
# upaths
ewise goodhista(accept)(i,j)=baseplus(j)(i+hstart-1)-base(j)(i+hstart-1)
if accept>=1000
break
:105
end do subdraws
if accept>=1000
break
end do draws
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smpl
do i=1,nvar
smpl 1 accept
do k=1,nstep
display resp(k)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smpl
do i=1,nvar
smpl 1 accept
do k=1,nstep
display resp(k)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smpl
do i=1,nvar
smpl 1 accept
do k=hstart,hend
end do k
do h=1,nhor
display respH(h)
end do h
smpl hstart hend
graph(ticks,dates,picture="##.##",header="Contribution of Monetary Policy shocks to "+vl(i)) 3
# respH hstart hend
# upperH / 2
# lowerH / 2
smpl
do i=1,nvar
smpl 1 accept
do k=hstart,hend
set work 1 accept = goodhista(t)(k-hstart+1,i)
end do k
do h=1,nhor
display respH(h)
end do h
smpl hstart hend
graph(ticks,dates,picture="##.##",header="Contribution of Exchange Rate shocks to "+vl(i)) 3
# respH hstart hend
# upperH / 2
# lowerH / 2
spgraph(done)-
do t=hstart,hend
end do t
TL
Thank you very much for your suggestions. I believe that I have successfully modified the code for two shocks. Could you please give me some feedbacks whether my code is correct?
Tim
Tim
CALENDAR 1965 1 12
lags 1 to 6
compute n1=1000
compute n2=1000
compute nvar=6
compute nstep=60
compute KMAX=5
dec vect[series] upathsa(nvar) ua(nvar) onestepsa(nvar) basea(nvar) baseplusa(nvar)
clear upaths
clear upathsa
dec symm s(6,6)
* draw.
compute accept=0
do draws=1,n1
* responses.
forecast(model=varmodel,from=hstart,to=hend,results=onestepsa,errors=ua,static)
forecast(model=varmodel,from=hstart,to=hend,results=basea)
do subdraws=1,n2
compute i1=p*v1
do k=1,KMAX+1
branch 105
end do k
* factor "f").
do k=1,KMAX+1
branch 105
end do k
do t=hstart,hend
compute %pt(upaths,t,p*(i1.*(inv(p)*%xt(u,t))))
end do t
do t=hstart,hend
compute %pt(upathsa,t,p*(i2.*(inv(p)*%xt(ua,t))))
end do t
# upaths
forecast(model=varmodel,from=hstart,to=hend,results=baseplusa,paths)
# upathsa
ewise goodhista(accept)(i,j)=baseplusa(j)(i+hstart-1)-basea(j)(i+hstart-1)
if accept>=1000
break
:105
end do subdraws
if accept>=1000
break
end do draws
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smpl
do i=1,nvar
smpl 1 accept
do k=1,nstep
display resp(k)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smpl
do i=1,nvar
smpl 1 accept
do k=1,nstep
display resp(k)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smpl
do i=1,nvar
smpl 1 accept
do k=hstart,hend
end do k
do h=1,nhor
display respH(h)
end do h
smpl hstart hend
graph(pattern,ticks,dates,picture="##.##",header="Contribution of Monetary Policy shocks to "+vl(i)) 3
# respH hstart hend
# upperH / 2
# lowerH / 2
smpl
do i=1,nvar
smpl 1 accept
do k=hstart,hend
end do k
do h=1,nhor
display respH(h)
end do h
smpl hstart hend
graph(pattern,ticks,dates,picture="##.##",header="Contribution of Exchange Rate shocks to "+vl(i)) 3
# respH hstart hend
# upperH / 2
# lowerH / 2
