Identifying VARs with sign restrictions
fabio fornari
will see how it works with three shocks before moving on ... needs really lots of draws to get acceptances ...
will let you know
thanks f
Did anyone try to extend Uhilg_3 file for the paper published (2005) with penalty function to more than 6 variables? can anyone tell me how the penalty is going to change in this case?
Thanks for help
This uses an alternative and more flexible parameterization of the unit sphere than was used by Uhlig. (Note that it's really the parameterization that needs to change; the calculation of the penalty function is similar regardless). I didn't use it in the original uhlig3.prg because the %stereo function was added with version 6.35 of RATS. There are quite a few ways to parameterize the unit sphere. The stereoscopic projection used in the %stereo function takes the N-1 vector x and maps it to the N-vector formed bymmk wrote:Hi
Thanks for help
y(i)=2x(i)/(||x||^2+1)
y(N)=(||x||^2-1)/(||x||^2+1)
All such mappings have at least one minor flaw. In this case, the only way to make y(N)=0 is to make the x's very large. (Uhlig's mapping has the problem of non-uniqueness, as well as being rather difficult to generalize easily).
* Replication File for Uhlig(2005), "What are the effects of monetary policy on
* output? Results from an agnostic identification procedure," Journal of Monetary
* Economics, 52, pp 381-419. Penalty function approach.
open data uhligdata.xls
calendar(m) 1965
data(format=xls,org=columns) 1965:1 2003:12 gdpc1 gdpdef cprindex totresns bognonbr fedfunds
set gdpc1 = log(gdpc1)*100.0
set gdpdef = log(gdpdef)*100.0
system(model=varmodel)
lags 1 to 12
estimate(noprint)
dec vect[strings] vl(6)
compute vl=||"real GDP","GDP price defl","Comm. Price Ind.",$
"Fed Funds Rate","Nonborr. Reserv.","Total Reserves"||
* Get the scale factors to be used for impulse responses
dec vect scales(6)
dec real func
compute fill=0
dofor i = gdpc1 gdpdef cprindex fedfunds bognonbr totresns
diff i / diff1
stats(noprint) diff1
compute fill=fill+1,scales(fill)=sqrt(%variance)
end dofor i
* ndraws is the desired number of draws from the posterior of the VAR
* nvar is the number of variables
* nstep is the number of IRF steps to compute
* KMAX is the "K" value for the number of steps constrained
compute ndraws=1000
compute nvar=6
compute nstep=60
compute KMAX=5
declare vect[rect] goodresp(ndraws)
declare vector ik a(nvar)
dec vect g(nvar-1)
compute g=%fill(nvar-1,1,1.0)
nonlin g
compute sxx =%decomp(%xx)
compute svt =%decomp(inv(%nobs*%sigma))
compute ncoef =%rows(sxx)
compute wishdof=%nobs-ncoef
dec rect ranc(ncoef,nvar)
infobox(action=define,progress,lower=1,upper=ndraws) "Monte Carlo Integration"
* Plan for double the number of draws to allow for the ones which we
* reject.
compute accept=0
do draws=1,ndraws*2
* responses.
compute sigmad =%ranwisharti(svt,wishdof)
compute swish =%decomp(sigmad)
compute ranc =%ran(1.0)
compute betau =sxx*ranc*tr(swish)
impulse(noprint,model=varmodel,decomp=swish,results=impulses,steps=nstep)
* Minimize the penalty function, starting from the last set of minimizers
find(noprint) min func
compute a=%stereo(g)
compute func=0.0
do k=1,KMAX+1
compute ik=(%xt(impulses,k)*a)./scales
compute func=func+%if(ik(4)>0,-ik(4),-100*ik(4))+$
%if(ik(3)<0,ik(3),100*ik(3))+$
%if(ik(2)<0,ik(2),100*ik(2))+$
%if(ik(5)<0,ik(5),100*ik(5))
end do k
end find
compute testfunc=func,testbeta=%beta
* Try the minimization again, starting from a standard set of values
compute func=0.0
do k=1,KMAX+1
end do k
end find
* If the two estimates don't match, reject the draw. If they do, copy out the
* impulse responses.
if abs(testfunc-func)<.01 {
compute accept=accept+1
dim goodresp(accept)(nstep,nvar)
ewise goodresp(accept)(i,j)=ik=%xt(impulses,i)*a,ik(j)
* If we've hit out desired number of accepted draws, break
if accept>=ndraws
break
infobox(current=accept)
end do draws
infobox(action=remove)
* Post-processing. Graph the mean of the responses along with the 16% and 84%-iles
clear upper lower resp
spgraph(vfields=3,hfields=2,hlabel="Figure 14. Impulse Responses with Penalty Function Approach")
do i=1,nvar
compute minlower=maxupper=0.0
smpl 1 accept
do k=1,nstep
set work = goodresp(t)(k,i)
compute lower(k)=frac(1)
compute upper(k)=frac(2)
compute resp(k)=%avg(work)
end do k
smpl 1 nstep
graph(ticks,number=0,picture="##.##",header="Impulse Responses for "+vl(i)) 3
# resp
# upper / 2
# lower / 2
Would please you kindly instruct me how to collect the value of the initial demand/monetary shock and how to show the variance of decomposition?
I tried to put the variance decomposition in the previous code with 2 shocks you posted few weeks ago.
and I got message as following,
## SX22. Expected Type REAL, Got MATRIX(REAL) Instead
>>>>%xt(impulses,t).^2<<<<
Would you kindly instruct me how to fix it?
Thank you very much!
DEC SERIES[RECT] irfsquaredRe: Identifying VARs with sign restrictions
I tried to follow up your instruction in the latest RATS letter which demonstrateds the impact responses on variables 1 and 2 to be equal. But I failed. Perhaps I misunderstood your instruction.
If you could give me some guidances, I will be very appreciated.
* Replication File for Uhlig (2005), "What are the effects of monetary policy on output?
* Results from an agnostic identification procedure." Journal of Monetary Economics, 52, pp
* 381-419. Pure sign restriction approach
open data levelsa1.xls
calendar 1970 1 4
data(format=xls,org=columns) 1970:01 2008:03 lrgspen1 lrntax lrgdp pgdpch rint lrpcon lrpinv
variables lrgspen1 lrntax lrgdp pgdpch rint lrpcon
lags 1 to 4
estimate(noprint)
compute vl=||'Govt spending','net tax','real gdp','GDP deflator','real interest rate','Private onsumption'||
* n1 is the number of draws from the posterior of the VAR
* n2 is the number of draws from the unit sphere for each draw for the VAR
compute n1=200
compute n2=200
compute nvar=6
compute nstep=60
compute KMAX=5
* Most draws are going to get rejected. We allow for up to 1000
* good ones. The variable accept will count the number of accepted
* draws. GOODRESP will be a RECT(nsteps,nvar) at each accepted
* draw.
declare vect[rect] goodresp(1000)
compute accept=0
infobox(action=define,progress,lower=1,upper=n1) 'Monte Carlo Integration'
do draws=1,n1
* responses.
* Do the subdraws over the unit sphere. These give the weights on the
* orthogonal components.
do subdraws=1,n2
compute rperp=$%perp(||1.0,-1.0,0.0,0.0,0.0,0.0||*swish)
compute a=rperp*%ranmat(5,1),a=a/sqrt(%normsqr(a))
* Check that the responses have the correct signs for steps 1 to KMAX+1
* (+1 because in the paper, the steps used 0-based subscripts, rather than
* the 1 based subscripts used by RATS).
do k=1,KMAX+1
compute ik=%xt(impulses,k)*a
if ik(1)<0
branch 105
end do k
* This is an accepted draw. Copy the information out. If we have our 1000
* good ones, drop out of the overall loop.
if accept>=1000
break
:105
end do subdraws
if accept>=1000
break
infobox(current=draws)
end do draws
spgraph(vfields=3,hfields=2,hlabel='Figure 6. Impulse Responses with Pure-Sign Approach',subhea='monetary Shock')
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
smpl 1 nstep
graph(ticks,number=0,picture='##.##',header='Impulse Responses for '+vl(i)) 3
# resp
# upper / 2
# lower / 2
The line I isolated has been garbled. (Probably didn't fit in one column in the newsletter). Get rid of the $ and it should be fine.lhlee0506 wrote:Hello,
Thank you for your instruction.
After removing $, the code seems to wotk.
But I am still confused about how to set up the sign restriction after putting variable1,2 to be equal.
This modification seems only make variable 1,2 to be equal for one period, how to make it last for four periods?
Hope to have your kind responses.
Thanks a lot!
calendar 1970 1 4
lags 1 to 4
estimate(noprint)
compute n1=200
compute n2=200
compute nvar=6
compute nstep=60
compute KMAX=5
* draw.
compute accept=0
do draws=1,n1
* responses.
do subdraws=1,n2
compute rperp=%perp(||1.0,-1.0,0.0,0.0,0.0,0.0||*swish)
do k=1,KMAX+1
if ik(1)<0
branch 105
end do k
if accept>=1000
break
:105
end do subdraws
if accept>=1000
break
end do draws
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
I use code for two shocks from the forum. In addition to the impulse responses, I would like to see how much of the variation is accounted for by the first shock and by the second shock (variance decomposition).
I am not quite sure whether fraction explained (variance decomposition) is correct. Could you please give me some suggestions and feedbacks whether my code is correct?
Tim
OPEN DATA uhligdata.xls
CALENDAR 1965 1 12
compute missc=1.0e+32
data(format=xlS,org=columns) 1965:1 2003:12 gdpc1 gdpdef cprindex totresns bognonbr fedfunds
lags 1 to 12
estimate(noprint,resid=resids)
compute vl=||'real GDP','GDP price defl','Comm. Price Ind.',$
'Fed Funds Rate','Nonborr. Reserv.','Total Reserves'||
compute n1=4000
compute n2=4000
compute nvar=6
compute nstep=60
compute KMAX=5
dec symm s(6,6)
dec vect v1(6) ;* For the unit vector on the 1st draw
dec vect v2(5) ;* For the unit vector on the 2nd draw
dec vect v(6) ;* Working impulse vector
* draw.
declare vect[rect] goodresp(1000) goodfevd(1000)
declare vect[rect] goodrespa(1000) goodfevda(1000)
compute ones=%const(1.0)
source forcedfactor.src
compute accept=0
do draws=1,n1
* responses.
compute p =%decomp(sigmad)
compute betau =sxx*ranc*tr(p)
* This is changed to unit shocks rather than orthogonalized shocks.
impulse(noprint,model=varmodel,decomp=%identity(6),results=impulses,steps=nstep)
gset irfsquared 1 1 = %xt(impulses,t).^2
do subdraws=1,n2
* First Set of Restrictions - Unique Impulse Vector
compute v1=%ran(1.0),v1=v1/sqrt(%normsqr(v1))
compute v=i1=p*v1
do k=1,KMAX+1
compute ik=%xt(impulses,k)*v
if ik(1)>0.or.ik(2)>0.or.ik(3)<0.or.ik(6)>0
branch 105
end do k
* Meets the first restriction
* Draw from the orthogonal complement of i1 (last five columns of the
* factor "f").
compute v2=%ran(1.0),v2=v2/sqrt(%normsqr(v2))
compute v=i2=%xsubmat(f,1,6,2,6)*v2
* Second Set of Restrictions - Demand Shock
do k=1,KMAX+1
if ik(1)<0.or.ik(2)<0.or.ik(3)<0.or.ik(6)<0
branch 105
end do k
* Meets both restrictions
dim goodrespa(accept)(nstep,nvar) goodfevda(accept)(nstep,nvar)
dim goodresp(accept)(nstep,nvar) goodfevd(accept)(nstep,nvar)
ewise goodresp(accept)(i,j)=(ik=%xt(impulses,i)*i1),ik(j)
ewise goodfevd(accept)(i,j)=(ik=(irfsquared(i)*(i1.^2))./(irfsquared(i)*ones)),ik(j)
ewise goodrespa(accept)(i,j)=(ik=%xt(impulses,i)*i2),ik(j)
ewise goodfevda(accept)(i,j)=(ik=(irfsquared(i)*(i2.^2))./(irfsquared(i)*ones)),ik(j)
if accept>=1000
break
:105
end do subdraws
if accept>=1000
break
end do draws
spgraph(vfields=3,hfields=2,hlabel='Impulse Responses with Pure-Sign Approach',subhea='Subhea')
do i=1,nvar
smpl 1 accept
do k=1,nstep
display resp(k)
end do k
smpl 1 nstep
graph(pattern,ticks,number=0,picture='##.##',header='Impulse Responses for '+vl(i)) 3
# resp
# upper / 2
# lower / 2
smpl
spgraph(vfields=3,hfields=2,hlabel='SECOND Impulse Responses with Pure-Sign Approach',subhea='Subhea')
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodrespa(t)(k,i)
display resp(k)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smpl
spgraph(vfields=3,hfields=2,hlabel='Fraction of Variance Explained with Pure-Sign Approach',subhea='Subhea')
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodfevd(t)(k,i)
compute frac=%fractiles(work,||.16,.50,.84||)
compute upper(k)=frac(3)
compute resp(k)=frac(2)
display resp(k)
end do k
smpl 1 nstep
graph(pattern,ticks,number=0,min=0.0,picture="##.##",header="Fraction Explained for "+vl(i)) 3
# resp
# upper / 2
# lower / 2
smpl
spgraph(vfields=3,hfields=2,hlabel='SECOND Fraction of Variance Explained with Pure-Sign Approach',subhea='Subhea')
do i=1,nvar
smpl 1 accept
do k=1,nstep
set work = goodfevda(t)(k,i)
display resp(k)
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smplRe: Identifying VARs with sign restrictions
This (the alpha weights on the "swish" matrix) will create responses for the first two variables which are equal to each other for the first four periods. Note that this severely restricts the possible shocks, so it may be difficult for the draws for shocks to satisfy any other constraints.lhlee0506 wrote:Hi~
Thanks a lot!
compute step0=%xt(impulses,1)
compute step1=%xt(impulses,2)
compute step2=%xt(impulses,3)
compute step3=%xt(impulses,4)
dec rect r(4,6)
compute %psubmat(r,1,1,||1.0,-1.0,0.0,0.0,0.0,0.0||*step0)
compute %psubmat(r,2,1,||1.0,-1.0,0.0,0.0,0.0,0.0||*step1)
compute %psubmat(r,3,1,||1.0,-1.0,0.0,0.0,0.0,0.0||*step2)
compute %psubmat(r,4,1,||1.0,-1.0,0.0,0.0,0.0,0.0||*step3)
compute rfperp=%perp(r)
compute alpha=rfperp*%ranmat(%cols(rfperp),1)
compute alpha=alpha/sqrt(%normsqr(alpha))Re: Identifying VARs with sign restrictions
That won't work without changing the way the impulse responses are computed. In the original Uhlig code, the impulse response and squares are computed by:TL wrote:Dear Tom,
Tim
gset irfsquared 2 nstep = irfsquared{1}+%xt(impulses,t).^2The shocks are computed using a factorization of the covariance matrix (decomp=swish). Because the shocks are orthogonal (across time by assumption, across variables by construction), the sums of squared impulse responses (in IRFSQUARED) provide all the information needed for computing the decomposition of variance. To get the variance produced by impulse vector swish * a (where ||a||=1) you just need the sum over j of irfsquared(i,j)*a(j)^2, which is what (irfsquared(i)*(a.^2)) is computing in:
ewise goodfevd(accept)(i,j)=ik=(irfsquared(i)*(a.^2))./(irfsquared(i)*ones),ik(j)The code we wrote for doing multiple sign-restricted shocks uses:
impulse(noprint,model=varmodel,decomp=%identity(nvar),results=impulses,steps=nstep)Code: Select all
gset irfsquared 2 nstep = irfsquared{1}+%xt(impulses,t).^2should have a big red X through it - the numbers produced are of almost no value; there are a whole bunch of non-zero covariances which this doesn't compute.
The solution to this is to return to the original base set of impulse responses, then back out the weights based upon those. That's really easy for the first one, since it just restores the original code:
compute v1=%ransphere(6)
compute i1=p*v1
do k=1,KMAX+1
compute ik=%xt(impulses,k)*v1
branch 105
end do kCode: Select all
compute v2=%ransphere(5)
compute i2=%xsubmat(f,1,6,2,6)*v2
compute v2=inv(p)*i2
do k=1,KMAX+1
compute ik=%xt(impulses,k)*v2
branch 105
end do kv1 and v2 are the two weight vectors on the "SWISH" factored draws. The FEVD's are computed with:
ewise goodfevd(accept)(i,j)=(ik=(irfsquared(i)*(v1.^2))./(irfsquared(i)*ones)),ik(j)
ewise goodfevda(accept)(i,j)=(ik=(irfsquared(i)*(v2.^2))./(irfsquared(i)*ones)),ik(j)Code: Select all
CALENDAR 1965 1 12
lags 1 to 12
compute n1=1000
compute n2=1000
compute nvar=6
compute nstep=60
compute KMAX=5
dec symm s(6,6)
* draw.
compute accept=0
do draws=1,n1
* responses.
impulse(noprint,model=varmodel,decomp=p,results=impulses,steps=nstep)
do subdraws=1,n2
compute i1=p*v1
do k=1,KMAX+1
branch 105
end do k
* factor "f").
do k=1,KMAX+1
branch 105
end do k
ewise goodresp(accept)(i,j)=(ik=%xt(impulses,i)*v1),ik(j)
ewise goodrespa(accept)(i,j)=(ik=%xt(impulses,i)*v2),ik(j)
if accept>=1000
break
:105
end do subdraws
if accept>=1000
break
end do draws
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smpl
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smpl
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
smpl
do i=1,nvar
smpl 1 accept
do k=1,nstep
end do k
smpl 1 nstep
# resp
# upper / 2
# lower / 2
One problem which I am always confused about is what is the rule to set up sign restriction.
say, if we would like to disscuss positive government spending shock and it is put as the variable 1,
then we restric ik(1)<0 in the loop.
Is it correct?
Thank you for your kind instruction.
I tried to apply your code into year delayed postivative shock for 4 periods, and it works.
I also tried to extend it to 3shocks case, but I think I could get wrong with something.
If I could have your guidance, it will ber very helpful.
@forcedfactor(force=column) sigmad i1~i2 f
dec rect v3(4,6)
compute %psubmat(v3,1,1,||0.0,1.0,0.0,0.0,0.0,0.0||*step0)
compute %psubmat(v3,2,1,||0.0,1.0,0.0,0.0,0.0,0.0||*step1)
compute %psubmat(v3,3,1,||0.0,1.0,0.0,0.0,0.0,0.0||*step2)
compute %psubmat(v3,4,1,||0.0,1.0,0.0,0.0,0.0,0.0||*step3)
compute rfperp=%perp(V3)
compute v3=rfperp*%ranmat(%cols(rfperp),1)
compute v3=v3/sqrt(%normsqr(v3))
compute v=i3=f*v3
