GIBBSPROBITDYNAMIC.RPF estimates using Bayesian methods a probit model with the latent index variable assumed to follow an AR(1) process. This uses the typical Gibbs sampling technique of drawing the continuous latent variable given the observable 0-1's, but, because of the dynamic process for the latent variable, you can't just draw those independently. Instead, the YSTAR are done one-at-a-time given the values of the YSTAR at all other data points.
Detailed Description
GIBBSPROBITDYNAMIC—Gibbs Sampling for Dynamic Probit
Last bumped by TomDoan on Sun Sep 08, 2024 10:04 am.
