how to specify random walk with ARMA(2,2)
hardmann
Dear Tom:
In calssical Clark(1987) model, (1) Yt=Tt+Ct, (2) Tt=Tt-1 + dt-1 + nt, (3) dt= dt-1 + ut, (4) PHI(L)Ct = et. Clark said this model can not be identified if depentence of int and et.
In Morrly Nelson Zvoit(2003), they just estimated UC-AR(2) rather than UC-AEMA(2,2).
Can we delete eq(3) in Clark model, and extend PHI(L) Ct to ARMA(2,2) to setup typically UC model as follows:
UC model with arma(2,2): (i) Yt=Tt+Ct, (ii) Tt=Tt-1 + u + nt, (iii) Ct - phi1*Ct-1 - phi2*Ct-2 = et + theta1*et-1 + theta2*et-2
how to specify it. I dont know thether model can be identified if independence between nt and et.
Hardmann
Hardmann
Re: how t specify random walk with ARMA(2,2)
You might want to look at:
http://faculty.washington.edu/ezivot/re ... 162006.pdf
which extends the MNZ analysis to Clark's double drift model. The use of an ARMA rather than AR for the cycle shouldn't be of real consequence. However, an ARMA(2,2) for the cycle is likely to be overparameterized.
hardmann
Re: how to specify random walk with ARMA(2,2)
Dear Tom:
I had read this paper that estimate double drifts. I also had read another paper "The Clark Model with Correlated Components," with Kum Hwa Oh. January, which estimate UC-ARMA(2,1) with Correlated Components
I slightly modefied MZN's UC-AR(2) to UC-ARMA(2,1) based on previous paper. I modified af,zf,f matrics.
However, I encounter problem. "## MAT6. Trying to Store 2 x 2 Matrix Into VECTOR "
I do not know which is 2 x 2 Matrix. When I estimate UC-arma(2,1) even Uc-arma(2,2) without correlated components, estimation are rightly worked but coef. of MA insignificent.
Regards
Hardmann
open data lgdp.txt
calendar(q) 1947
data(format=free,org=columns) 1947:01 1998:02 lgdp
set lgdp = 100.0*lgdp
* UC-Ur decomposition with ARMA(2,1) cycle, fixed trend rate.
nonlin mu sn ph1 ph2 th1 se rho
dec frml[rect] af
dec frml[vect] zf
dec frml[symm] swf
frml af = ||1.0,0.0,0.0,0.0|$
0.0,ph1,ph2,th1|$
0.0,1.0,0.0,0.0|$
0.0,0.0,0.0,0.0||
frml zf = ||mu,0.0,0.0,0.0||
frml swf = %diag(||sn^2|rho*sn*se,se^2||)
compute [vect] c=||1.0,1.0,0.0,0.0||
compute [rect] f=||1.0,0.0|$
0.0,1.0|$
0.0,0.0|$
0.0,1.0||
* Get initial guess values
filter(type=hp) lgdp / gdp_hp
set gap_hp = lgdp - gdp_hp
linreg gap_hp
# gap_hp{1 2}
compute ph1=%beta(1),ph2=%beta(2),se=sqrt(%seesq)
set trend = t
linreg gdp_hp
# constant trend
compute mu=%beta(2)
compute sn=sqrt(.1*%seesq)
compute th1=0.0
compute rho=0.0
dlm(presample=ergodic,a=af,z=zf,sw=swf,c=c,f=f,y=lgdp,method=bfgs,type=filter) / states0
*set cycle0 = states0(t)(2)
*set trend0 = states0(t)(1)
Hardmann
