line connecting pairs in scater plot given position on graph
Aktar
Unread post by Aktar »
I would like a line in my scatter plot wich rely all point of the scatter. However the scatter is composed of pairs (points) that are aligned forming a curve more or less flat (regime switching probabilities given transitional variable). The curve is modelling given a logistic function...
I used scatter(style=line) but the line connects CONSECUTIVE points given their position in the sample rather than their position on the graph. Indeed, even if the pairs are aligned, when i connect pairs, i have something which is unreadable (line goings and comings)
moderator
Site Admin
Re: line connecting pairs in scater plot given position on g
Unread post by moderator »
If I understand the question properly, you probably just need to sort the series by value. You can use a single ORDER instruction to sort both series based on the values of one of them. Then do the SCATTER on the sorted pair.
Tom Maycock
