"FO9. Simultaneous block is singular." Error
evankoet
I am trying to run the code of the paper by Fratzscher, Juvenal and Sarno called "Asset prices, exchange rates and the current account". It estimates a 7-variable VAR and then runs a Monte Carlo simulation by taking orthogonal decompositions and using sign restrictions. However, the simulation does not run and I keep on getting the following error message:
## FO9. Simultaneous block is singular. Check your equations.
The Error Occurred At Location 6693, Line 301 of loop/block
My question is whether this is related to my data, or whether this error message has something to do with the programming itself. Is there also a way to figure out where "Location 6693, Line 301 of loop/block" is, so that I can see what is wrong?
I am able to run a very similar code with a 6-variable VAR (with different sign restrictions), of which 5 variables are the same as in the 7-variable model. The code is very similar so I do not understand where the error comes from.
If you wish I can post the code online, but it is quite long so I thought I would start by asking the questions above. Thank you very much for your help.
Evan
Evan
moderator
- Site Admin
Re: "FO9. Simultaneous block is singular." Error
Off hand, I'd guess it could be either. That's a "numerical" sort of an error (rather than a syntax error or other issue directly related to your code), but I can't really say whether there's a mistake in the way you've formulated the model, or you've correctly specified the model but it just doesn't work with the data.evankoet wrote: My question is whether this is related to my data, or whether this error message has something to do with the programming itself.
If you want us to take a look, the best option would be to email the program and data files to us at support@estima.com. Please be sure to include your full name and your RATS serial number and version number.
Sure. The Edit-Show Last Error may be able to take you to the offending line. Failing that, see "Instruction Locations-Debugging Compiled Code" starting on page 460 of the RATS User's Guide (if you have RATS 7, see the beginning of Chapter 16 in the RATS 7 User's Guide). Basically, this involves executing the code using a SOURCE(ECHO) instruction, or in batch mode, so that you can see the prefixed instruction location information, which you can then use to pinpoint the relevant instruction.evankoet wrote: Is there also a way to figure out where "Location 6693, Line 301 of loop/block" is, so that I can see what is wrong?
Tom Maycock
Estima
evankoet
Thank you for your prompt reply. I will send you the code and data later today.
Evan
Evan
In order to get a "simultaneous block", you need to have current endogenous variables on the right hand side of one of the equations. Did you add an identity to your VAR?evankoet wrote:Hi,
evankoet
The error came from the fact that I defined a variable in the VAR as i, whereas the Monte Carlo loop also used i. After changing the name of the variable it worked perfectly.
