Output direct to Excel
Anja
Unread post by Anja »
Is it possible to direct output from a model directly to an Excel spread sheet?
Thank You,
Anja
Re: Output direct to Excel
Not directly, as the full table doesn't lend itself to a spreadsheet-style display. However, you can use REPORT ending with REPORT(action=show,format=xls) to put whatever output you want into the spreadsheet. The following is an example using one of the sample data sets.
calendar 1922
allocate 1941:1
open data fooddata.dat
data(format=free,org=obs) / foodcons prretail dispinc foodprod prfarm
set trend = t
set avgprices = (prfarm+prfarm{1})/2.0
report(action=define)
report(atrow=1,atcol=1) "R**2"
report(atrow=2,atcol=1) "DW"
linreg foodcons
# constant prretail dispinc trend
report(regressors)
report(atrow=1,column=current) %rsquared
report(atrow=2,column=current) %durbin
linreg foodcons
# constant prretail dispinc{0 1}
report(regressors)
open copy testoutput.xls
report(action=show,format=xls,unit=copy)
avik
Unread post by avik »
I followed your example above and was able to create an Excel file with the output of several regressions.
My question is as follows:
Currently the output comes as
Reg1 Reg2 Reg3 Reg4 Reg5
R**2 0.87 0.02 0.03 0.02 0.06
Constant 0.17 -0.02 0.02 -0.03 0.02
t-stat 3.76 -0.16 0.12 -0.28 0.19
EV1 0.53 0.02 -0.06 -0.04 0.09
19.20 0.36 -1.31 -1.11 1.88
EV2 -0.13 -0.09 0.14 0.06 0.04
-6.32 -1.58 2.41 1.33 0.55
EV3 0.10 0.08 -0.06 0.11 -0.19
4.54 1.56 -0.99 2.48 -3.90
Is there a way to get the output in a "transposed" format (so that the explanatory variables are in columns and the regressions are in rows)?
I played with the REPORT procedure, but could not get it to transpose the output.
avik wrote:Hi Tom,
No. The REGRESSORS option just works with each regression being in a separate column. While I've seen summary tables for regressions running the other direction, they almost always have had the same set of regressors in each equation, which is much easier to handle. The key feature of REGRESSORS is that it lets you vary the set of explanatory variables and they all get slotted appropriately. The following would let you flip around the table so coefficients are in columns. This would be attached to the end of the KLEIN.RPF example:
linreg  privwage
# constant  prod{0 1}  trend
report(atrow=1,atcol=2,fillby=rows) %eqnreglabels(0)
report(atrow=2,atcol=1,fillby=rows) "OLS" %beta
linreg(inst)  privwage
report(atrow=3,atcol=1,fillby=rows) "2SLS" %beta
@liml privwage
report(atrow=4,atcol=1,fillby=rows) "LIML" %beta
report(action=format,atcol=2,width=8)
report(action=show)
