VARLAGSUM
VARLAGSUM
Dear Estima,
After estimating the VAR model, I can get the matrix for varlagsum in RATS 6.0. But I am not able to get the same in RATS 7.2. Why is that?
My estimated VAR is in differences. I want to derive the impulse responses and variance decompositions for some more variables say given by the following identities.
equation(identity) 12 Base
# AMBSLDIFF logAMBSL{1}
equation(identity) 13 Money
# M1Multi logAMBSL
equation(identity) 14 Price
# logM1 M1RealBal
associate 12
# 1.0 1.0
associate 13
# 1.0 1.0
associate 14
# 1.0 -1.0
How do I proceed? Please help.
# M1Multi logAMBSL
# logM1 M1RealBal
associate 12
# 1.0 1.0
associate 13
# 1.0 1.0
associate 14
# 1.0 -1.0
Re: VARLAGSUM
Without seeing how you're setting up the VAR, I can't really tell about the %VARLAGSUMS. As far as I can tell, it works fine if you useTG81 wrote:Dear Estima,
# M1Multi logAMBSL
# logM1 M1RealBal
associate 12
# 1.0 1.0
associate 13
# 1.0 1.0
associate 14
# 1.0 -1.0
SYSTEM(MODEL=...)
etc.
The added identities are much easier to handle as well if you use a MODEL for the VAR and names (rather than numbers) for your equations. The setup from the Gali QJE 1992 replication is:
system(model=islm)
variables cygr cdrate crr crmgr
lags 1 to 4
estimate(noprint)
* Define the identities for accumulating growth rates and other variables
* constructed from the four variables included in the VAR.
equation(identity,coeffs=||1.0,1.0||) yaccum logy
# logy{1} cygr
equation(identity,coeffs=||1.0,1.0||) raccum tb3
# tb3{1} cdrate
equation(identity,coeffs=||1.0,-1.0||) infid inf
# tb3 crr
equation(identity,coeffs=||1.0,1.0||) realaccum realm1
# realm1{1} crmgr
group identities yaccum raccum infid realaccum
You just use MODEL=ISLM+IDENTITIES on the IMPULSE and ERRORS instructions.
Re: VARLAGSUM
Thank you very much for the reply! Its been a great help.
We figured that %modellagsums is working in place of %varlagsums in RATS 7.2 and 7.3. I ran in to another problem. My model has long run restrictions (and no short run restrictions). When I am imposing that and calling in the procedure @ShortAndLong, I am getting results only for low values of nkeep. For nkeep>190(approx), RATS is giving the following error message
In the bootstrap simulations, for a certain value of nkeep, noninvertible matrix is generated and the program stops. The following are some portion of my program. I am not sure what is going wrong as the same set of codes work perfectly fine if I do not impose any short run or long run restrictions. Please help Tom. I have a journal deadline next week.
CODES:
dec rect[series] impulses(nvar,nvar) impuls(nvar,nvar) responses(nvar,nvar) responses2(nvar,nvar) vdecomp(nvar,nvar)
dec vect[series] udraws(nvar) resids(nvar) resample(nvar)
declare rect[series] vdbkeep(nvar,nvar) vdbkeep2(nvar,nvar) deco(nvar,nvar)
do i = 1,nvar
do j = 1,nvar
set responses(i,j) = 0
set responses2(i,j) = 0
set vdbkeep(i,j) = 0
set vdbkeep2(i,j) = 0
system(model=varmodel)
variables RDIFF OutputDIFF HoursDIFF RealBalDIFF MultiDIFF AMBSLDIFF
lags 1 to optlags
*estimate the multivariate model
dec rect f(nvar,nvar)
dec rect sr(nvar,nvar)
input sr
dec rect lr(nvar,nvar)
input lr
. 0 0 0 0 0
. . 0 0 0 0
. . . 0 0 0
. . . . 0 0
. . . . . 0
estimate(model=varmodel,cvout=vsigma,resids=resids,noprint)
source "C:\Users\Documents\WinRATS 7.3\ShortAndLong.src"
@ShortAndLong(sr=sr,lr=lr,masums=inv(%modellagsums(varmodel)),factor=f) %sigma
disp ###.### "Impact Responses" f
impulse(noprint,model=varmodel,factor=f,results=impuls,steps=horizon)
errors(print,model=varmodel,steps=horizon,factor=f,results=deco)
compute rstart=%regstart(),rend=%regend()
infobox(action=define,progress,lower=1,upper=nkeep) "Bootstrap Simulations"
do draws=1,nkeep
* Draw a bootstrapped sample
boot entries rstart rend
do i=1,nvar
set udraws(i) = resids(i)(entries(t))
forecast(path,model=varmodel,from=rstart,to=rend,results=resample)
# udraws
system(model=bootvar)
variables resample
lags 1 to optlags
* Estimate the model with resampled data
estimate(noprint,model=bootvar,noftests,cvout=v)
dec rect fb(nvar,nvar)
@ShortAndLong(sr=sr,lr=lr,masums=inv(%modellagsums(bootvar)),factor=fb) %sigma
disp ###.### "Impact Responsesb" fb
impulse(noprint,model=bootvar,factor=fb,results=impulses,steps=horizon)
errors(noprint,model=bootvar,factor=fb,results=vdecomp,steps=horizon)
do i = 1,nvar
do j = 1,nvar
set responses(i,j) = responses(i,j)+impulses(i,j)
set responses2(i,j) = responses2(i,j)+impulses(i,j)^2
set vdbkeep(i,j) = vdbkeep(i,j)+vdecomp(i,j)
set vdbkeep2(i,j) = vdbkeep2(i,j)+vdecomp(i,j)^2
infobox(current=draws)
end do draws
infobox(action=remove)
CODES:
do i = 1,nvar
do j = 1,nvar
lags 1 to optlags
input sr
input lr
. 0 0 0 0 0
. . 0 0 0 0
. . . 0 0 0
. . . . 0 0
. . . . . 0
do draws=1,nkeep
do i=1,nvar
# udraws
variables resample
lags 1 to optlags
do i = 1,nvar
do j = 1,nvar
end do draws
Re: VARLAGSUM
I don't know whether it would have any effect, but don't include the source instruction for shortandlong inside the loop. You already did that once with the original data. Once it's in, it's in.
That particular long run restriction can just be done with the %BQFACTOR function as described in the User's Guide which will simplify everything considerably.
Re: VARLAGSUM
Thanks Tom! The %BQFACTOR is working. Now, in order to use the procedures @MCGraphIRF and @MCFEVDTable, I am imposing the long run restrictions (given by %bqfactor) in the portion of the codes in MCVardodraws as given below.
Codes:
compute fxx =%decomp(varxx)
compute fwish =%decomp(inv(%nobs*%sigma))
compute wishdof=%nobs-varnreg
infobox(action=define,progress,lower=1,upper=ndraws) "Monte Carlo Integration"
do draw=1,ndraws
if %clock(draw,2)==1 {
compute sigmad =%ranwisharti(fwish,wishdof)
compute fsigmad =%bqfactor(%sigma,%modellagsums(varmodel))
compute betau =%ranmvkron(fsigmad,fxx)
else
impulse(noprint,model=varmodel+identities,factor=fsigmad,results=impulses,steps=steps)
But it is wrong as I am not factorizing sigmad. How do I impose %bqfactor in Monte Carlo simulations? Please help.
Codes:
do draw=1,ndraws
else
Re: VARLAGSUM
Replace the IMPULSE instruction with:TG81 wrote:Thanks Tom! The %BQFACTOR is working. Now, in order to use the procedures @MCGraphIRF and @MCFEVDTable, I am imposing the long run restrictions (given by %bqfactor) in the portion of the codes in MCVardodraws as given below.
But it is wrong as I am not factorizing sigmad. How do I impose %bqfactor in Monte Carlo simulations? Please help.Code: Select all
compute fxx =%decomp(varxx) compute fwish =%decomp(inv(%nobs*%sigma)) compute wishdof=%nobs-varnreg compute betaols=%modelgetcoeffs(varmodel) infobox(action=define,progress,lower=1,upper=ndraws) "Monte Carlo Integration" do draw=1,ndraws if %clock(draw,2)==1 { compute sigmad =%ranwisharti(fwish,wishdof) compute fsigmad =%bqfactor(%sigma,%modellagsums(varmodel)) compute betau =%ranmvkron(fsigmad,fxx) compute betadraw=betaols+betau } else compute betadraw=betaols-betau compute %modelsetcoeffs(varmodel,betadraw) impulse(noprint,model=varmodel+identities,factor=fsigmad,results=impulses,steps=steps)
compute factor=%bqfactor(sigmad,%modellagsums(model))
impulse(noprint,model=varmodel+identities,factor=factor,results=impulses,steps=steps)
Re: VARLAGSUM
Thanks Tom for the reply! I tried that before as well. RATS is giving me the following error message
## SX11. Identifier %SIGMAD is Not Recognizable. Incorrect Option Field or Parameter Order?
Please help as I have a deadline this week.
Re: VARLAGSUM
That's a typo. You want SIGMAD, not %SIGMAD.
