Input:
declare vector[integer] identity(17)
ewise identity(i)=1
declare rect[integer] d(17,17)
ewise d(i,i)=1
dis %SOLVE(d,identity)
Output:
Can't Find Match for %SOLVE(IMATRIX,INDEX). Closest Match is %SOLVE(RECTANGULAR,VECTOR)
Does anyone see what's wrong with my program ? Specifically, the vector I created called identity is recognised as an INDEX
from the %Solve function. Not sure why is that, any help is appreciated.
%SOLVE(A,B)
Re: %SOLVE(A,B)
You don't want to use VECT[INT] or RECT[INT] for any matrix calculations; those are really just for bookkeeping. If you change to:apollon wrote:Input:
ewise identity(i)=1
ewise d(i,i)=1
Output:
declare vector[real] identity(17)
ewise identity(i)=1
declare rect[real] d(17,17)
it will work.
