SEASONALDLM—state-space representation of seasonal
@SEASONALDLM creates the system matrices for one of a choice of two state space representations for a seasonal.
Detailed description
hardmann
Parameters of @seasonalDLM
Dear Tom:
I have checked the @ seanalDLM procedure. Why does the procedure return [al] and use both [*ap] and [*a] simultaneously. In addition, I would like to know why [ap], [cp], [swp] are used, and whether these parameters are following @ seasonalDLM? If that's the case, when calling @ seanalDLM, the current option is used instead of using parameters according to the procedure. Is it compatible with old code?
Best Regard
Hardmann
Best Regard
Hardmann
Re: Parameters of @seasonalDLM
So it wouldn't break any old code (it originally used the parameters). The options are the preferred method. I think that's described in the comments of the procedure file.
hardmann
Re: SEASONALDLM—state-space representation of seasonal
Dear Tom:
Thank you very much, I understand now. I tried to write a related procedure, so I delved into the internal code in detail.
Best Regard
Hardmann
Best Regard
Hardmann
