Request Multivariate REGCRITS.SRC
It would be useful to have a procedure like REGCRITS.SRC applicable to VAR's and VECM's i.e. for multivariate time series. Obviously there is VARLAGSELECT.SRC but the formulae are not completely transparent: AICC, SBC/BIC and HQ. There are AIC and SBC formulae in Enders RATS Programming Manual and Chapter 5 AETS; and others. Is this possible?
Amarjit
Amarjit
Re: Request Multivariate REGCRITS.SRC
@REGCRITS doesn't care what generated the log likelihood. While there are some specialized IC's which are strictly for single equation least squares, the main ones (SBC, HQ and AIC) can apply to multivariate models.
There's IC from VARLAGSELECT.
@REGCRITS: as described here https://estima.com/ratshelp/index.html? ... edure.html has 2 columns, giving different results.
In Enders
- AIC and SBC
- AIC* and SBC*
An example using ECT.RPF
Presumably in comparing fits I use those appropriate like-with-like computations with the same sample range in all models?
In Enders
- AIC and SBC
- AIC* and SBC*
* lag length selection tests
@varlagselect(lags=12,det=constant,crit=aic)
# ftbs3 ftb12 fcm7
@varlagselect(lags=12,det=constant,crit=sbc)
# ftbs3 ftb12 fcm7
@varlagselect(lags=12,det=constant,crit=gtos)
# ftbs3 ftb12 fcm7
@varlagselect(lags=12,det=constant,crit=hq)
# ftbs3 ftb12 fcm7
system(model=ratemodel)
variables ftbs3 ftb12 fcm7
lags 1 to 6
estimate(residuals=resids,noftests)
@regcrits
comp N = %eqnsize(1)*%nvar
comp aic = %nobs*%logdet + 2*N
comp sbc = %nobs*%logdet + N*log(%nobs)
comp aicstar = -2.0*%logl/%nobs + 2.0*N/%nobs
comp sbcstar = -2.0*%logl/%nobs + N*log(%nobs)/%nobs
report(use=creport,action=define,title="Information Criteria")
report(use=creport,atrow=1,atcol=1,span) "Information Criteria"
report(use=creport,atrow=2,atcol=1) "AIC" aic
report(use=creport,atrow=3,atcol=1) "SBC" sbc
report(use=creport,atrow=4,atcol=1) "AICstar" aicstar
report(use=creport,atrow=5,atcol=1) "SBCstar" sbcstar
report(use=creport,action=format,picture="*.###")
report(use=creport,action=show)
I have no idea what you're trying to say about @REGCRITS. It gives 4 IC's for a single model. So yes, they're different. But an IC in isolation means nothing; they are used to compare different models. @REGCRITS produces exactly the same HQ and SBC for a VAR as is used by @VARLagSelect.
TomDoan wrote: ↑Wed Apr 03, 2024 7:25 am I have no idea what you're trying to say about @REGCRITS. It gives 4 IC's for a single model. So yes, they're different. But an IC in isolation means nothing; they are used to compare different models. @REGCRITS produces exactly the same HQ and SBC for a VAR as is used by @VARLagSelect.
Sorry, the point regarding REGCRITS is there are two formulae for the same criteria, and a VAR generates a log likelihood hence using the first column. Correct?
These are the results from running the above code using VARLAGSELECT and REGCRITS. How are they the same?
VAR Lag Selection
Lags HQ
0 8.32307803
1 0.66879444
2 0.42990159
3 0.35167603
4 0.34400126
5 0.36758951
6 0.38667651
7 0.36542928
8 0.29156429*
9 0.37367410
10 0.40677616
11 0.48205793
12 0.54007865
VAR Lag Selection
Lags SBC/BIC
0 8.34498385
1 0.75641775
2 0.58324238
3 0.57073430*
4 0.62877701
5 0.71808274
6 0.80288723
7 0.84735747
8 0.83920997
9 0.98703726
10 1.08585680
11 1.22685605
12 1.35059425
AIC 0.142
SBC 0.898
Hannan-Quinn 0.444
(log) FPE 0.148Re: Request Multivariate REGCRITS.SRC
Actually @REGCRITS includes the full count of free parameters (%NFREE), including the covariance matrix. That allows it to be used to compare (e.g.) a VAR and a multivariate GARCH model. @VARLAGSELECT doesn't include the covariance matrix parameters since those have the same count in each of the models. The value of the criterion doesn't matter---just the rankings.
I'm not sure what you're trying to do in the first place. You can't use IC's to compare a VAR with a VECM, so what is the point?
TomDoan wrote: ↑Wed Apr 03, 2024 9:43 am Actually @REGCRITS includes the full count of free parameters (%NFREE), including the covariance matrix. That allows it to be used to compare (e.g.) a VAR and a multivariate GARCH model. @VARLAGSELECT doesn't include the covariance matrix parameters since those have the same count in each of the models. The value of the criterion doesn't matter---just the rankings.
The point is to compare e.g. VAR(1) vs. VAR(4) vs. VAR(p) using IC's, after an ESTIMATE. As you have said I cannot use IC's to compare VAR vs. VECM.
Therefore, I should use @VARLAGSELECT to choose the number of lags. And @REGCRITS IC's for comparison. Is that sensible?
I'm lost. @VARLAGSELECT does exactly that. What would re-doing the same calculations accomplish? (@REGCRITS would rank models exactly the same way).
@REGCRITS(K=%NREGSYSTEM) produces exactly the same results as @VARLAGSELECT.
But what if I include other deterministic terms: (typically there's only a constant) i.e. seasonals and/or a time trend in the model, which cannot be included in VARLAGSELECT?
Similarly, for Engle & Granger, as VARLAGSELECT only allows 1 term NONE or CONSTANT in DET, and in the model DET usually includes a constant and resids{1}, the IC for VARLAGSELECT and REGCRITS will not be the same. Correct?
The VARLAG.RPF example has the @VARLAGSELECT deconstructed to allow you to change up the DETERMINISTICS. (That's the reason we did that).
Engle-Granger is a univariate estimation, and the lags on that have nothing to do with the lags in a VAR in the same variables.
