Covariance matrix of DCC-GARCH parameter estimates
I have a more conceptual question related to the estimation of DCC-GARCH models. How is the joint covariance matrix of the parameter estimates (given by %xx) determined/estimated?
From my understanding there is a univariate GARCH model for each series in the first step and in the second step the parameters of the joint correlation equation are estimated (including the time invariant Q matrix towards which the DCCs converge, given stationarity). So my question is: given this two-step procedure, how is the joint covariance matrix of the parameters defined?
Best
Jules
Best
Jules
Re: Covariance matrix of DCC-GARCH parameter estimates
RATS by default does a full joint likelihood maximization for DCC. There's a GARCHMVDCC2.RPF which does the two-step procedure---it does one iteration with BHHH to get an estimate of the overall covariance matrix. However, if you have 10 or fewer variables, there is no reason to do the two step procedure, which is consistent but less efficient.
I wonder if you could give me a reference on how the full information maximum likelihood estimation of the DCC GARCH model works?
Best
Jules
Best
Jules
It's either the standard BFGS or BHHH estimate of the covariance matrix, depending upon your estimation options.
Thanks Tom,
But what I actually meant was a reference related to the derivation of the one step likelihood itself.
Is this written down in the original paper? I am struggling to find a comprehensive summary of the formulas, as everywhere solely the two step approach is described.
Thank you very much
Best
Jules
Thank you very much
Best
Jules
The full sample likelihood is in the original DCC paper.
