ppunit.src is a procedure for doing the Phillips-Perron root test. @PPUNIT is part of the Unit Root Tests wizard on the Time Series menu.
Detailed description
PPUNIT—Phillips Perron Unit Root Test
Osabuohien247
ADF test
Good day,
Just like we have adfautoselect for ADF lag selection, can i find any code in RATS for Phillips-Perron (PP) bandwidth or lag selections?
Thank you
Thank you
Re: PPUNIT—Phillips Perron Unit Root Test
There really is none, as there is nothing to optimize over. As it says in the discussion of the procedure, you can do a sensitivity table which where the statistics will generally stabilize when the number of lags is adequate.
Note, however, that the Phillips-Perron test is generally inferior to the ADF. The only cases where it works better are rare in practice.
