how to restrict the correlation parameter in estimating sw?
horsehandsome
Hi I am estimating a state-space model where there are two state variables. I allow two shocks in the transition equations to be correlated in the spirit to Morley, Nelson and Zivot (2003) and Sinclair (2009). My question is: how to restrict the correlation parameter in 'sw' to be less than 1 in its absolute term. I ended up getting some number way above 1. Thanks.
Jason
Jason
Re: how to restrict the correlation parameter in estimating sw?
This gives two options for that; the first pegs the correlation coefficient at 1 (if the unrestricted max is >1, the restricted max should be at 1). The second estimates the covariance matrix in packed lower triangular form. If the restricted max is at perfect correlation, the (2,2) element of the lower triangular should be 0.
* Unrestricted UC model, allowing for correlation between the shocks.
* The maximum occurs at rho=1 (possible since we have only one
* observable, so having just a single effective shock is OK).
compute rhone=0.0,sn=.1
nonlin mu d sn ph1 ph2 se rhone=1.0
frml swf = ||sn^2|rhone*abs(sn)*abs(se),se^2||
dlm(presample=ergodic,a=af,z=zf,sw=swf,c=c,f=f,y=lgdp,method=bfgs,$
type=filter) / statesur
* Alternative parameterization for covariance matrix of shocks.
dec packed swlower(2,2)
frml swf = %ltouterxx(swlower)
compute swlower(1,1)=.7,swlower(2,1)=0.0,swlower(2,2)=.7
nonlin mu d ph1 ph2 swlower
type=filter) / statesur-
horsehandsome
Thanks for you reply, Tom. But what I ended up having is above 1 correlation along with non-convergence warning and some nonsensical parameters. Is there any way to constrain the correlation parameter within the (-1,1) band while allowing it to be freely estimated? Thanks.
Use this as the parameter set:
nonlin mu d sn ph1 ph2 se rhone rhone<=1.0-
horsehandsome
Thanks a lot! It works.
