hi. Is it possible to (1) make a regression line thicker in a scatter plot and (2) get rid of the vertical line at zero in a scatterplot?
Regression line
Re: Regression line
You would have to draw it yourself using the OVERLAY=LINES option and a separate pair of "x-y" series which will draw the line. The LINES option does "hairlines", which can't be redefined as they're used for other purposes (tick marks in particular).e1983 wrote:hi. Is it possible to
AXIS=NONE or AXIS=HORIZONTAL will eliminate the vertical axis.e1983 wrote: (2) get rid of the vertical line at zero in a scatterplot?
