Error Bands on IRFs in TVAR
I have two questions on Threshold VAR models. Since I am an absolute beginner in this topic this might already have been dealt with:
1) TVARs switch coefficients when an estimated threshold value has been exceeded. Assume I want to analyse shocks under a zero lower bound regime on interest rats, then technically I don't need to estimate the threshold, right? I would just have to set the threshold value of the policy rate to zero.
2) To analyse the IRFs generalized IRFs have to be computed. In the Balke (2000) paper there have no error bands been computed. Is it possible to compute error bands for GIRFs for example by bootstrapping or monte carlo integration? A reference would be Galvao and Marcellino (2014) -"The effects of the monetary policy stance on the transmission mechanism", they use a residual-based bootstrap method to the estimated nonlinear model.
3) Is it possible to calculate regime depentent IRFs including error bands?
It would be very nice if you could suggest some example code related to the above posted questions.
Thank you very much in advance
Best
Jules
Best
Jules
Re: Error Bands on IRFs in TVAR
If the threshold is known, then you don't have to estimate it. However, you have to have data points on both sides of the threshold to estimate the model, and, in fact, have to have enough data points in each regime to estimate a VAR. This isn't a theoretical model, it's empirical, so if something hasn't happened, or only rarely has happened, you can't use it.Jules89 wrote: I have two questions on Threshold VAR models. Since I am an absolute beginner in this topic this might already have been dealt with:
It's a bit odd that that paper doesn't reference Balke, given that other than the adding bootstrap over parameters, their model is exactly the same as Balke's. You can bootstrap over the model, as they do in that paper---it's just an added complication.Jules89 wrote: 2) To analyse the IRFs generalized IRFs have to be computed. In the Balke (2000) paper there have no error bands been computed. Is it possible to compute error bands for GIRFs for example by bootstrapping or monte carlo integration? A reference would be Galvao and Marcellino (2014) -"The effects of the monetary policy stance on the transmission mechanism", they use a residual-based bootstrap method to the estimated nonlinear model.
How is that different from question 2?Jules89 wrote: 3) Is it possible to calculate regime depentent IRFs including error bands?
Thank you for the quick reply. Is there any code example for a similar bootstrap ?
Best jules
Best jules
No. But it wouldn't be a big issue. From your description, it sounds like you have a bigger problem with getting what you're doing into a TVAR framework.
comming back to my question regarding the residual based bootstrap for the TVAR, which I would like to use to simulate data from the estimated model to generate confidence bands for the GIRFs.
I used the Balke(2000) code and tried to simlate data from it by using resampled residuals. The problem is that the simulation generates explosive time series. The code is given by:
Is this explosive behavor a property of the model, or did I do something wrong?
Thank you in advance
Best Jules
**** Load Data ****
cal(q) 1947
allocate 1997:4
open data flofund2.dat
data(unit=data,org=obs) 1947:1 1997:4 $
date nfbfla nfbstk nfbfln nfcfla nfcstk nfcfln cmpapfln cmpapfla cmpapstk rgdpcw pgdpcw fyff m2 cp46 t6
**** Control parameters ****
compute nvar =4 ;* #-Dependent variables
compute maxlag=4 ;* Lag-length
comp upper =1 ;* Regime Selector. Change 0 for other regime
comp horizon =12 ;* IRF horizon
comp nboot =100 ;* #-of IRF Bootstrap Replications
compute shock= +1.0 ;* size and signs of shocks in terms of standard deviations
compute sstart = 1959:1 ;* Estimation start
compute send = 1997:3 ;* Estimation end
compute d = 1 ;* Threshold Lag
compute ciboot = 20 ;* #-of Bootstrap replications for CIs
compute thresh = 0.48667 ;* Threshold value estimated before
**** Data Transformations ****
set mix = (nfbstk+nfcstk)/(cmpapstk+nfbstk+nfcstk)
set gdp = rgdpcw
set pgdp = pgdpcw
set d1mix = (mix-mix{1})
set cpbill1 = cp46-t6
set d1gdp = 400*log(gdp/gdp{1})
set d1pgdp = 400*log(pgdp/pgdp{1})
set ly = log(gdp)
set d1y = d1gdp
set d1p = d1pgdp
set money = fyff
set credit = cpbill1
**** Storage Space ****
dec vect[frml] tvarf(nvar) ;* Vector of formulas of T-VAR equations, which will include the switching
dec vect[series] bootu(nvar) data(nvar)
dec series[vect] bootuv bootres
dec vect[string] shortlabels(nvar) longlabels(nvar)
**** Set up the series for the T-VAR ****
dec vect[int] depvars(nvar) ;* Vector of Indicators of Dependent Variables
compute depvars =||d1y,d1p,money,credit||
**** set thresholds and Threhold Formulas ****
dec vector macoeffs
compute malength = 2
filter(type=lagging,span=malength) credit / credthr ;* Moving Average of the Threshold Variable
compute macoeffs=%fill(malength,1,1.0/malength)
equation(identity,coeffs=macoeffs) threqn credthr ;* This generates an equation (and from it a FRML) to compute the moving average
# credit{0 to malength-1}
frml(equation=threqn,identity) thrfrml
set dup = thrfrml{d}>thresh ;* Dummy for the upper regime
set dlo = 1.-dup ;* Dummy for the lower regime
**** Estimation of the Model coefficients *****
system(model=basevar)
variables depvars
lags 1 to maxlag
compute rstart=sstart+maxlag
compute rend=send
dec vect[series] resup(nvar) reslo(nvar) ;* Vector of Series of Upper and Lower regime residuals splitted up
dec vect[frml] fitup(nvar) fitlo(nvar) ;* Vector of formulas of fitted VAR equations (includes the estimated coefficients)
*** Upper regime estimation
estimate(noprint,smpl=dup,resids=resup,title="Upper Regime") rstart rend ;* Estimate under the upper regime
do i=1,nvar
frml(equation=%modeleqn(basevar,i)) fitup(i) ;* Define regime-specific FRML’s
compute vup=%sigma ;* Upper Regime Covariance Matrix
*** Lower regime estimation
estimate(noprint,smpl=dlo,resids=reslo,title="Lower Regime") rstart rend ;* Estimate under the lower regime
do i=1,nvar
frml(equation=%modeleqn(basevar,i)) fitlo(i) ;* Define regime-specific FRML’s
compute vlo=%sigma ;* Lower Regime Covariance Matrix
**** Compute the upper and lower branch covariance matrices, their Choleski ****
**** factors and the inverse factor. (The inverse is for standardizing the ****
**** residuals and the factor for mapping standardized residuals back to ****
**** the true levels.) ****
compute sup =%decomp(vup) ;* Upper Regime Cholesky Decomp of Covariance Matrix
compute siup=inv(sup) ;* Upper Regime inverse Cholesky Decomp of Covariance Matrix
compute slo =%decomp(vlo) ;* Lower Regime Cholesky Decomp of Covariance Matrix
compute silo=inv(slo) ;* Lower Regime inverse Cholesky Decomp of Covariance Matrix
**** Compute (jointly) standardized residuals ****
dec series[vect] stdu
gset stdu rstart rend = %if(dup,siup*%xt(resup,t),silo*%xt(reslo,t)) ;* siup/silo are vect[series] %xt(resup,1) takes for t=1 the vector of realisations of resup
**** Save the original data ****
dec vect[series] data(nvar)
do i=1,nvar
set data(i) = depvars(i){0}
**** Define the switching formula. Because the bootstrap requires taking ****
**** the standardized residuals and reflating them using regime-specific ****
**** covariance matrices, the reflation part has to be incorporated into ****
**** the formula. Thus TVARF(i) is (in effect) an identity given the (still ****
**** to be created) bootres series. ****
do i=1,nvar
frml tvarf(i) depvars(i) = %if(thrfrml{d}>thresh,$
fitup(&i)+%dot(%xrow(sup,&i),bootres),$
fitlo(&i)+%dot(%xrow(slo,&i),bootres))
**** Create a FRML to determine which regime holds in a simulation. (It ****
**** will be 1 for upper and 0 for lower) ****
*frml(identity) upperfrml dup = thrfrml{d}>thresh
**** Build the threshold var model using the switching equations and the ****
**** definitional identity for the threshold variable. ****
group tvar tvarf(1) tvarf(2) tvarf(3) tvarf(4) thrfrml
**** Figure out which set of entries we want. This is the simplest way ****
**** to get this. dup{0} takes two values (0 or 1) but the order isn't known ****
**** in advance since it will depend upon which value is seen first in the ****
**** <<rstart>> to <<rend>> range. So we have to figure out which of values(1) ****
**** and values(2) (and the corresponding entries(1) and entries(2)) is the ****
**** one that we need, given the choice for <<upper>>. ****
panel(group=dup{0},id=values,identries=entries) dup rstart rend
if upper==1.and.values(1)==1.or.upper==0.and.values(1)==0
compute rdates=entries(1)
else
compute rdates=entries(2)
**** Set up target series. There is one for each combination of test sign ****
**** and sizes on the shock, variable shocked and target variable. ****
compute wstart=rend+1,wend=wstart+horizon-1 ;* This is the working range for calculating the GIRF's
compute ninitial=%size(rdates) ;* #-of periods in the specified regime
dec rect[series] nlirfs(nvar,nvar)
do i=1,nvar
do j=1,nvar
set nlirfs(i,j) wstart wend = 0.0
**** Simulate Data ****
dec vect[series] resample(nvar+1) ;* Set up storage space for the simulated Data
do i = 1,nvar
set resample(i) = %modeldepvars(tvar)(i){0}
set resample(5) = credthr
do rep = 1, 10
boot entr rstart rend
gset bootres rstart rend = stdu(entr(t))
forecast(model=tvar,from=rstart,to=rend,results=resample)
spgraph(hfields=4,vfields=1)
do i = 1,4
graph 2
# data(i) rstart rend
# resample(i) rstart rend
end do rep
Best Jules
The dominant root of the lower partition is about 1.2. If (as seems to be the case), the lower regime doesn't necessarily drive the credit variable up towards the threshold, then eventually the process will diverge. That's not as obvious with the IRF's which only do 15 steps and which take the difference between the results with and without one single change to the shocks (thus big number-big number can be small number).
One thing to note is that computing error bands in a model which requires simulations just to compute the IRF's in the first place requires a staggering amount of calculation.
May the reason for this be that the variable "money" and "D1p" aren't stationary? Because in a TVAR the variables have to be stationary right? Otherwise shocks might drive you persistently in a regime, where the process stays extremely lone or evene forever, right?
The Dickey-Fuller test results are:
Anyway, below is a code for the bootstrapped confidence bands. I am not quite sure whether this is correct, as the results seem odd to me. I use the median of all possible GIRFs which are estimated from the data simulated by the model, as the GIRFs central tendency. The confidence bands are derived by using upper and lower quantiles. Could you have a look on the code?
Best
Jules
Dickey-Fuller Unit Root Test, Series D1P
Regression Run From 1959:04 to 1997:03
Observations 153
With intercept
With 2 lags chosen from 4 by GTOS/t-tests(0.050)
Sig Level Crit Value
1%(**) -3.47396
5%(*) -2.88035
10% -2.57669
T-Statistic -1.93483
Dickey-Fuller Unit Root Test, Series MONEY
Regression Run From 1960:01 to 1997:03
Observations 152
With intercept
With 3 lags chosen from 4 by GTOS/t-tests(0.050)
1%(**) -3.47423
5%(*) -2.88047
10% -2.57675
T-Statistic -2.42320
Best
Jules
**** Load Data ****
cal(q) 1947
allocate 1997:4
comp upper =0 ;* Regime Selector. Change 0 for other regime
compute ciboot = 500 ;* #-of Bootstrap replications for CIs
compute pi=.15 ;* Fraction of threshold values excluded at each end
set gdp = rgdpcw
set pgdp = pgdpcw
set ly = log(gdp)
set d1y = d1gdp
set d1p = d1pgdp
set money = fyff
dec vector macoeffs
variables depvars
lags 1 to maxlag
compute rend=send
do i=1,nvar
do i=1,nvar
do i=1,nvar
do i=1,nvar
else
do i=1,nvar
do j=1,nvar
**** Storage Space for Bootstrap ****
dec series[vect] stdub
dec vect[series] resupb(nvar) reslob(nvar) ;* Vector of Series of Upper and Lower regime residuals splitted up
dec vect[frml] fitupb(nvar) fitlob(nvar) ;* Vector of formulas of fitted VAR equations (includes the estimated coefficients)
dec vect[frml] tvarfb(nvar) ;* Vector of formulas of T-VAR equations, which will include the switching
dec vect[series] bootub(nvar)
dec series[vect] bootuvb bootresb
dec vect[series] datab(nvar)
dec rect[real] matgirf ;* For TRansformimng series into matrix
declare vect[series[vect]] girf(nvar*nvar)
do i = 1, nvar*nvar
gset girf(i) 1 ciboot = %zeros(horizon,1)
**** Additional Configurations for Bootstrap ****
do i = 1,nvar
compute piskip=fix(pi*%nobs)+(maxlag*nvar+1) ;* To prevent overfitting, exclude the lower and upper pi% and number of regressors per equation from the estimation range
compute pistart=rstart+piskip
compute piend=rend-piskip
**************************************** GIRFs Bootstrap within Bootstrap Start ****************************************
infobox(action=define,lower=1,upper=ciboot,progress) "Residual Based Bootstrap"
do r = 1,ciboot
infobox(current=r)
**** Simulate Data from the TVAR ****
**** Estimate the Model with the new Data ****
filter(type=lagging,span=malength) resample(4) / credthrre ;* Moving Average of the Threshold Variable
equation(identity,coeffs=macoeffs) threqnb credthrre ;* This generates an equation (and from it a FRML) to compute the moving average
# resample(4){0 to malength-1}
frml(equation=threqnb,identity) thrfrmlb
****** Estimate the Threshold Value ******
* Threshold Value is estimated by the value that maximizes the Log likelihood
* of the estimated model for a given threshold value
system(model=threshestim)
variables resample(1) resample(2) resample(3) resample(4)
lags 1 to maxlag
estimate(noprint,model=threshestim) rstart rend
compute loglr=%logl
set copy rstart rend = credthrre{d} ;* Get a sorted copy of the threshold variable
order copy rstart rend
compute bestlogl=loglr
set lrstats pistart piend = 0.0
do pientry=pistart,piend
compute thresh=copy(pientry)
sweep(var=hetero,group=credthrre{d}<thresh) rstart rend ;* This allows for the covariance matrix to differ between regimes
# %modeldepvars(threshestim)
# %rlfromeqn(%modeleqn(threshestim,1))
if %logl>bestlogl ;* If this is best so far, save it
compute bestlogl=%logl,bestthresh=thresh
end do pientry
compute thresh = bestthresh
**** given the new threhold value estimate the Model ****
set dupb = thrfrmlb{d}>thresh ;* Dummy for the upper regime
set dlob = 1.-dupb
system(model=basevarb)
lags 1 to maxlag
*** Upper & Lower regime estimation
estimate(noprint,model=basevarb,smpl=dupb,resids=resupb) rstart rend ;* Estimate under the upper regime
estimate(noprint,model=basevarb,smpl=dlob,resids=reslob) rstart rend ;* Estimate under the lower regime
do i=1,nvar
frml(equation=%modeleqn(basevarb,i)) fitupb(i) ;* Define regime-specific FRML’s
compute vupb=%sigma ;* Upper Regime Covariance Matrix
do i=1,nvar
frml(equation=%modeleqn(basevarb,i)) fitlob(i) ;* Define regime-specific FRML’s
compute vlob=%sigma ;* Lower Regime Covariance Matrix
compute supb =%decomp(vupb) ;* Upper Regime Cholesky Decomp of Covariance Matrix
compute siupb=inv(supb) ;* Upper Regime inverse Cholesky Decomp of Covariance Matrix
compute slob =%decomp(vlob) ;* Lower Regime Cholesky Decomp of Covariance Matrix
compute silob=inv(slob) ;* Lower Regime inverse Cholesky Decomp of Covariance Matrix
gset stdub rstart rend = %if(dup,siupb*%xt(resupb,t),silob*%xt(reslob,t)) ;* siup/silo are vect[series] %xt(resup,1) takes for t=1 the vector of realisations of resup
do i=1,nvar
frml tvarfb(i) resample(i) = %if(thrfrml{d}>thresh,$
fitupb(&i)+%dot(%xrow(supb,&i),bootresb),$
fitlob(&i)+%dot(%xrow(slob,&i),bootresb))
group tvarb tvarfb(1) tvarfb(2) tvarfb(3) tvarfb(4) thrfrmlb
panel(group=dupb{0},id=values,identries=entries) dupb rstart rend
else
do i=1,nvar
set datab(i) = resample(i){0}
**** GIRF BOOTSTRAP ****
do jrep=1,ninitial
**** Copy History into the dependent Variable Solts ****
compute basedate=rdates(jrep)
do i=1,nvar
move datab(i) basedate-maxlag basedate-1 resample(i) wstart-maxlag
**** Loop over bootstrap replications ****
do boot=1,nboot
**** Generate the bootstrap shuffle ****
boot rentries wstart wend rstart rend
**** Generate the base set of shocks by premultiplying the ****
**** bootstrapped standardized shocks by the factor of the overall ****
**** covariance matrix. ****
gset bootuvb wstart wend = %if(%ranflip(.5),+1,-1)*stdub(rentries(t))
gset bootresb wstart wend = bootuvb
forecast(model=tvarb,from=wstart,to=wend,results=base)
do jshock=1,nvar
**** Patch over the component for which are computing the ****
**** response with the selected size and sign. ****
compute bootresb(wstart)=bootuvb(wstart)
compute bootresb(wstart)(jshock)=shock
forecast(model=tvarb,from=wstart,to=wend,results=withshock)
do i=1,nvar
set nlirfs(i,jshock) wstart wend = nlirfs(i,jshock)+withshock(i)-base(i)
end do jshock
end do boot
end do jrep
do j=1,nvar
do i=1,nvar
set nlirfs(i,j) wstart wend = nlirfs(i,j)/(nboot*ninitial)
**** Bookkeeping ****
** Converts the series of IRFs for different shocks into matrices. Gives you k (#-shocks) **
** matrices (i,j), where i is the ith response step of each variable. **
** j is equal to nvar(=4)*nvar(4), coulumns 1 to 4 are the responses of all variables to a shock **
** in variable 1, coulums 5 to 8 are the responses of all variables to a shock in variable 2, and **
** so on. **
make matgirf wstart wend
# nlirfs
** Plugs the columns of the above matrices in the storage space vectors for j = 1,...,nvar*nvar. **
** GIRF vectors of series of vectors: j=1,..4 are responses of veriable all variables **
** to a shock in variable 1 for draw r, j=5,...,8 are the responses of all variables **
** to a shock in variable 2 and so on **
do j =1,nvar*nvar
do i =1,horizon
compute girf(j)(r)(i) = matgirf(i,j)
end do r
infobox(action=remove)
**** Monte Carlo Integration ****
declare vect[vect[vect]] Q(nvar*nvar)
compute lowerci = 0.16
compute middle = 0.50
compute upperci = 0.84
do i = 1,nvar*nvar
@mcmcpostproc(ndraws=ciboot,percentiles=||lowerci,middle,upperci||,quantiles=Q(i)) girf(i)
declare vect[series] ciup(nvar*nvar)
declare vect[series] center(nvar*nvar)
declare vect[series] cilow(nvar*nvar)
do i= 1, nvar*nvar
set cilow(i) 1 horizon = Q(i)(t)(1)
set center(i) 1 horizon = Q(i)(t)(2)
set ciup(i) 1 horizon = Q(i)(t)(3)
declare rect[series] cilomat(nvar,nvar)
declare rect[series] centermat(nvar,nvar)
declare rect[series] ciupmat(nvar,nvar)
compute k = 1
do i = 1,4
do j= 1,4
set cilomat(j,i) = cilow(k)
set centermat(j,i) = center(k)
set ciupmat(j,i) = ciup(k)
compute k=k+1
compute shortlabels=||"Output","Inflation","Money","Credit"|| ;* Labels Short
spgraph(hfields=4,vfields=4,header="Shocks",ylabels=shortlabels,xlabels=shortlabels)
do i = 1,nvar
do j = 1,nvar
graph(nodates) 3
# cilomat(j,i) / 2
# centermat(j,i) / 1
# ciupmat(j,i) / 2
That's not true. In the example below, this generates a non-explosive process even though one branch is non-stationary and one is explosive. For TAR models, the behavior of the combined process depends upon all sorts of things---for instance, the variance of the shocks matters (a big variance here does create a problem because it overwhelms the -1.0 in the upper branch that's driving the process back towards the threshold).Jules89 wrote:May the reason for this be that the variable "money" and "D1p" aren't stationary? Because in a TVAR the variables have to be stationary right? Otherwise shocks might drive you persistently in a regime, where the process stays extremely lone or evene forever, right?
dec series y
frml yfrml y = %if(y{1}<=1.0,y{1},-1.0+1.1*y{1})
set y 1 5000 = 0.0
simulate(model=yfrml,from=2,to=5000,cv=||1.0||,results=test)
Regarding your program, inside the loop, you're redefining the THRESH value that's needed to do the outer bootstrap.
Given the behavior of the bootstrapped data, I'm not surprised that you're getting odd results. Once those get off track, they very quickly turn into y(t)=1.2y(t-1) for each of the series (basically, you see only the dominant root and nothing else)
Thanks Tom,
I have three questions:
1)when I get this right, then stationarity of the variables seems not to be a major issue in TVAR models. A summary paper by Hubrich and Teräsvirta (2013) with the title "Thresholds and Smooth Transitions in Vector Autoregressive Models (link: https://pure.au.dk/ws/files/54473123/rp13_18.pdf), defines the TVAR for stationary time series (see page 7). Basicly all TVAR papers I read use stationary time series (or variables that should be stationary). Would you recommend to transform variables to stationarity if they arn't or would you go with the standard behavior in linear VARs and leav everything in levels?
2) Right I have to assign a different name for it within the reestimation (maybe call it threshb or so, such that in the outer bootstrap I have the "old" threshvariable). I wanted to estimate a new threshold for the simulated data. Should I stick to the already estimated threshold and do not reestimate it for every "draw" of new data?
3) So the bad news is that for this data set bootstrapping confidence bands is not a good idea, right?
Thank you very much
Best
Jules
Thank you very much
Best
Jules
I'm not really sure what you're saying. The 2013 paper keeps working with "stationary" models because you actually can do proofs of various conditions for them. They rather explicitly allow for non-stationary models as well, they just don't do much with them.Jules89 wrote:Thanks Tom,
The model is what the model is. If the threshold is seen as depending upon the non-stationary credit variable, then you can't replace that with a stationary alternative.
You're doing a parametric bootstrap treating the original estimate as fixed, but part of the uncertainty in the model is that that's not known so you should be re-estimating it.Jules89 wrote: 2) Right I have to assign a different name for it within the reestimation (maybe call it threshb or so, such that in the outer bootstrap I have the "old" threshvariable). I wanted to estimate a new threshold for the simulated data. Should I stick to the already estimated threshold and do not reestimate it for every "draw" of new data?
Correct. You probably would have an easier time doing MCMC (which treats the data as given)---the only thing non-linear is the threshold value; given it, everything else can be drawn by standard VAR techniques.Jules89 wrote: 3) So the bad news is that for this data set bootstrapping confidence bands is not a good idea, right?
Thank you very much,
the last point sounds very interesting.
How would I estimate that with MCMC? As far as I understand you mean that I estimate the threshold in the usual way (as in Balke 2000).
Since the data are the same and I am not generating any new data the threshold keeps being the same. From the samplesplit implied by th eestimated threshold I get two data sets, for which I set up two likelihoods and two priors. Then I draw for the two resulting VARs the coefficients and run the GIRF Bootstrap.
That would mean I have model uncertainty with respect to the VAR parameters but not with respect to the threshold, since this is given by the data, correct?
how would I get the sample split data to set up the two gibbs samplers?
Thank you very much
best Jules
Thank you very much
best Jules
Given the threshold value, you just have two separate VAR's. Sampling from those will take care of the covariance matrices and VAR coefficients. Those are "one-off" calculations since the sample changes, so it's not the super-efficient calculation used by @MONTEVAR which can do everything for each draw using the least squares statistics, but it's no more complicated than having to re-estimate with bootstrapped data. The likelihood in the threshold value is discontinuous (since it only changes at the observed data points of the threshold variable), but you just need to come up with a proposal density for it, which could be continuous, to do Independence Chain M-H.
thank you for your help, but I may have missed an argument. Within this bayesian setup I don't understand what you mean by "Given the threshold value, you just have two separate VAR's. Sampling from those will take care of the covariance matrices and VAR coefficients."?
I have two VARs and I draw the coefficients of those from the respective posteriors. Given the threshold value, I would draw for each of the two VARs the parameters similar to the @MONTEVAR procedure. Then I set up the TVAR as before and run the GIRF bootstrap.
What do you mean by " Those are "one-off" calculations since the sample changes"? Given the two likelihoods for the two VARs and the respective posteriors, where does the sample change and why?
I assume that you mean I should sample the threshold value as well, since you said "The likelihood in the threshold value is discontinuous (since it only changes at the observed data points of the threshold variable), but you just need to come up with a proposal density for it, which could be continuous, to do Independence Chain M-H."
But how would such a proposal density look like? I have never seen a paper doing something like that for TVARs and it sounds very challenging... Could you give me a reference or tell me a bit more detailed how the sampling steps would look like?
Best
Jules
Best
Jules
One VAR is for the lower regime, one for the upper. Change the threshold, change the sample covered by each. Draws for a VAR with the standard non-informative prior only require the OLS coefficients, covariance matrix and X'X matrix for a particular sample which is why you can compute those sufficient statistics once for a fixed sample VAR and generate draws very quickly. In this case, the samples (likely) change with each sweep, so you can't use the old information.Jules89 wrote:Dear Tom,
It would be Gibbs sampling (or Metropolis within Gibbs). You do everything but the threshold given the threshold (again, that's just two VAR's), and then the threshold given everything else, which is not standard, but the conditional likelihood depends only upon the residuals from the two VAR's and the two covariance matrices. As to what might be an appropriate proposal for the threshold, that would depend entirely upon the application. In some cases, it might be rather flat; in others it might need to be much more peaked. However, it's just a single parameter, so the sampler's likely to be fairly robust.Jules89 wrote: I assume that you mean I should sample the threshold value as well, since you said "The likelihood in the threshold value is discontinuous (since it only changes at the observed data points of the threshold variable), but you just need to come up with a proposal density for it, which could be continuous, to do Independence Chain M-H."
As I'm sure you're aware, there's very little done with error bands on TVAR's. It just seems that this is a case where parametric bootstrapping is fixing a bit too much at sample values to be workable.
