Co-integration analysis using CATS2
bizimanaRATS
Dear forum members,
each time I do a co-integration analysis in RATS using CATS2, I get an error or message like this: ## Unassigned 1023. Can anyone explain me what the error means and its possible effects on the model estimation. I did not find that kind of error in the RATS manual.
JC
JC
Re: Co-integration analysis using CATS2
First, your RATS is somehow set up wrong so it doesn't find the actual error messages. The CATS problem is that you have a rather old copy of CATS v2. Contact support@estima.com. Make sure you let us know the serial numbers and versions of the RATS and CATS software that you're using.
bizimanaRATS
thanks for your reply. I reset the model using RATS 8.2 and now it's showing the real error messages. As for the copy of CATS 2 I am using, it's compatible with RATS version 6.2 or later. The program I am using now is RATS 8.2; so it should not pose any problem to my understanding. The issue I am encountering is related to setting up the rank of pi. When the dialogue box comes up and asks me to input the number of co-integrating vectors, and do it, the run does not go through. I see this error message: ## MAT13. Store into Out-of-Range Matrix or Series Element. However when I check the error message meaning I do not understand why the error comes up since I am inputting the right number of co-integrating vectors. Below is the program I am using:
Calendar(m) 2000:01
allocate 100 2013:06
open data DataPriceSorgh_New1.txt
data(format=free,org=obs) / PKAY PBKO PNIOR PSEG PSAN PSIK PGAO PTOM PMOP
source "C:\.......\Desktop\Research1\Software\CATS2\cats.src"
@cats(lags=1,dettrend=cimean) 2000:08 2013:06
# PKAY PBKO PNIOR PSEG PSAN PSIK PGAO PTOM PMOP
I appreciate your help.
JC
Calendar(m) 2000:01
JC
The early CATS v2's had an error in them (multiple options with the same root name) that was only detected in RATS version 8 and later. You need the person in charge of your RATS and CATS licenses contact support@estima.com.
