Store correlation matrix output
cyang40
Unread post by cyang40 »
I would like to store the correlation between two variables, but my following command does not do the job. Could you please direct me as to what is missing in my code? Thank you.
cmom(corr,print)
# gdp_detrend govt_detrend
compute mycorrs = %cmom(gdp_detrend,govt_detrend)
Re: Store correlation matrix output
You want %cmom(1,2)---the elements of the array are accessed by position, not by the variable.
cyang40
I fixed the code but the output doesn't seem to exist.
cmom(corr,print)
compute mycorrs = %cmom(1,2)
print / mycorrs
## SX22. Expected Type SERIES[REAL], Got REAL Instead
>>>>print / mycorrs<<<<
MYCORRS is a number, not a series. Use DISPLAY, not PRINT.
cyang40
Thank you for the advise. Since I have a panel data, is there a way to store the output by country? I have attempted the following procedure, and I received an error message from the system. Perhaps, I am doing this incorrectly.
do i=1,61
cmom(corr,print) i//1970:1 i//2013:1
compute mycorrs(i) = %cmom(1,2)
display mycorrs(i)
## SX11. Identifier MYCORRS is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>> compute mycorrs(<<<<
add
clear mycorrs
before the loop so mycorrs is recognized as a series.
cyang40
This will create a vector with 1//1970:1 2//1986:1 instead of a matrix with 1//1970:1 61//2013:1. Ideally, I would like to have the value of correlation assigned to each country over time. Is there a way to modify this setting? Thank you.
Instead of compute do
set mycorrs i//1970:1 i//2013:1 = %cmom(1,2)
cyang40
Great. Thank you very much, Tom.
