Question about replication of Filardo(1994)
fan
Unread post by fan »
I am trying to replicate Filardo(1994) by using MLE method. I am keeping getting the following error message
The Error Occurred At Location 216, Line 21 of %MSVARPROB
I am not sure how to solve the problem and I am seeking for your help.
Here is my code
cal(m) 1948
open data filardo.dat
* The graph in the paper appears to be standardized (probably by dividing through
* by 2.0 times the sample standard deviation).
graph(footer="Figure 1. Log Growth Rate of Monthly IP")
# ipgr
stats(noprint) ipgr * 1959:12
stats(noprint) ipgr 1960:1 *
set g = ipgradjust
* Transform the information variables
set cligr   = 100.0*log(cli/cli{1})
set spgr    = 100.0*log(sp/sp{1})
set xlidiff = xli-xli{1}
set ffdiff  = fed-fed{1}
* And center them to zero means
   diff(center) s
end dofor s
* Common setup
compute nlags=4
source msvarsetup.src
@MSVARSetup(lags=nlags)
# g
nonlin(parmset=common) mu phi sigma
* Time varying probabilities
dec equation p1eq p2eq
dec vector   v1   v2
nonlin(parmset=tv) v1 v2
* This overrides the standard fixed definition
function  %MSVARPmat  time
type rect %MSVARPmat
type int  time
local integer i j
local rect    pexpand
local real    z
if nexpand==nstates {
   compute %MSVARPmat=pexpand*p
else {
* Initialize the probabilities using only the intercepts
function TVPInit
type vector TVPInit
local rect a
local integer i j
compute TVPInit=%MSVARInit()
* Define the logistic index for the transitions
equation p1eq *
# constant cligr{1}
equation p2eq *
# constant cligr{1}
* Standard guess values aiming to make state 1 the low growth state.
compute v1=log(.7/.3)~~0.0
compute v2=log(.95/.05)~~0.0
compute mu(1)=-1.7,mu(2)=.3
boxjenk(ar=nlags) g
compute phi=||%beta(1),%beta(2),%beta(3),%beta(4)||
compute sigma=%seesq
 method=bhhh,iters=20) logltvtp gstart gend
Thank you in advance
Re: Question about replication of Filardo(1994)
Add an
@MSFilterInit
before the MAXIMIZE. It makes sure everything is set up properly.
fan
quote="TomDoan"]Add an
@MSFilterInit
before the MAXIMIZE. It makes sure everything is set up properly.[/quote]
Thank you for the quick reply. Since @MSFliterInit can't be used together with msvarsetup, I changed my code to mssetup. However, after setting up the ms procedure, the new error message says [quote] ## I2. Expected Instruction Here
>>>>#<<<<[quote] I could not figure out the mistake I made, so I am seeking for your help.
Here is my modified code
cal(m) 1948 a
# ipgr
set g = ipgradjust
   diff(center) s
end dofor s
* Common setup
compute nlags=4
# g
dec vector   v1   v2
type int  time
local integer i j
local rect    pexpand
local real    z
else {
function TVPInit
type vector TVPInit
local rect a
local integer i j
equation p1eq *
# constant cligr{1}
equation p2eq *
# constant cligr{1}
boxjenk(ar=nlags) g
You need to do an @MSVARInitial at some point before you put in your own guess values.
fan
TomDoan wrote:You need to do an @MSVARInitial at some point before you put in your own guess values.
Thank you for the advice. I have one more question would like to ask. Following the example of KIMNP078_1995.RPF, I am trying to modify the code to incorporate the possibility that the gap between average growth rats during expansion and recession could be smaller in more recent period. However, I am getting this error message
## SR10. Missing Values And/Or SMPL Options Leave No Usable Data Points.
I am not clear what caused this error as I do not see any missing values in the data set. Could you kindly take a look at my code? I am looking forward to hearing from you. Thank you in advance!!
cal(m) 1948
# ipgr
set g = ipgradjust
   diff(center) s
end dofor s
* Common setup
compute nlags=4
# g
*Set up the shift dummy and the extra parameters on the shift
set dummy = t>=1985:4
dec vect mustar(2)
*Override the %MSVARFVec function. This returns the expanded set of likelihood
*functions across all state combinations.
function %MSVARFVec time
type vector %MSVARFVec
type integer time
local integer i j state
local vect u
dim %MSVARFVec(nexpand)
do i=1,nexpand
compute state=MSVARLagState(i,1)
compute u=%xt(y,time)-mu(state)(1)-mustar(state)*dummy(time)
do j=1,nlags
    compute statej=MSVARLagState(i,j+1), $
        u=u-phi(j)*(%xt(y,time-j)-mu(statej)(1)-mustar(statej)*dummy(time-j))
compute %MSVARFVec(i)=exp(-.5*MSVARLogDetV(state)-.5*%qform(MSVARSigmaInv(state),u))
@msvarinitial gstart gend
dec vector   v1   v2
type int  time
local integer i j
local rect    pexpand
local real    z
else {
function TVPInit
type vector TVPInit
local rect a
local integer i j
equation p1eq *
# constant cligr{1}
equation p2eq *
# constant cligr{1}
You never initialize MUSTAR and you don't include it in your parameter set.
fan
TomDoan wrote:You never initialize MUSTAR and you don't include it in your parameter set.
Thank you so much for pointing out my silly mistakes. Have a nice day
fan
As you mentioned that to rescale that the growth rates of IP for period before 1960 would change the mean during that period, which wouldn't make much sense, could you please kindly suggest a better way to deal with data sets that have the similar pattern, dispersion in the early sample appears greater than in the later part? Many Thanks
There's no reason you can't have a variance which changes at a known location. It would require changing the @MSVARFVEC function.
fan
TomDoan wrote:There's no reason you can't have a variance which changes at a known location. It would require changing the @MSVARFVEC function.
Thank you for your quick reply. Following your suggestion, I modified the @MSVARFVEC function. Could you please take a quick look and let me know whether it is correct? Many Thanks
set dummy = t<=1959:12
dec real alfa
* Override the %MSVARFVec function. This returns the expanded set of
* likelihood functions across all state combinations.
type integer time
local vect    u
do i=1,nexpand
   do j=1,nlags
      compute statej=MSVARLagState(i,j+1),$
        u=(1+alfa*time(t))*(u-phi(j)*(%xt(y,time-j)-mu(statej)(1))
No. If you look at where you put the rescaling, it's applying the factor multiple times to the short lags. Plus, even if you get that corrected, it's not the same thing as the much simpler (and more justifiable) correction of the variances.
fan
TomDoan wrote:No. If you look at where you put the rescaling, it's applying the factor multiple times to the short lags. Plus, even if you get that corrected, it's not the same thing as the much simpler (and more justifiable) correction of the variances.
Thank you for your quick response. I changed the code, but not sure whether the change is correct or not. Could you please kindly take a look? If the change is incorrect, could you please share a little a tip how to make the variance correction
dec real alfa
type integer time
local vect    u
do i=1,nexpand
   do j=1,nlags
        u=(u-phi(j)*(%xt(y,time-j)-mu(statej)(1))
   compute %MSVARFVec(i)=exp(-.5*MSVARLogDetV(state)*(1+alfa*dummy(t))-.5*%qform(MSVARSigmaInv(state)(1+alfa*dummy(t))*,u))
What the correct change is depends upon whether 1+alfa*dummy(t) is supposed to inflate or deflate the variance. Think about what should happen to the log variance (first term) and the inverse variance (second term) when you multiply (or divide, depending upon the interpretation of the factor) the variance by a constant.
fan
TomDoan wrote:What the correct change is depends upon whether 1+alfa*dummy(t) is supposed to inflate or deflate the variance. Think about what should happen to the log variance (first term) and the inverse variance (second term) when you multiply (or divide, depending upon the interpretation of the factor) the variance by a constant.
Thank you for sharing the tip. 1+alfa*dummy(t) is supposed to inflate the variance as the author points out that dispersion in the first third of the sample appears greater than in the later part. So, I need to inflation the log variance by multiplying 1+alfa*dummy(t), and deflating the inverse variance by dividing 1+alfa*dummy(t). Is that correct?
 compute %MSVARFVec(i)=exp(-.5*MSVARLogDetV(state)*(1+alfa*dummy(t))-.5*%qform(MSVARSigmaInv(state)/(1+alfa*dummy(t)),u)
Multiplying the log by the inflation factor is *really* not the right thing to do. The first part of that is actually computing v^(-.5) (using exp(-.5*log(v)) so you either divide the whole factor by sqrt(1+alfa*dummy) or add log(1+alfa*dummy) to the v before it gets multiplied by the -.5.
