Bjornland-Leitemo JME 2009
bjornland_leitemo_jme_2009.zip is a replication for for Bjørnland, Hilde C. and Kai Leitemo (2009): "Identifying the Interdependence between US Monetary Policy and the Stock Market", Journal of Monetary Economics, vol 56, pp 275-282. This uses the @ShortAndLong procedure to estimate a structural VAR on a five variable system, and includes Monte Carlo integration of the IRF's.
If you are looking for a more basic example of short- and long-restrictions with error band calculations, see https://estima.com/forum/viewtopic.php?f=8&t=2335.
Detailed Description
shengyang
Re: Bjornland-Leitemo JME 2009
I revised the program by expanding to 7-variable matrix. However, it keeps showing an error "ShortAndLong failed to converge to a solution". I greatly appreciate if you could give me some advices.
What are your SR and LR matrices?
shengyang
SR and LR matrices are as follows; if the LR restriction is removed, the error message will change to "## MAT5. Needed Matrix with Dimensions 7 x 1, Got 5 x 1 Instead"
input lr
. . 0 . . . .
input sr
. 0 0 0 0 0 0
. . 0 0 0 0 0
. . . 0 0 0 0
. . . . 0 0 0
. . . . . . 0
. . . . . . 0
input lr
. . 0 . . . .
input sr
. 0 0 0 0 0 0
. . 0 0 0 0 0
. . . 0 0 0 0
. . . . 0 0 0
. . . . . . 0
. . . . . . 0
How are you distinguishing your 5 and 6 shocks? You're also failing the Rubio-Ramirez-Wagonner-Zha counting rule.
Re: SVAR Montesvar command
Questions about data should generally be addressed to the authors. However, it's fairly clear that it's 100.0*(log(cpi)-log(cpi{12}))cczzwhy wrote:Thank you very much! I also get a question on the dataset in Bjørnland, Hilde C. and Kai Leitemo (2009): "Identifying the Interdependence between US Monetary Policy and the Stock Market" paper.Can you tell me how you calculate the monthly data of pi from cpi?
cczzwhy
Hello,Tom!I got a question about graphing error bands in irf. I am trying to generate a irf with two different error bands like,but my model is a svar,so should I use the code ?
What should I do to take the two different pairs of lower and upper vectors out?
@MCGraphIRF(model=varmodel,shocklabels=shocklabels,varlabels=varlabels,$
center=input,impulses=baseirfs,percent=||.025,.16,.84,.975||,$
footer="Figure 7. Pointwise 68% and 95% Posterior Bands, B-Q Model")Code: Select all
@MCProcessIRF(model=varvix,percentiles=||.025,.16,.84,.975||,center=median,lower=lower,upper=upper,irf=irf)What should I do to take the two different pairs of lower and upper vectors out?
You would have to do two separate @MCPROCESSIRF's to get two sets of lower and upper (use different names). However, why can't you use @MCGRAPHIRF?
cczzwhy
Thanks for your reply.It is because i am trying to generate a graph like Figure 7-26 in[Introduction to rats*],by using ,what should I do to generate the fan area if using mcgraphirf?
graph(row=1,col=1,header=varlabels(5),nodates,ovcount=3,overlay=fan,ovsame) 3-
@MCProcessIRF(model=varvix,percentiles=||.025,.975||,center=median,lower=lower95,upper=upper95,irf=irf)
@MCProcessIRF(model=varvix,percentiles=||.16,.84||,center=median,lower=lower68,upper=upper68,irf=irf)
for i = target and j = shock the graph would be something like
graph(overlay=fan,other options) 5
# irf(i,j)
# lower95(i,j)
# lower68(i,j)
# upper68(i,j)
# upper95(i,j)
# irf(i,j)
# lower95(i,j)
# lower68(i,j)
# upper68(i,j)
# upper95(i,j)
zoe_z
I have a quick question. If I want to use MC simulation to generate 68% probability bands for impulse responses using Cholesky factorization, can I simply use the same model as for SR-LR but only use SR block, while not restricting LR block?
dec rect lr(5,5) sr(5,5)
input lr
input sr
. 0 0 0 0
. . 0 0 0
. . . 0 0
. . . . 0
This would be a quick way of switching between Cholesky and SR-LR models while getting consistent probability bands for IRFs.
Thanks!
input lr
input sr
. 0 0 0 0
. . 0 0 0
. . . 0 0
. . . . 0
Thanks!
Yes. That would work.
cczzwhy
Hello Tom!I have no idea about how to generate the variance composition in this procedure ,is there any examples?
The variance decomposition is included in the original program. Look for "errors(". It has to use the factor matrix before standardizing the shocks.
istiak
There are some numbers in the 5 variable model code that I do not understand. For example, in one line I see that
"@varirf(model=varstockp,steps=nsteps,factor=f,page=byshock,$
shocks=shocklabels,varlabels=varlabels,accumulate=||2,3,4||)"
In another line, I see that
"option vect[int] accum ||1||"
"@SRLRDoDraws(accum=||2,3,4||,steps=nsteps,model=varstockp,lr=lr,sr=sr)"
My question is what do the numbers in ||....||indicate?
If I use a 6 variable or 4 variable or 3 variable model, how do the numbers in the above ||....|| will change?
Thank you so much.
Thank you so much.
