Balcilar, et al EE(2015)
n_khraief
Dear Listers,
I am trying to run the oil_stock_msvar_irf2.RPF program I have got always the same following error:
## SR3. Tried to Use Series Number 45844208, Only 5 Are Available
The Error Occurred At Location 531, Line 72 of MSSYSREGRESSION
Would you like please to help me with this.
Kind regards,
N.K
Kind regards,
N.K
- mssysregression.src
- MSSYREGRESSION_file
- (20.45 KiB) Downloaded 1423 times
- oil_stock_monthly.dat
- data_file
- (297.71 KiB) Downloaded 1396 times
- oil_stock_msvar_irf2.rpf
- program_file
- (8.39 KiB) Downloaded 1377 times
n_khraief
Re: Error
Thank you for your reply but I used the excel file and I got the same error message.
- oil_stock_monthly.xlsx
- excel_file
- (187.15 KiB) Downloaded 1095 times
Re: Error
1. It has nothing to do with the data file. However, I couldn't run a program which references a data file that I don't have.
2. Use a newer version of @MSSYSREGRESSION.
3. A MS model is completely inappropriate to your data. There are definitely multiple regimes, but there's nothing "Markov" about them---there's a 30 year period in the middle of the data where the oil prices are controlled.
Re: Balcilar, et al EE(2015)
I have an e-mail in to the authors with some questions about what they did. At any rate, you need a newer version of MSSYSREGRESSION.
n_khraief
I am so grateful.
Did you mean the last version of MSSYSREGRESSION the attached file.
Kind regards and many thanks,
N.K
I am so grateful.
N.K
- (20.44 KiB) Downloaded 1404 times
A cleaned up version of the program is now posted at https://estima.com/forum/viewtopic.php?f=8&t=2536. As in the paper, this finds two regimes, one where the price of oil doesn't change, one where it does. As I said above, it's not clear that a "Markov" assumption is reasonable for that, since for about 30 years, the price of (U.S.) oil was controlled by law.
n_khraief
Thanks a lot, Tom.
n_khraief
Dear Tom thank you for your valuable efforts.
I have a question:
Why the error:
## SR3. Tried to Use Series Number 70201344, Only 9 Are Available
repeated after the following part of program
@mssysregression(states=2,switch=ch)
# dlsp dloil
# dlsp{1 to lag} dloil{1 to lag} constant ect{1}
N.K
I have a question:
Why the error:
# dlsp dloil
N.K
You're using an outdated version of the program. The whole MS suite of procedures has changed.
n_khraief
How can test for the presence of Markov assumption in time series?
N.K
N.K
There really isn't a way to do that. Tests for n+1 vs n regimes are very complicated and generally not worth the effort---people typically use information criteria to compare those, though that requires that you can actually fit an n+1 regime model, which is often quite a task if n regimes are adequate as the n+1 regime model isn't identified. And I'm not sure I've ever seen a test for Markov vs some other form of switching.
n_khraief
Many thanks Tom.
Actually, I just found this paper that developed a new test for the Markov property in time series. A Gauss code to implement
this test is available from the authors.
https://hong.economics.cornell.edu/pape ... Series.pdf
Thanks a lot Tom,
N.K
Thanks a lot Tom,
N.K
