Chang and Serletis (2015)
za2015
Unread post by za2015 »
I am interested in replicating a paper by Chang and Serletis (2015): "Oil, Uncertainty, and Gasoline Prices".
This is the URL:
https://econ.ucalgary.ca/manageprofile/ ... -Jan15.pdf
specifically, I am interested in figure 6 and table 5 of the paper. To compute nonlinear impulse response functions as in Kilian and Vigfusson (2013) after accounting for the effect of oil price uncertainty.
Thank you
Re: Chang and Serletis (2015)
Have you checked with Serletis? He does a lot of his work with RATS.
za2015
I emailed him earlier today and waiting for his reply!
The Kilian-Vigfusson methods are shown at https://estima.com/forum/viewtopic.php?f=8&t=2242.
za2015
The Kilian and Vigfusson (2013) code doesn't account for the uncertainty effect in the garch-in-mean VAR. So, I am not sure how to compute the nonlinear IRFs using a bivariate GARCH-in-mean VAR.
Thank you
The GIRFs for the GARCH model are from some of Serletis' earlier work
https://estima.com/forum/viewtopic.php?f=8&t=1189
It looks like this paper combines the two ideas.
za2015
It does, but I wasn't sure whether the nonlinear IRFs account for uncertainty effect or not! In Kilian and Vigfusson they don't.
So, would I be able to run 10,000 simulations on RATS?
za2015
Regarding Elder-Serletis(2010) VAR-GARCH-M paper, after running the code for the IRF where can I find the results for the plots? Is it in the series: GDPTOPLUS and GDPTOMINUS? I just need to get the results and draw the figures using different software.
Thank you for your time,
za2015 wrote:Hi,
That's correct. Those are the responses to positive and negative shocks (of size equal to the square root of the sample variance of the oil price change) with the "M" effect included in the model. The same with "nom" at the end of the name are the responses in the model without the "M" effect.
za2015
I noticed that when running the code for the IRF using stock returns instead of gdp, the series for the stockreturnstoplusnom and stockreturnstominusnom does not show on the screen. i think the name is too long that's why. Is there a way that I can fix this problem without changing the name of the variable?
Here is the code:
compute shock=sqrt(meanhoil)
compute %parmspoke(allparms,withMParms)
@CalcIRF ||shock,0.0||
set stockreturnstoplus 1 nsteps+1 = irf(t)(2)
@CalcIRF ||-shock,0.0||
set stockreturnstominus 1 nsteps+1 = irf(t)(2)
* And without M effects
compute %parmspoke(allparms,noMParms)
set stockreturnstoplusnom 1 nsteps+1 = irf(t)(2)
set stockreturnstominusnom 1 nsteps+1 = irf(t)(2)
za2015
I have another question about Elder-Serletis (2010) paper:
Are the bands established with 95% confidence intervals?
Thank you,
za2015 wrote:Hi Tom,
Here is the code:
Only the first 16 characters matter so, although you can use the really long names, they will actually be treated as stockreturnstopl and stockreturnstomi. You can call them whatever you want---there's no reason they have to start with stockreturns; returnstoplus and returnstominus will work just as well.
za2015 wrote:Hi,
Thank you,
From the comments in the program:
* This will do 16- and 84%-ile bands around the median response which is roughly
* the equivalent of +/- 1 s.d. bands, but allowing for asymmetry.
za2015
I have another question, Tom:
Is there a way I can add a square on the graph that shows the significance at the 5% level, as in the attached graph?
Thank you,
za2015
How can I adjust the code to show the 95% confidence intervals in the series?
