ESTAR
ef08kp
ESTAR
hi,
I am modelling real exchange rates for developing countries and to do that i am using Terasvirta's ESTAR models. Well, yes there exists a zipped folder that replicates terasvirta's 1994 results however the examples that are mentioned in the file are about LSTAR models. Neverthless when i ran the sample code for one of the files lynx.prg provided in the zippped folder ( data was also provided by the zipped folder) i didnt get the results as they are in the TERASVIRTA'S 1994 paper. Here is the code:
OPEN DATA "h:\settings\Personal\LYNX.xls"
CALENDAR(M) 1973
ALL 1982:04
DATA(FORMAT=XLS,ORG=COLUMNS) 1973:01 1982:04 lynx
set x = log(lynx)/log(10)
diff(center) x /xc
source startest.src
do d=1,9
@StarTest(p=11,d=d) xc
end do d
stats x
compute scalef=1.0/sqrt(%variance)
nonlin(parmset=starparms) gamma c
frml flstar = %logistic(1.8*gamma*(x{3}-c),1.0)
compute c=%mean,gamma=2.0
equation standard x
# constant x{1 to 11}
equation transit x
frml(equation=standard,vector=phi1) phi1f
frml(equation=transit ,vector=phi2) phi2f
frml star lynx = f=flstar,phi1f+f*phi2f
nonlin(parmset=regparms) phi1 phi2
nlls(parmset=regparms,frml=star) x
equation standard x
# x{1}
equation transit x
# x{2 3 4 10 11}
nlls(parmset=regparms+starparms,frml=star) x
stats %resids
I had the following queries:
1. i wasnt able to understand the underlined part of the code.
2. what all changes i need to make to run a code for a ESTAR model given i have done the linearity tests and my delay parameter (d)=1 and lags (p) =1.
3. Also why have the starting values for gamma taken as 2.
thank you
kumar somya
CALENDAR(M) 1973
ALL 1982:04
diff(center) x /xc
source startest.src
do d=1,9
end do d
stats x
equation standard x
equation transit x
equation standard x
# x{1}
equation transit x
# x{2 3 4 10 11}
stats %resids
thank you
kumar somya
Re: ESTAR
The lynx data set is annual from 1821 to 1934. You somehow got the dates different, and in the process, lost a couple of data points.ef08kp wrote:hi,
CALENDAR(M) 1973
ALL 1982:04
diff(center) x /xc
source startest.src
do d=1,9
end do d
stats x
equation standard x
equation transit x
equation standard x
# x{1}
equation transit x
# x{2 3 4 10 11}
stats %resids
thank you
kumar somya
On reading the program, I noticed that the following should replace the two lines:
* In practice, you would use the following:
* In order to help reproduce the published results, we're putting in
* a rounded value for scalef
compute scalef=1.8
frml flstar = %logistic(scalef*gamma*(x{3}-c),1.0)1. Nothing seems to be underlined. Try just including the part of the code that you need explained.
2. An e-star replaces
frml flstar = %logistic(scalef*gamma*(x{d}-c),1.0)
with
frml festar = 1-exp(-scalef^2*gamma*(x{d}-c)^2)
using festar elsewhere in place of flstar.
3. That's explained in the comments. It's big enough to separate the data into regimes, but not so large that it's impossible for it to move. (If gamma starts too large, the transition function will be either 0 or 1 at almost every data point, and the derivative with respect to gamma will be zero).
ef08kp
Re: ESTAR
Hi, the part of the that i didnt understand is:
equation standard x
# x{1}
equation transit x
# x{2 3 4 10 11}
equation standard x
# x{1}
equation transit x
# x{2 3 4 10 11}
Re: ESTAR
There are two branches, which here are called standard and transit. The instructionef08kp wrote:Hi, the part of the that i didnt understand is:
equation standard x
# x{1}
equation transit x
# x{2 3 4 10 11}
frml(equation=xxx,vector=yyy) zzz
translates the linear equation xxx into the non-linear formula zzz, and writes the formula using the vector yyy in place of the coefficients from the linear equation. For instance,
equation transit x
# x{2 3 4 10 11}
creates the formula phi2f which will have the form phi2(1)*x(t-2)+phi2(2)*x(t-3)+phi2(3)*x(t-4)+phi2(4)*x(t-10)+phi2(5)*x(t-11). As you can see, it's a lot easier to do this by defining the linear equation and translating, than by direct coding.
takes the two branches and combines them based upon the value of the transition function flstar.
The first of these estimates only the regression parameters holding the "star" parameters fixed. The second then estimates all the parameters together.
ef08kp
Re: ESTAR
thanks for such a lucid reply on the code. I gave the following code after making amends:
OPEN DATA "H:\LYNX.xls"
CALENDAR(A) 1821
ALL 1934:01
DATA(FORMAT=XLS,ORG=COLUMNS) 1821:01 1934:01 lynx
diff(center) x / xc
source startest.src
do d=1,9
end do d
stats x
compute scalef=1.8
equation standard x
equation transit x
frml star x = f=flstar,phi1f+f*phi2f
equation standard x
# x{1}
equation transit x
# x{2 3 4 10 11}
equation standard x
# x{1}
equation transit x
# x{2 3 4 9 11}
stats %resids
and the output that i get as it is:
Test for STAR in series X. AR length=11 delay=1
Test F-stat Signif
Linearity 0.6226741 0.9271
H01 0.8351087 0.6063
H02 0.3655942 0.9649
H03 0.7644539 0.6737
Test for STAR in series X. AR length=11 delay=2
Test F-stat Signif
Linearity 1.5076229 0.0867
H01 1.7991184 0.0760
H02 0.9573417 0.4931
H03 1.4592817 0.1643
Test for STAR in series X. AR length=11 delay=3
Test F-stat Signif
Linearity 2.8824584 0.0002
H01 2.2799061 0.0221
H02 2.3245568 0.0174
H03 2.4749249 0.0103
Test for STAR in series X. AR length=11 delay=4
Test F-stat Signif
Linearity 1.9044282 0.0165
H01 1.1929929 0.3131
H02 2.1628094 0.0270
H03 1.9060830 0.0510
Test for STAR in series X. AR length=11 delay=5
Test F-stat Signif
Linearity 0.8415018 0.6990
H01 0.6361525 0.7902
H02 1.3661956 0.2096
H03 0.6105938 0.8145
Test for STAR in series X. AR length=11 delay=6
Test F-stat Signif
Linearity 0.7460010 0.8156
H01 0.7723175 0.6655
H02 0.9446770 0.5044
H03 0.5824690 0.8376
Test for STAR in series X. AR length=11 delay=7
Test F-stat Signif
Linearity 1.6187611 0.0554
H01 2.5273400 0.0116
H02 0.8101852 0.6298
H03 1.0807723 0.3876
Test for STAR in series X. AR length=11 delay=8
Test F-stat Signif
Linearity 2.5687501 0.0009
H01 1.3373657 0.2290
H02 3.1913891 0.0016
H03 2.1720057 0.0244
Test for STAR in series X. AR length=11 delay=9
Test F-stat Signif
Linearity 1.5465760 0.0742
H01 1.2962767 0.2509
H02 1.3118699 0.2375
H03 1.7974375 0.0685
Statistics on Series X
Annual Data From 1821:01 To 1932:01
Observations 112
Sample Mean 2.911441 Variance 0.313933
Standard Error 0.560297 of Sample Mean 0.052943
t-Statistic (Mean=0) 54.991860 Signif Level 0.000000
Skewness -0.403384 Signif Level (Sk=0) 0.085531
Kurtosis (excess) -0.686422 Signif Level (Ku=0) 0.150763
Jarque-Bera 5.236230 Signif Level (JB=0) 0.072940
## NL6. NONLIN Parameter PHI1(1) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI1(2) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI1(3) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI1(4) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI1(5) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI1(6) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI1(7) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI1(8) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI1(9) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI1(10) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI1(11) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI1(12) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI2(1) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI2(2) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI2(3) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI2(4) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI2(5) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI2(6) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI2(7) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI2(8) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI2(9) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI2(10) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI2(11) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI2(12) Has Not Been Initialized. Trying 0
Nonlinear Least Squares - Estimation by Gauss-Newton
Convergence in 2 Iterations. Final criterion was 0.0000000 <= 0.0000100
Dependent Variable X
Usable Observations 101 Degrees of Freedom 77
Total Observations 112 Skipped/Missing 11
Centered R**2 0.930436 R Bar **2 0.909657
Uncentered R**2 0.997536 T x R**2 100.751
Mean of Dependent Variable 2.8941247428
Std Error of Dependent Variable 0.5573387988
Standard Error of Estimate 0.1675198835
Sum of Squared Residuals 2.1608441764
Regression F(23,77) 44.7780
Significance Level of F 0.00000000
Log Likelihood 50.84060
Durbin-Watson Statistic 1.962900
1. PHI1(1) 0.046850178 0.546116792 0.08579 0.93185776
2. PHI1(2) 0.692967777 0.180597498 3.83708 0.00025341
3. PHI1(3) 0.400529640 0.242210451 1.65364 0.10227157
4. PHI1(4) 0.256605423 0.263717264 0.97303 0.33358410
5. PHI1(5) -0.195698901 0.236042887 -0.82908 0.40962079
6. PHI1(6) -0.069392486 0.260043785 -0.26685 0.79029861
7. PHI1(7) 0.157233615 0.290870401 0.54056 0.59036948
8. PHI1(8) -0.301547093 0.304192476 -0.99130 0.32464232
9. PHI1(9) 0.366941977 0.277727393 1.32123 0.19033716
10. PHI1(10) 0.105380885 0.265373182 0.39710 0.69238898
11. PHI1(11) -0.306078863 0.265565287 -1.15256 0.25265831
12. PHI1(12) 0.079548643 0.196132783 0.40559 0.68617187
13. PHI2(1) -1.929499818 1.009423698 -1.91149 0.05966309
14. PHI2(2) 0.796581701 0.271502136 2.93398 0.00440749
15. PHI2(3) -1.767519848 0.414412959 -4.26512 0.00005620
16. PHI2(4) 1.500593248 0.450620337 3.33006 0.00133484
17. PHI2(5) -0.324800754 0.466707307 -0.69594 0.48856109
18. PHI2(6) 0.472362414 0.473092728 0.99846 0.32118557
19. PHI2(7) -0.490538185 0.484736996 -1.01197 0.31472293
20. PHI2(8) 0.524911595 0.477433765 1.09944 0.27500016
21. PHI2(9) -0.660001005 0.428497568 -1.54027 0.12759482
22. PHI2(10) -0.009860803 0.394758103 -0.02498 0.98013605
23. PHI2(11) 0.898063449 0.399116231 2.25013 0.02729566
24. PHI2(12) -0.697649696 0.292277363 -2.38694 0.01944326
Usable Observations 101 Degrees of Freedom 95
Centered R**2 0.909280 R Bar **2 0.904506
Uncentered R**2 0.996787 T x R**2 100.675
Standard Error of Estimate 0.1722296646
Sum of Squared Residuals 2.8179904495
Log Likelihood 37.43158
Durbin-Watson Statistic 1.905887
1. PHI1(1) 1.142538637 0.012196342 93.67880 0.00000000
2. PHI2(1) -0.954242884 0.151577881 -6.29540 0.00000001
3. PHI2(2) 1.210845204 0.254671072 4.75455 0.00000707
4. PHI2(3) -0.455332955 0.156074429 -2.91741 0.00440493
5. PHI2(4) 0.484065331 0.086286485 5.60998 0.00000020
6. PHI2(5) -0.554868492 0.108473253 -5.11526 0.00000163
Convergence in 8 Iterations. Final criterion was 0.0000023 <= 0.0000100
Usable Observations 101 Degrees of Freedom 93
Centered R**2 0.913390 R Bar **2 0.906871
Uncentered R**2 0.996932 T x R**2 100.690
Standard Error of Estimate 0.1700831168
Sum of Squared Residuals 2.6903287959
Log Likelihood 39.77279
Durbin-Watson Statistic 2.028622
1. PHI1(1) 1.159984554 0.023541082 49.27490 0.00000000
2. PHI2(1) -0.807993894 0.148388424 -5.44513 0.00000042
3. PHI2(2) 0.956917201 0.244847549 3.90822 0.00017638
4. PHI2(3) -0.343980467 0.138167875 -2.48958 0.01456587
5. PHI2(4) 0.490987063 0.072463848 6.77561 0.00000000
6. PHI2(5) -0.545143976 0.092709187 -5.88015 0.00000006
7. GAMMA 2.285645135 0.659173986 3.46744 0.00079750
8. C 2.723728365 0.084779610 32.12716 0.00000000
Centered R**2 0.902665 R Bar **2 0.897542
Uncentered R**2 0.996553 T x R**2 100.652
Standard Error of Estimate 0.1783985751
Sum of Squared Residuals 3.0234749028
Log Likelihood 33.87725
Durbin-Watson Statistic 2.011131
1. PHI1(1) 1.155674270 0.014666137 78.79882 0.00000000
2. PHI2(1) -0.773769977 0.136785652 -5.65681 0.00000016
3. PHI2(2) 0.876553512 0.223035415 3.93011 0.00016114
4. PHI2(3) -0.368373534 0.134089827 -2.74721 0.00719149
5. PHI2(4) 0.278688670 0.049503364 5.62969 0.00000018
6. PHI2(5) -0.248361702 0.071517803 -3.47273 0.00077736
Convergence in 6 Iterations. Final criterion was 0.0000046 <= 0.0000100
Centered R**2 0.903029 R Bar **2 0.895730
Uncentered R**2 0.996565 T x R**2 100.653
Standard Error of Estimate 0.1799698309
Sum of Squared Residuals 3.0121900226
Log Likelihood 34.06609
Durbin-Watson Statistic 2.061257
1. PHI1(1) 1.169360994 0.029439254 39.72115 0.00000000
2. PHI2(1) -0.789160172 0.164712475 -4.79114 0.00000626
3. PHI2(2) 0.873681809 0.265570256 3.28983 0.00141680
4. PHI2(3) -0.360429543 0.146655851 -2.45766 0.01583761
5. PHI2(4) 0.280102578 0.051210224 5.46966 0.00000038
6. PHI2(5) -0.256835479 0.074474964 -3.44862 0.00084838
7. GAMMA 1.942275628 0.659495280 2.94509 0.00407859
8. C 2.683908029 0.114926704 23.35322 0.00000000
again i am not getting results in the paper. Also the when you mention the following instruction:
equation standard x
# x{1}
equation transit x
# x{2 3 4 10 11}
does it mean at lag 1there is standard estimation and lags 2 to 11 transition take places between regimes therefore nonlinear.
thank you
kumar
CALENDAR(A) 1821
ALL 1934:01
diff(center) x / xc
source startest.src
do d=1,9
end do d
stats x
compute scalef=1.8
equation standard x
equation transit x
equation standard x
# x{1}
equation transit x
# x{2 3 4 10 11}
equation standard x
# x{1}
equation transit x
# x{2 3 4 9 11}
stats %resids
Test F-stat Signif
Test F-stat Signif
Test F-stat Signif
Test F-stat Signif
Test F-stat Signif
Test F-stat Signif
Test F-stat Signif
Test F-stat Signif
Test F-stat Signif
Observations 112
equation standard x
# x{1}
equation transit x
# x{2 3 4 10 11}
thank you
kumar
Re: ESTAR
You're still two observations short, presumably in your data file.
I wouldn't be that concerned about being able to reproduce results out of papers. In general, we have a very hard time ever matching results unless we can get both the data and the program. There are too many minor decisions that don't get documented within the paper that affect the results.
The "standard" model is the branch that applies where the transition function is 0. When the transition function is 1, it's the sum of the standard and the transit.
Re: ESTAR
I read through my correspondence with Prof. Teräsvirta regarding the results in the paper. STAR models are very tricky to fit, and have many local modes. He re-ran one of his models with more modern optimization code and got different (better) results. The RATS code for estimating these is correct; but RATS, and any other optimizer, is going to be sensitive to guess values when the objective function is multi-modal.
ef08kp
Re: ESTAR
I was estimating the an estar model for yen dollar ( CPI based) real effective exchange rate with P =1 and d=1 ( the lag and delay parameter respectively). could you please just check the code below as i was not getting right results given i was practising on a paper that has used the same dataset for yen dollar exchange rate for the same period. Could the problem be starting value of gamma ?
OPEN DATA "h:\settings\Personal\jpus.xls"
CALENDAR(M) 1973
ALL 1996:12
DATA(FORMAT=XLS,ORG=COLUMNS) 1973:01 1996:12 reer
set x = reer
source startest.src
do d=1,9
@StarTest(p=1,d=d) x
end do d
stats x
frml festar = 1-exp(-scalef^2*gamma*(x{1}-c)^2)
compute c=%mean,gamma=1.0
equation standard x
# constant x{1}
equation transit x
# constant x{1}
frml star x = f=festar,phi1f+f*phi2f
equation standard x
# x{1}
equation transit x
# x{1}
nlls(parmset=regparms+starparms,frml=star,trace) x
thank you
CALENDAR(M) 1973
ALL 1996:12
set x = reer
source startest.src
do d=1,9
end do d
stats x
equation standard x
# constant x{1}
equation transit x
# constant x{1}
equation standard x
# x{1}
equation transit x
# x{1}
thank you
Re: ESTAR
If you have the same data set, you should be able to reproduce the published results by feeding in the published gamma and c. (Given those, the model is linear). It's possible that either the published result or the one you're getting is a local mode rather than the global one - since this is a non-linear least squares model, the one with the higher sum of squared residuals is the "wrong" mode.
