Does GARCH contradict EMH?
Postby economicsstudent » Tue Apr 10, 2012 3:19 pm
Carrying out tests of efficiency on stock market returns - if i have concluded that the majority of tests support the returns being stationary, is it a contradiction to then say that the same data displays evidence of ARCH effects?
economicsstudent
Re: Does GARCH contradict EMH?
Postby TomDoan » Wed Apr 11, 2012 11:45 am
economicsstudent wrote:Carrying out tests of efficiency on stock market returns - if i have concluded that the majority of tests support the returns being stationary, is it a contradiction to then say that the same data displays evidence of ARCH effects?
You don't want them to be stationary, you want them to be uncorrelated. Those aren't even close to being the same thing.
ARCH effects means that the returns are dependent in second moments, so they aren't serially independent. If you're testing a version of the EMH that requires independence, then the presence of ARCH would reject that. If you use a weaker version which requires only a lack of correlation, then the presence of ARCH wouldn't reject that.
If you are confused about this, you need to discuss it with your teacher. Most of your questions have nothing to do with using the RATS program.
Postby economicsstudent » Wed Apr 11, 2012 4:23 pm
Thank you for your help.
economicsstudent
