Chan Karolyi Longstaff Sanders JOF 1992
Postby TomDoan » Mon Apr 29, 2013 1:04 pm
The following is a replication of the estimation of various interest rate models by GMM from Chan, Karolyi, Longstaff and Sanders(1992), "An Empirical Comparison of Models of the Short-Term Interest Rate", Journal of Finance, vol 47, no 3, 1209-1227. Note that the model, while estimated by monthly data, uses a parameterization which annualizes the rates. This includes two versions for the estimation; one which uses the weighting scheme from the original paper, the other uses a common weighting scheme computing under the just-identified specification.
ckls.rpf
Original estimation method
(5.3 KiB) Downloaded 4 times
ckls commonsw.rpf
Alternative estimation method
(5.52 KiB) Downloaded 4 times
rates.txt
Data file
(5.4 KiB) Downloaded 127 times
Last bumped by TomDoan on Mon Apr 29, 2013 1:04 pm.
Return to Examples and Sample Code
Who is online
