Error Correction Model (Non-Standard)
Posted: Tue Jun 15, 2010 3:53 pm
by moderator
The simplest way to estimate an error correction model is to use SYSTEM with the ECT instruction. That takes care of all the specialized bookkeeping for you. However, if you have to estimate a model using a different technique than provided by ESTIMATE, or if you have a restricted or otherwise non-standard model, you might need to use some type of two-step procedure. If so, you'll need some extra steps in order to be able to do impulse responses or forecasts.
The following is based upon an example from the Gujarati textbook:
cal(q) 1970
open data table21-1.prn
data(format=prn,org=columns) 1970:1 1991:4
* Estimate the cointegrating relation
linreg pce / u
# constant pdi
compute betaci=%beta(2)
set dpce = pce-pce{1}
set dpdi = pdi-pdi{1}
linreg(define=pceeq) dpce / upce
# constant dpdi u{1}
linreg(define=pcieq) dpdi / updi
# constant dpdi{1}
equation(coeffs=||1.0,1.0||,identity) pdiid pdi
# pdi{1} dpdi{1}
equation(coeffs=||1.0,1.0||,identity) pceid pce
# pce{1} dpce{1}
equation(coeffs=||1.0,-betaci||,identity) uid u
# pce pdi
vcv(matrix=v)
# upce updi
group ecm pceeq pcieq pdiid pceid uid
impulse(model=ecm,cv=v,steps=50,print)
Consumption (PCE) is modeled as a standard linear consumption function with an error correction term. In order to close the model, disposable income (PDI) is modeled as an exogenous drifiting random walk. The consumption equation:
while simple in form codes up several dynamic relationships among the variables. dpce and dpdi are differences of pce and pdi, and u is a linear combination of pce and pdi. The most straightforward way to handle this is to define identities which link the variables. The final model will produce responses for (in order) dpce, dpdi, pdi, pce and u since those are the dependent variables of the five equations in order.
