Graphs
Posted: Mon Jun 14, 2010 1:44 pm
by dalleyne
I have a question that is probably easy(I am using winrats 7.3).I am using an spgraph procedure to generate ten graphs.The program runs successfuly and all the graphs are output but they are placed near the left margin while the header remains the middle.If I generate at least four graphs the header is then dead centre and all looks well.How can I get the (10) graphs to move further to the right so that they can be below the header and not far to the left of it. On the other hand can I move the header to the left. I did not send the program since it is similar to the one used in the manual.
Please, can someone help.
D
Re: Graph
Posted: Mon Jun 14, 2010 2:17 pm
The placement of the graphs will depend upon your choices for HFIELDS and VFIELDS. If you do HFIELDS=4,VFIELDS=4, then put in 10 graphs, they'll fill the leftmost 1/4 of the page, then the second 1/4 page, put two graphs in a third 1/4 page and leave the rightmost 1/4 page blank, which sounds a bit like what you're getting.
Re: Graphs
Posted: Tue Jun 15, 2010 7:30 pm
by dalleyne
Thanks Tom,
Your assessment was correct.Iam now able to set the graphs below the header.
