Variations on BEKK
Posted: Wed Dec 02, 2009 2:53 pm
The code below provides modernized calculations for standard, diagonal and triangular BEKK models. The standard BEKK, can, of course, be done with GARCH directly. The code using MAXIMIZE can be used as the base if you want some additional features that aren't currently included. This uses the same data set as the garchmv.prg example.
Note that MV=TBEKK (for triangular BEKK) and MV=DBEKK (for diagonal BEKK) were added to the GARCH instruction with RATS 8.3. Also, the SIGNS option was added to allow for different sign effects on asymmetry.
* Variations on BEKK models
all 6237
open data g10xrate.xls
data(format=xls,org=columns) / usxjpn usxfra usxsui
* Standard BEKK with GARCH instruction
compute gstart=3,gend=6237
garch(p=1,q=1,mv=bekk,pmethod=simplex,piters=5) gstart gend xjpn xfra xsui
* General setup for GARCH with MAXIMIZE
compute n=3
dec series[vect] yv
dec frml[vect] residv
dec vect[series] u(n)
* SERIES[SYMM] named H and UU. UX and HX are used for the current values
* of the residual vector and H matrices
declare series[symm] h uu
declare symm hx(n,n)
declare vect ux(n)
declare frml[symm] hf
* Mean parameters
dec vect mu(n)
nonlin(parmset=meanparms) mu
* Define residuals
frml residv = yv-mu
* Define vector of dependent variables
gset yv = ||xjpn,xfra,xsui||
* Run preliminary regression to get estimates of residuals and means.
nlsystem(frmlvector=residv,parmset=meanparms,resids=u) gstart gend
compute rr=%sigma
gset h * gend = rr
gset uu * gend = rr
frml logl = $
hx = h(t) = hf(t) , $
ux = residv , $
uu(t) = %outerxx(ux) , $
%pt(u,t,ux) , $
%logdensity(hx,ux)
* Standard BEKK. Should be the same as above (just much slower)
dec rect var(n,n) vbr(n,n)
dec packed vct(n,n)
dec symm vcs
compute var=sqrt(.05)*%identity(n),vbr=sqrt(.45)*%identity(n)
compute vct=%decomp(rr)
nonlin(parmset=bekkparms) vct var vbr
FUNCTION %%BEKKInit
compute vcs=%ltouterxx(vct)
END
frml hf = vcs+%mqform(h{1},vbr)+%mqform(uu{1},var)
maximize(title="Standard BEKK Model",start=%%BEKKInit(),parmset=meanparms+bekkparms,$
method=bfgs,iters=400,pmethod=simplex,piters=5) logl gstart gend
* Diagonal BEKK
dec vect vav(n) vbv(n)
dec packed vct(n,n)
dec symm vcs vbs vas
compute vav=%fill(n,1,sqrt(.05)),vbv=%fill(n,1,sqrt(.45))
nonlin(parmset=dbekkparms) vct vav vbv
FUNCTION %%DBEKKInit
compute vbs=%outerxx(vbv)
compute vas=%outerxx(vav)
END
maximize(title="Diagonal BEKK Model",start=%%DBEKKInit(),parmset=meanparms+dbekkparms,$
* Triangular BEKK. This is written assuming the "causality" flows from
* the first to the last series, which means that the A' matrix in A'HA
* needs to be lower triangular. Because of the convention used in
* defining "packed" matrices, the output will show A and B as lower
* triangular, so this is actually doing AHA' rather than A'HA.
dec packed vat(n,n) vbt(n,n)
dec packed vct(n,n)
compute vat=sqrt(.05)*%identity(n),vbt=sqrt(.45)*%identity(n)
nonlin(parmset=tbekkparms) vct vat vbt
FUNCTION %%TBEKKInit
local integer i j
ewise vbr(i,j)=%if(j>=i,vbt(i,j),0.0)
ewise var(i,j)=%if(j>=i,vat(i,j),0.0)
END
maximize(title="Triangular BEKK",start=%%TBEKKInit(),parmset=meanparms+tbekkparms,$
